A227K12KZG-M8
A227K12KZG-M8
    ELECTROSWITCH
    插件
    钮子开关 双刀双掷 6万次 直插 6A 28V -30℃~+90℃
A227K12KZG-M8 数据手册
MINIATURE SWITCHES Commercial Miniature Toggle Switches • Base (body) — Diallyl Phthalate. • Lever — Brass, bright chrome plated. — Brass, nickel plated. • Bushing Frame — Stainless steel. Contacts and Rockers — 50 • Switching millionths gold over silver. Terminal — 50 millionths gold • Center over silver. — Refer to hardware listing • Hardware on page 57. designed to meet the • Originally requirements of MIL-S-83731 (see • • • • • • • • CURRENT RATINGS MATERIAL SPECIFICATIONS page 54 for Test Specifications). Sealed lever type with panel seal and terminal seal. Flatted bushing on sealed lever type. Solder lug or printed circuit terminals. Epoxy sealed terminals. One and two pole circuits. High electrical/mechanical reliability. Dry circuit current carrying ability. Toggle lever throw 25° ±5°. Current Capacity in Amperes — Per Pole 115 V 125 V 28 V AC AC DC 400 Hz 60 Hz LAMP LOAD 1 1 1 RESISTIVE LOAD 5 5 5 INDUCTIVE LOAD 2 2 2 LOGIC LEVEL 10 mA @ 5 V Max. (AC or DC) SWITCH SELECTION TABLE — SEALED Circuit With Lever UP Position CENTER Position Catalog Number DOWN Position (Flat) Solder Lug Terminals Printed Circuit Terminals ONE POLE ON ON ON ON* ON NONE OFF NONE NONE OFF OFF ON ON ON ON ON* ON ON ON NONE ON* OFF NONE NONE OFF OFF ON ON ON ON ON ON ON* ON* ON* ON* A121S1CWZG-M8 A123S1CWZG-M8 A126S1CWZG-M8 A127S1CWZG-M8 A131S1CWZG-M8 A137S1CWZG-M8 A121S1CWCG-M8 A123S1CWCG-M8 A126S1CWCG-M8 A127S1CWCG-M8 A131S1CWCG-M8 A137S1CWCG-M8 A221S1CWZG-M8 A223S1CWZG-M8 A226S1CWZG-M8 A227S1CWZG-M8 A231S1CWZG-M8 A232S1CWZG-M8 A233S1CWZG-M8 A234S1CWZG-M8 A235S1CWZG-M8 A221S1CWCG-M8 A223S1CWCG-M8 A226S1CWCG-M8 A227S1CWCG-M8 A231S1CWCG-M8 A232S1CWCG-M8 A233S1CWCG-M8 A234S1CWCG-M8 A235S1CWCG-M8 "ON-ON-ON" CIRCUIT DIAGRAM No. of Poles Up Position TWO POLE ON ON ON* ON* ON* ON ON* ON* ON* Center Maintained Position Down Position (Keyway) 2 * Momentary Contact APPROXIMATE DIMENSIONS SINGLE POLE DOUBLE POLE TERMINAL DIMENSIONS SOLDERING TERMINALS PRINTED CIRCUIT TERMINALS SINGLE POLE Litho in U.S.A GG DOUBLE POLE SINGLE POLE DOUBLE POLE 49 MINIATURE SWITCHES Commercial Miniature Leverlock Toggle Switches — Unsealed SPECIFICATIONS • • • • • • • CURRENT RATINGS MATERIAL • One hole mounting. designed to meet the • Originally requirements of MIL-S-83731 (see • Base (body) — Diallyl Phthalate. lever — Brass, nickel plated. • Locking Cap — natural adnodized aluminum page 54 for Test Specifications). Slow make, slow break contact action. High electrical/mechanical reliability. Toggle lever throw 25° ±5°. Solder lug or printed circuit terminals. One and two pole circuits. Dry circuit current carrying ability. Mounting hardware furnished unassembled • • • • Current Capacity in Amperes — Per Pole 115 V 125 V 28 V AC AC DC 400 Hz 60 Hz supplied as standard; other colors such as red, blue, gold, black and green are also available. Bushing — Brass, nickel plated. Frame — Stainless steel. Switching Contacts and Rockers — 50 millionths gold over silver. Center Terminal — 50 millionths gold over silver. Hardware — Refer to hardware listing on page 57. LAMP LOAD 1 1 1 RESISTIVE LOAD 5 5 5 INDUCTIVE LOAD 2 2 2 LOGIC LEVEL 10 mA @ 5 V Max. (AC or DC) LEVER LOCK SELECTION TABLE Circuit With Lever Standard Cap Style UP Position CENTER Position Catalog Number DOWN Position (Keyway) Lever Lock Bushing Style Solder Lug Terminals Printed Circuit Terminals ONE POLE SPDT ON OFF ON 1 A121K12KZG-M8 A121K12KCG-M8 ON NONE ON 2 A123K12KZG-M8 A123K12KCG-M8 ON NONE ON* 3 A126K12KZG-M8 A126K12KCG-M8 ON* OFF ON* 4 A127K12KZG-M8 A127K12KCG-M8 ON OFF ON* 5 A131K12KZG-M8 A131K12KCG-M8 TWO POLE DPDT ON OFF ON 1 A221K12KZG-M8 A221K12KCG-M8 ON NONE ON 2 A223K12KZG-M8 A223K12KCG-M8 ON NONE ON* 3 A226K12KZG-M8 A226K12KCG-M8 ON* OFF ON* 4 A227K12KZG-M8 A227K12KCG-M8 ON OFF ON* 5 A231K12KZG-M8 A231K12KCG-M8 ON ON 1 A232K12KZG-M8 A232K12KCG-M8 ON * Momentary Contact Indicates direction against which lever is locked. APPROXIMATE DIMENSIONS (For terminal dimensions see page 49) SINGLE POLE DOUBLE POLE LEVER LOCK BUSHING STYLES (The descriptive illustrations below are for pictorial representation only — keyway on right hand side) STYLE 1 STYLE 2 STYLE 3 STYLE 4 "ON-ON-ON" CIRCUIT DIAGRAM STYLE 5 No. of Poles Up Position Locked In Three Positions 50 Locked Out Of Center Position Locked Into Side Opposite Keyway — Momentary Keyway Side Locked In Center Position — Momentary Either Side Locked In Center Position — Momentary Keyway Side Center Maintained Position Down Position (Keyway) 2 Litho in U.S.A GG MINIATURE SWITCHES Commercial Miniature Toggle Switches Right Angle Mount (Vertical) P.C. Terminals designed to meet the • Originally requirements of MIL-S-83731 (see • • • • • • • CURRENT RATINGS MATERIAL SPECIFICATIONS page 54 for Test Specifications). Sealed lever type with panel seal and terminal seal. Right angle mount (vertical) printed circuit terminals. Epoxy sealed printed circuit terminals. One and two pole circuits. High electrical/mechanical reliability. Dry circuit current carrying ability. Toggle lever throw 25° ±5°. • Base (body) — Diallyl Phthalate. • Lever — Brass, bright chrome plated. — Brass, nickel plated. • Bushing Frame — Stainless steel. Contacts and Rockers — 50 • Switching millionths gold over silver. Terminal — 50 millionths gold • Center over silver. • Hardware — None required. Current Capacity in Amperes — Per Pole 115 V 125 V 28 V AC AC DC 400 Hz 60 Hz LAMP LOAD 1 1 1 RESISTIVE LOAD 5 5 5 INDUCTIVE LOAD 2 2 2 LOGIC LEVEL 10 mA @ 5 V Max. (AC or DC) SWITCH SELECTION TABLE — SEALED Circuit With Lever In… UP Position CENTER Position ON ON ON ON* ON NONE OFF NONE NONE OFF OFF ON ON ON ON ON* ON ON ON NONE ON* OFF NONE NONE OFF OFF ON ON ON ON DOWN Position (Position C) Catalog Number ONE POLE SPDT ON ON ON* ON* ON* ON* A121M1D9AVG-M8 A123M1D9AVG-M8 A126M1D9AVG-M8 A127M1D9AVG-M8 A131M1D9AVG-M8 A134M1D9AVG-M8 TWO POLE DPDT ON ON ON* ON* ON* ON ON* ON* ON* A221M1D9AVG-M8 A223M1D9AVG-M8 A226M1D9AVG-M8 A227M1D9AVG-M8 A231M1D9AVG-M8 A232M1D9AVG-M8 A233M1D9AVG-M8 A234M1D9AVG-M8 A235M1D9AVG-M8 * Momentary Contact APPROXIMATE DIMENSIONS TERMINAL DIMENSIONS Right Angle P.C. Terminal EPOXY SEAL .031 MAX. TYP. x.050 WIDE SPDT "ON-ON-ON" CIRCUIT DIAGRAM No. of Poles Up Position DPDT Litho in U.S.A GG Center Down Maintained Position Position (Position C) 2 51 MINIATURE SWITCHES Commercial Miniature Toggle Switches Right Angle Mount (Horizontal) P.C. Terminals designed to meet the • Originally requirements of MIL-S-83731 (see • • • • • • • CURRENT RATINGS MATERIAL SPECIFICATIONS page 54 for Test Specifications). Sealed lever type with terminal seal. Right angle mount (horizontal) printed circuit terminals. Epoxy sealed printed circuit terminals. One and two pole circuits. High electrical/mechanical reliability. Dry circuit current carrying ability. Toggle lever throw 25° ±5°. • Base (body) — Diallyl Phthalate. • Lever — Brass, bright chrome plated. — Brass, nickel plated. • Bushing Frame — Stainless steel. Contacts and Rockers — 50 • Switching millionths gold over silver. Terminal — 50 millionths gold • Center over silver. • Hardware — None required. Current Capacity in Amperes — Per Pole 115 V 125 V 28 V AC AC DC 400 Hz 60 Hz LAMP LOAD 1 1 1 RESISTIVE LOAD 5 5 5 INDUCTIVE LOAD 2 2 2 LOGIC LEVEL 10 mA @ 5 V Max. (AC or DC) SWITCH SELECTION TABLE — SEALED Circuit With Lever In… UP Position CENTER Position ON ON ON ON* ON NONE OFF NONE NONE OFF OFF ON ON ON ON ON* ON ON ON NONE ON* OFF NONE NONE OFF OFF ON ON ON ON DOWN Position (Position C) Catalog Number ONE POLE SPDT ON ON ON* ON* ON* ON* A121M1D9AG-M8 A123M1D9AG-M8 A126M1D9AG-M8 A127M1D9AG-M8 A131M1D9AG-M8 A134M1D9AG-M8 TWO POLE DPDT ON ON ON* ON* ON* ON ON* ON* ON* A221M1D9AG-M8 A223M1D9AG-M8 A226M1D9AG-M8 A227M1D9AG-M8 A231M1D9AG-M8 A232M1D9AG-M8 A233M1D9AG-M8 A234M1D9AG-M8 A235M1D9AG-M8 * Momentary Contact APPROXIMATE DIMENSIONS TERMINAL DIMENSIONS Right Angle P.C. Terminal SPDT "ON-ON-ON" CIRCUIT DIAGRAM No. of Poles Up Position DPDT 52 Center Down Maintained Position Position (Position C) 2 Litho in U.S.A GG MINIATURE SWITCHES Commercial Miniature Toggle Switches – New Four Pole • Base (body) — Diallyl Phthalate. • Lever — Brass, bright chrome plated. Lever — Brass, nickel plated. • Locking Cap — natural anodized aluminum designed to meet the • Originally requirements of MIL-S-83731 (see • • • • • • • • CURRENT RATINGS MATERIAL SPECIFICATIONS page 54 for Test Specifications). Sealed lever type with panel seal and terminal seal. Flatted bushing on sealed lever type. Solder lug or printed circuit terminals. Epoxy sealed terminals. One and two pole circuits. High electrical/mechanical reliability. Dry circuit current carrying ability. Toggle lever throw 25° ±5°. supplied as standard; other colors such as red, blue, gold, black and green are also available. Bushing — Brass, nickel plated. Frame — Stainless steel. Switching Contacts and Rockers — 50 millionths gold over silver. Center Terminal — 50 millionths gold over silver. Hardware — Refer to hardware listing on page 57. • • • • SWITCH SELECTION TABLE — SEALED Circuit With Lever In… UP Position 4-PDT ON ON ON ON* ON ON ON NONE ON* CENTER Position OFF NONE NONE OFF OFF ON ON ON ON ON ON ON* ON* ON* ON ON* ON* ON* LAMP LOAD 1 1 1 RESISTIVE LOAD 5 5 5 INDUCTIVE LOAD 2 2 2 LOGIC LEVEL 10 mA @ 5 V Max. (AC or DC) APPROXIMATE DIMENSIONS Catalog Number DOWN Position (Flat) Current Capacity in Amperes — Per Pole 115 V 125 V 28 V AC AC DC 400 Hz 60 Hz Solder Lug Terminals Printed Circuit Terminals A421S1CWZG-M8 A423S1CWZG-M8 A426S1CWZG-M8 A427S1CWZG-M8 A431S1CWZG-M8 A432S1CWZG-M8 A433S1CWZG-M8 A434S1CWZG-M8 A435S1CWZG-M8 A421S1CWCG-M8 A423S1CWCG-M8 A426S1CWCG-M8 A427S1CWCG-M8 A431S1CWCG-M8 A432S1CWCG-M8 A433S1CWCG-M8 A434S1CWCG-M8 A435S1CWCG-M8 (For terminal dimensions see page 49) * Momentary Contact LEVER LOCK SELECTION TABLE — UNSEALED Circuit With Lever In… Standard Cap Style UP Position ON ON ON ON* ON ON Catalog Number CENTER Position DOWN Position (Keyway) Lever Lock Bushing Style OFF NONE NONE OFF OFF ON ON ON ON* ON* ON* ON 1 2 3 4 5 1 Solder Lug Terminals A421K12KZG-M8 A423K12KZG-M8 A426K12KZG-M8 A427K12KZG-M8 A431K12KZG-M8 A432K12KZG-M8 Printed Circuit Terminals A421K12KCG-M8 A423K12KCG-M8 A426K12KCG-M8 A427K12KCG-M8 A431K12KCG-M8 A432K12KCG-M8 FOUR POLE "ON-ON-ON" CIRCUIT DIAGRAM * Momentary Contact Indicates direction against which lever is locked. APPROXIMATE DIMENSIONS (For terminal dimensions see page 49) No. of Poles Up Position Center Maintained Position Down Position (Keyway) 4 NOTE: FOR LEVER LOCK BUSHING STYLES SEE PAGE 50. Litho in U.S.A GG 53 MINIATURE SWITCHES Rating, Cross Reference and Engineering Data “A” Series Originally Designed To Meet the Following MIL Specifications MIL Specification Test Requirement 1. Strength of Terminal 1 lb. — solder lug 2. Strength of Actuating Lever Pivot and Stop 10 lbs. & 8 lbs. throughout range 3. Strength of Mounting Means 15 lbs. in. torque on bushing 4. Dielectric (Sea Level) Indication Dielectric (Altitude) 1000 VAC Group C 750 VAC after electrical endurance. 500 µA max. leakage 5. Contact Voltage Drop 2.5 millivolt initial 5.0 millivolt after mechanical endurance @ 2-6 VDC 0.1 amp. 6. Temperature Rise 50°C rise @ rated resistance after endurance test current 7. Short Circuit 10 operations make and carry 100 amps resistive load @ lowest DC volts 8. Mechanical Life 20K operations at specified high and low temperatures 9. Electrical Endurance 10K operations at specified high and low temperatures 10. Overload 50 operations @ 150% of rated resistive load 11. A) Electrical Endurance at Altitude No requirement B) Electrical Endurance at Sea Level 54 10K operations resistive load @ room temperature 10K operations inductive load @ room temperature 10K operations lamp load @ room temperature Performed on different test samples 12. Vibration Method 204 of MIL-STD-202, test condition A .06 D.A. or 10 G’s 10-500 Hz 10 usec. max. chatter 13. Shock Fuse-method 213 or MIL-STD @75 G’s 10 usec. max, chatter 14. Salt Spray Test Upon Completion 48 hours — method 101 of MIL-STD-202, test condition B 10 operations resistive load (toggle sealed switches only) 15. Moisture Resistance Test Upon Completion Method 106 of MIL-STD-202 100 VDC potential between current carrying parts and panel 16. Sand & Dust Method 110 of MIL-STD-202, test condition B 6 hours @ 23°C 2.5K operations mechanical life (toggle sealed switches only) 17. Explosion MIL-STD-202 method 109, maximum rated DC inductive load (toggle sealed switches only) 18. Sealing Toggle seal — 5 operations under 0.5 inches of H2O above top of bushing 19. A) Toggle Seal B) Bushing Seal No requirement 20. Temperature Operation Mechanical life, -25°C to +71°C 21. Life Low Cur. Level No requirement 22. Fungus No requirement 23. Intermediate Current 10K operations, 50 milliamps @ 10 VDC resistive load @ 20,000 feet altitude @ room temperature 24. Thermal Shock Method 107 of MIL-STD-202 test condition A 5 cycles @ -55°C/+85°C Litho in U.S.A GG
A227K12KZG-M8 价格&库存
很抱歉,暂时无法提供与“A227K12KZG-M8”相匹配的价格&库存,您可以联系我们找货
