D5G0106N
D5G0106N
    ELECTROSWITCH
    旋转开关 28VDC 115VAC
D5G0106N 数据手册
D5 - SERIES SPECIFICATIONS AND ORDERING INFORMATION 1.437" DIAMETER 1.5 AMPS @ 28 VDC The D5 Series switch is an economical single section switch utilizing glass epoxy insulation, staked construction, and printed circuit board or solder lug terminals. The formed spring index uses a small face plate area with detenting available up to 12 positions. SPECIFICATIONS ELECTRICAL MECHANICAL Current and Voltage Rating: Make and break resistive load 1.5 amps @ 28 VDC; 0.5 amp @ 115 VAC. Current Carrying Capacity: 9 amps. Dielectric Strength: 1,500 VAC between current carrying parts and ground. Contact Resistance: Average initial 3.5 milliohms. Insulation Resistance: In excess of 750,000 megohms. Materials and Finishes: All parts utilize non-corrosive materials as standard. Clips and Rotors: Brass with silver plate as standard. Insulation: Glass epoxy. Index: Formed spring, hill and valley design. Index Life: 25,000 cycles minimum. Index Torque: Switches have lowest practical torque consistent with crisp detenting and smooth, reliable operation. Index Angles: Positive 30° standard. Index Stops: Fixed or continuous. Stop Strength: 25 in. lbs. minimum. Hardware: Mounting nut and lockwasher are shipped assembled. D STANDARD PART NUMBER PRINTED CIRCUIT BOARD TERMINALS SOLDER LUG TERMINALS SWITCHES - 30° INDEXING - FIXED STOPS SWITCHES - 30° INDEXING - FIXED STOPS ACTIVE POLES/ POLES POSITIONS SECTION 01 01 01 01 02 02 03 06 08 10 11 04 05 03 NO. OF SHORTING NONFIG. SECTIONS SHORTING 1 1 1 1 2 2 3 1 1 1 1 1 1 1 D5G0106S D5G0108S D5G0110S D5G0111S D5G0204S D5G0205S D5G0303S D5G0106N D5G0108N D5G0110N D5G0111N D5G0204N D5G0205N D5G0303N * DB DB DB DB DG DG DN ACTIVE POLES/ POLES POSITIONS SECTION 01 01 01 01 02 02 03 06 08 10 11 04 05 03 1 1 1 1 2 2 3 NO. OF SECTIONS 1 1 1 1 1 1 1 SHORTING D5G0106S - R D5G0108S - R D5G0110S - R D5G0111S - R D5G0204S - R D5G0205S - R D5G0303S - R NONFIG. SHORTING D5G0106N - R D5G0108N - R D5G0110N - R D5G0111N - R D5G0204N - R D5G0205N - R D5G0303N - R * DB DB DB DB DG DG DN * FIGURES ARE SHOWN ON PAGES 55 AND 56. DIMENSIONS STANDARD CONSTRUCTION D5G GLASS EPOXY CONSTRUCTION NON–TURN LUG .125W X .025 THK. .531 FROM C–LINE .063 ENGAGEMENT • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 26 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 ADDITIONAL OPTIONS AND ORDERING INFORMATION D5 - SERIES How to Order Additional Options: 2 DIGIT SERIES INSULATION TYPE D5 G - GLASS TOTAL POLES ACTIVE POSITIONS 01 - MIN. 12 - MAX @ 30° CONTACT TYPE S - SHORTING N - NON SHORTING TERMINAL TYPE 5 STOP TYPE L - SOLDER LUG R - REAR P.C. CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS D INDEX ANGLE SHAFT/ BUSHING SHAFT FLAT SEE CHART “A” SEE CHART “B” (SPECIFY) (SPECIFY) (SPECIFY) F - FIXED C - CONT. ADDITIONAL OPTIONS G (SPECIFY) (SPECIFY) (SPECIFY) (SPECIFY) SHAFT, BUSHING, AND FLAT OPTIONS D SHAFT AS VIEWED WITH NON-TURN LUG AT 9 O'CLOCK AND SHAFT IN EXTREME CCW POSITION AND STRUT BOLTS ORIENTED VERTICALLY. U W Y Z PRINTED CIRCUIT BOARD OPTIONS P.C. BOARD MOUNTING PATTERN R CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS. • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 27
D5G0106N 价格&库存
很抱歉,暂时无法提供与“D5G0106N”相匹配的价格&库存,您可以联系我们找货
