D7 - SERIES
SPECIFICATIONS AND ORDERING INFORMATION
1 7/8" DIAMETER 2.25 AMPS @ 28 VDC
The D7 Series, constructed with a dual-ball, hill and valley index, has increased the physical size of the switch conductors allowing for additional
current carrying capabilities. Standard designs utilize glass epoxy or ceramic
insulations, solder lug terminals, and 30° adjustable stop indexing.
SPECIFICATIONS
ELECTRICAL
MECHANICAL
Current and Voltage Rating: Make and break resistive load
2.25 amps @ 28 VDC; 1.0 amp @ 115 VAC.
Current Carrying Capacity: 9 amps.
Dielectric Strength: 1,500 VAC between current carrying parts and
ground.
Contact Resistance: Average initial 3 milliohms.
Insulation Resistance: Glass in excess of 750,000 megohms.
Ceramic in excess of 1,000,000 megohms.
Materials and Finishes: All parts utilize non-corrosive materials
as standard.
Clips and Rotors: Brass with silver plate as standard.
Insulation: Glass epoxy, or ceramic.
Index: Dual-ball, hill and valley design.
Index Life: 25,000 cycles minimum.
Index Torque: Switches have lowest practical torque consistent
with crisp detenting and smooth, reliable operation.
Index Angles: Positive 30° standard, 60° available.
Index Stops: Adjustable standard, fixed or continuous.
Stop Strength: 25 in. lbs. minimum.
Hardware: Mounting nut and lockwasher are shipped assembled.
STANDARD PART NUMBER
D
GLASS EPOXY INSULATION
CERAMIC INSULATION
SWITCHES - 30° INDEXING
ADJUSTABLE STOPS - SOLDER LUG TERMINALS - STOPS SET @ 2 POS.
ACTIVE
POLES/
NO. OF
POLES POSITIONS SECTION SECTIONS
01
02
02
03
03
04
04
05
06
06
06
08
09
10
02-11
02-11
02-05
02-11
02-03
02-11
02-05
02-11
02-05
02-03
02-11
02-05
02-03
02-05
1
1
2
1
3
1
2
1
2
3
1
2
3
2
1
2
1
3
1
4
2
5
3
2
6
4
3
5
SHORTING
NONSHORTING
FIG.
D7G0111S
D7G0211S
D7G0205S
D7G0311S
D7G0303S
D7G0411S
D7G0405S
D7G0511S
D7G0605S
D7G0603S
D7G0611S
D7G0805S
D7G0903S
D7G1005S
D7G0111N
D7G0211N
D7G0205N
D7G0311N
D7G0303N
D7G0411N
D7G0405N
D7G0511N
D7G0605N
D7G0603N
D7G0611N
D7G0805N
D7G0903N
D7G1005N
DA
DA
DH
DA
DM
DA
DH
DA
DH
DM
DA
DH
DM
DH
ACTIVE
POLES/
NO. OF
01
02
02
03
03
04
06
06
02-11
02-11
02-05
02-11
02-03
02-05
02-05
02-03
1
1
2
1
3
2
2
3
01
02
03
04
05
02-06
02-06
02-06
02-06
02-06
1
1
1
1
1
1
2
1
3
1
2
3
2
60° INDEXING
1
2
3
4
5
SHORTING
NONSHORTING
FIG.
D7C0111S
D7C0211S
D7C0205S
D7C0311S
D7C0303S
D7C0405S
D7C0605S
D7C0603S
D7C0111N
D7C0211N
D7C0205N
D7C0311N
D7C0303N
D7C0405N
D7C0605N
D7C0603N
DA
DA
DH
DA
DM
DH
DH
DM
________
________
________
________
________
D7C0106N-60
D7C0206N-60
D7C0306N-60
D7C0406N-60
D7C0506N-60
DK
DK
DK
DK
DK
* FIGURES ARE SHOWN ON PAGES 55 AND 56.
DIMENSIONS
STANDARD CONSTRUCTION
D7G - GLASS EPOXY CONSTRUCTION
• ELECTRONIC PRODUCTS
UNIT OF ELECTRO SWITCH CORP.
30
.500 FOR DESIGNS OF FIVE OR
MORE SECTIONS
2010 Yonkers Road
Raleigh, NC 27604
Telephone: (888) ROTARYS or (919) 833-0707
Fax: (800) 909-9171 or (919) 833-8016
ADDITIONAL OPTIONS AND ORDERING INFORMATION
D7 - SERIES
How to Order Additional Options:
2 DIGIT
SERIES
INSULATION
TYPE
TOTAL
POLES
ACTIVE
POSITIONS
D7
G - GLASS
C - CERAMIC
01 - MIN.
12 - MAX @ 30°
06 - MAX @ 60°
CONTACT
TYPE
S - SHORTING
N - NONSHORTING
CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS
D
INDEX
ANGLE
STOP
TYPE
SHAFT/
BUSHING
SHAFT
FLAT
30°
60°
A - ADJ.
F - FIXED
C - CONT.
SEE
CHART
“A”
SEE
CHART
“B”
(SPECIFY) (SPECIFY)
(SPECIFY)
ADDITIONAL OPTIONS
7
(SPECIFY)
(SPECIFY)
(SPECIFY)
(SPECIFY)
(SPECIFY)
SHAFT, BUSHING, AND FLAT OPTIONS
D
SHAFT AS VIEWED
WITH NON-TURN LUG
AT 9 O'CLOCK AND
SHAFT IN EXTREME
CCW POSITION AND
STRUT BOLTS
ORIENTED VERTICALLY.
W
U
Y
Z
INSULATION AND INDEX OPTIONS
D7C - CERAMIC CONSTRUCTION
30° INDEX
D7C - CERAMIC INSULATION
60° INDEX
60
CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS.
2010 Yonkers Road
Raleigh, NC 27604
31
很抱歉,暂时无法提供与“D7C0603N”相匹配的价格&库存,您可以联系我们找货
