D7C0603S
D7C0603S
    ELECTROSWITCH
    旋转开关 28VDC 115VAC
D7C0603S 数据手册
D7 - SERIES SPECIFICATIONS AND ORDERING INFORMATION 1 7/8" DIAMETER 2.25 AMPS @ 28 VDC The D7 Series, constructed with a dual-ball, hill and valley index, has increased the physical size of the switch conductors allowing for additional current carrying capabilities. Standard designs utilize glass epoxy or ceramic insulations, solder lug terminals, and 30° adjustable stop indexing. SPECIFICATIONS ELECTRICAL MECHANICAL Current and Voltage Rating: Make and break resistive load 2.25 amps @ 28 VDC; 1.0 amp @ 115 VAC. Current Carrying Capacity: 9 amps. Dielectric Strength: 1,500 VAC between current carrying parts and ground. Contact Resistance: Average initial 3 milliohms. Insulation Resistance: Glass in excess of 750,000 megohms. Ceramic in excess of 1,000,000 megohms. Materials and Finishes: All parts utilize non-corrosive materials as standard. Clips and Rotors: Brass with silver plate as standard. Insulation: Glass epoxy, or ceramic. Index: Dual-ball, hill and valley design. Index Life: 25,000 cycles minimum. Index Torque: Switches have lowest practical torque consistent with crisp detenting and smooth, reliable operation. Index Angles: Positive 30° standard, 60° available. Index Stops: Adjustable standard, fixed or continuous. Stop Strength: 25 in. lbs. minimum. Hardware: Mounting nut and lockwasher are shipped assembled. STANDARD PART NUMBER D GLASS EPOXY INSULATION CERAMIC INSULATION SWITCHES - 30° INDEXING ADJUSTABLE STOPS - SOLDER LUG TERMINALS - STOPS SET @ 2 POS. ACTIVE POLES/ NO. OF POLES POSITIONS SECTION SECTIONS 01 02 02 03 03 04 04 05 06 06 06 08 09 10 02-11 02-11 02-05 02-11 02-03 02-11 02-05 02-11 02-05 02-03 02-11 02-05 02-03 02-05 1 1 2 1 3 1 2 1 2 3 1 2 3 2 1 2 1 3 1 4 2 5 3 2 6 4 3 5 SWITCHES - 30° INDEXING ADJUSTABLE STOPS - SOLDER LUG TERMINALS - STOPS SET @ 2 POS. SHORTING NONSHORTING FIG. D7G0111S D7G0211S D7G0205S D7G0311S D7G0303S D7G0411S D7G0405S D7G0511S D7G0605S D7G0603S D7G0611S D7G0805S D7G0903S D7G1005S D7G0111N D7G0211N D7G0205N D7G0311N D7G0303N D7G0411N D7G0405N D7G0511N D7G0605N D7G0603N D7G0611N D7G0805N D7G0903N D7G1005N DA DA DH DA DM DA DH DA DH DM DA DH DM DH * ACTIVE POLES/ NO. OF POLES POSITIONS SECTION SECTIONS 01 02 02 03 03 04 06 06 02-11 02-11 02-05 02-11 02-03 02-05 02-05 02-03 1 1 2 1 3 2 2 3 01 02 03 04 05 02-06 02-06 02-06 02-06 02-06 1 1 1 1 1 1 2 1 3 1 2 3 2 60° INDEXING 1 2 3 4 5 SHORTING NONSHORTING FIG. D7C0111S D7C0211S D7C0205S D7C0311S D7C0303S D7C0405S D7C0605S D7C0603S D7C0111N D7C0211N D7C0205N D7C0311N D7C0303N D7C0405N D7C0605N D7C0603N DA DA DH DA DM DH DH DM ________ ________ ________ ________ ________ D7C0106N-60 D7C0206N-60 D7C0306N-60 D7C0406N-60 D7C0506N-60 DK DK DK DK DK * * FIGURES ARE SHOWN ON PAGES 55 AND 56. DIMENSIONS STANDARD CONSTRUCTION D7G - GLASS EPOXY CONSTRUCTION * • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 30 .500 FOR DESIGNS OF FIVE OR MORE SECTIONS 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 ADDITIONAL OPTIONS AND ORDERING INFORMATION D7 - SERIES How to Order Additional Options: 2 DIGIT SERIES INSULATION TYPE TOTAL POLES ACTIVE POSITIONS D7 G - GLASS C - CERAMIC 01 - MIN. 12 - MAX @ 30° 06 - MAX @ 60° CONTACT TYPE S - SHORTING N - NONSHORTING CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS D INDEX ANGLE STOP TYPE SHAFT/ BUSHING SHAFT FLAT 30° 60° A - ADJ. F - FIXED C - CONT. SEE CHART “A” SEE CHART “B” (SPECIFY) (SPECIFY) (SPECIFY) ADDITIONAL OPTIONS 7 (SPECIFY) (SPECIFY) (SPECIFY) (SPECIFY) (SPECIFY) SHAFT, BUSHING, AND FLAT OPTIONS D SHAFT AS VIEWED WITH NON-TURN LUG AT 9 O'CLOCK AND SHAFT IN EXTREME CCW POSITION AND STRUT BOLTS ORIENTED VERTICALLY. W U Y Z INSULATION AND INDEX OPTIONS D7C - CERAMIC CONSTRUCTION 30° INDEX D7C - CERAMIC INSULATION 60° INDEX 60 CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS. • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 31
D7C0603S 价格&库存
很抱歉,暂时无法提供与“D7C0603S”相匹配的价格&库存,您可以联系我们找货
