D6 - SERIES
SPECIFICATIONS AND ORDERING INFORMATION
1.687" DIAMETER 1.5 AMPS @ 28 VDC
The D6 Series is one of our more versatile rotary switches. A 30° index
angle, solder lug terminals, and diallyl phthalate insulation are
standard. However, additional indexes of 36°, 45°, and 60° and insulation
sections of glass epoxy and ceramic are available. Adjustable stops are
available on indexes of 30° and 60°.
SPECIFICATIONS
D
ELECTRICAL
MECHANICAL
Current and Voltage Rating: Make and break resistive load
1.5 amps @ 28 VDC; 0.5 amp @ 115 VAC.
Current Carrying Capacity: 9 amps.
Dielectric Strength: 1,500 VAC between current carrying parts and
ground.
Contact Resistance: Average initial 3.5 milliohms.
Insulation Resistance: Diallyl in excess of 900,000 megohms
Glass in excess of 750,000 megohms.
Ceramic in excess of 1,000,000 megohms.
Hardware: Mounting nut and lockwasher are shipped assembled.
Materials and Finishes: All parts utilize non-corrosive materials
as standard.
Clips and Rotors: Brass with silver plate as standard.
Insulation: Diallyl phthalate, glass, or ceramic.
Index: Dual-ball, side thrust design.
Index Life: 25,000 cycles minimum.
Index Torque: Switches have lowest practical torque consistent
with crisp detenting and smooth, reliable operation.
Index Angles: Positive 30° standard, 36°, 45°, and 60° available.
Index Stops: Adjustable standard, fixed or continuous.
Stop Strength: 25 in. lbs. minimum.
STANDARD PART NUMBER
DIALLYL PHTHALATE INSULATION
SWITCHES - 30° INDEX - ADJUSTABLE STOPS - SOLDER LUG TERMINALS
ACTIVE
POLES/
NO. OF
POLES POSITIONS SECTION SECTIONS
01
02
02
03
03
04
04
05
02-12
02-12
02-06
02-12
02-05
02-12
02-06
02-12
1
1
2
1
3
1
2
1
1
2
1
3
1
4
2
5
SHORTING
NONSHORTING
FIG.
D6D0112S
D6D0212S
D6D0206S
D6D0312S
D6D0305S
D6D0412S
D6D0406S
D6D0512S
D6D0112N
D6D0212N
D6D0206N
D6D0312N
D6D0305N
D6D0412N
D6D0406N
D6D0512N
DD
DD
DL
DD
DO
DD
DL
DD
ACTIVE
POLES/
NO. OF
05
06
06
06
08
09
10
10
02-03
02-12
02-06
02-05
02-06
02-05
02-03
02-06
5
1
2
3
2
3
5
2
1
6
3
2
4
3
2
5
SHORTING
NONSHORTING
FIG.
D6D0503S
D6D0612S
D6D0606S
D6D0605S
D6D0806S
D6D0905S
D6D1003S
D6D1006S
D6D0503N
D6D0612N
D6D0606N
D6D0605N
D6D0806N
D6D0905N
D6D1003N
D6D1006N
DR
DD
DL
DO
DL
DO
DR
DL
* FIGURES ARE SHOWN ON PAGES 55 AND 56.
DIMENSIONS
STANDARD CONSTRUCTION
D6D - DIALLYL PHTHALATE CONSTRUCTION
.4 3 7
• ELECTRONIC PRODUCTS
UNIT OF ELECTRO SWITCH CORP.
28
2010 Yonkers Road
Raleigh, NC 27604
Telephone: (888) ROTARYS or (919) 833-0707
Fax: (800) 909-9171 or (919) 833-8016
ADDITIONAL OPTIONS AND ORDERING INFORMATION
D6 - SERIES
How to Order Additional Options:
2 DIGIT
SERIES
INSULATION
TYPE
TOTAL
POLES
ACTIVE
POSITIONS
D6
D - DIALLYL
01 - MIN.
12 - MAX @ 30°
10 - MAX @ 36°
08 - MAX @ 45°
06 - MAX @ 60°
S - SHORTING
N - NON
SHORTING
12 - MAX @ 30°
06 - MAX @ 60°
S - SHORTING
N - NON
SHORTING
(30°,45°,60°)
G - GLASS
(30°,36°,45°,60°)
D6
C - CERAMIC
01 - MIN.
(30°,60°)
CONTACT
TYPE
TERMINAL
TYPE
L - SOLDER LUG
R - REAR P.C.
(NO 36°)
L - SOLDER LUG
CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS
D
INDEX
ANGLE
30°
36°
45°
60°
STOP
TYPE
SHAFT/
BUSHING
SHAFT
FLAT
SEE
CHART
“A”
SEE
CHART
“B”
(SPECIFY) (SPECIFY)
(SPECIFY)
A - ADJ.
(30°,60° ONLY)
F - FIXED
C - CONT.
30°
60°
A - ADJ.
F - FIXED
C - CONT.
ADDITIONAL OPTIONS
6
(SPECIFY)
PRINTED BOARD
MOUNTING PATTERN
(SPECIFY)
(SPECIFY)
(SPECIFY)
(SPECIFY)
SHAFT, BUSHING, AND FLAT OPTIONS
D
SHAFT AS VIEWED
WITH NON-TURN LUG
AT 9 O'CLOCK AND
SHAFT IN EXTREME
CCW POSITION AND
STRUT BOLTS
ORIENTED VERTICALLY.
W
U
Y
Z
INSULATION OPTIONS
D6G - GLASS EPOXY INSULATION
R
REAR P.C.
D6C - CERAMIC CONSTRUCTION
CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS.
2010 Yonkers Road
Raleigh, NC 27604
29
很抱歉,暂时无法提供与“D6D0406S”相匹配的价格&库存,您可以联系我们找货
