2015-104
2015-104
    BERGQUIST
    BERGQUIST - 2015-104 - Thermal Insulator, Thermal Pad, TO-3P, Pack5, Silicone Elastomer, 3.5 W/m.K, ...
2015-104 数据手册
Sil-Pad 2000 ® Higher Performance, High Reliability Insulator Features and Benefits TYPICAL PROPERTIES OF SIL-PAD 2000 PROPERTY Color • Thermal impedance: 0.33°C-in2/W (@50 psi) • Optimal heat transfer • High thermal conductivity: 3.5 W/m-K IMPERIAL VALUE White TEST METHOD Visual Reinforcement Carrier Fiberglass Fiberglass — Thickness (inch) / (mm) 0.010 to 0.020 0.254 to 0.508 ASTM D374 Hardness (Shore A) Continuous Use Temp (°F) / (°C) 90 90 ASTM D2240 -76 to 392 -60 to 200 — ELECTRICAL Dielectric Breakdown Voltage (Vac) 4000 4000 ASTM D149 Dielectric Constant (1000 Hz) 4.0 4.0 ASTM D150 Volume Resistivity (Ohm-meter) 1011 1011 ASTM D257 Flame Rating V-O V-O U.L.94 THERMAL Thermal Conductivity (W/m-K) 3.5 3.5 ASTM D5470 THERMAL PERFORMANCE vs PRESSURE Pressure (psi) Sil-Pad 2000 is a high performance, thermally conductive insulator designed for demanding military/aerospace and commercial applications. In these applications, Sil-Pad 2000 complies with military standards. METRIC VALUE White 10 25 50 100 200 TO-220 Thermal Performance (°C/W) 2.61 2.32 2.02 1.65 1.37 Thermal Impedance (°C-in2/W) (1) 0.57 0.43 0.33 0.25 0.20 1) The ASTM D5470 test fixture was used.The recorded value includes interfacial thermal resistance.These values are provided for reference only. Actual application performance is directly related to the surface roughness, flatness and pressure applied. Typical Applications Include: Sil-Pad 2000 is a silicone elastomer formulated to maximize the thermal and dielectric performance of the filler/binder matrix.The result is a grease-free, conformable material capable of meeting or exceeding the thermal and electrical requirements of high-reliability electronic packaging applications. • Power supplies • Power semiconductors • Military Electronics • Avionics • Motor controls • U.L. File Number E59150 • Aerospace Configurations Available: • Sheet form, die-cut parts • With or without pressure sensitive adhesive Building a Part Number 00 – Standard Options NA Section E – AC – Section D 0.010 Section C – Section B Section A SP2000 NA = Selected standard option. If not selecting a standard option, insert company name, drawing number, and revision level. _ _ _ = Standard configuration dash number, 1212 = 12" x 12" sheets, or 00 = custom configuration AC = Adhesive, one side 00 = No adhesive Standard thicknesses available: 0.010", 0.015", 0.020" SP2000 = Sil-Pad 2000 Material Note: To build a part number, visit our website at www.bergquistcompany.com. Sil-Pad ®: U.S. Patents 4,574,879; 4,602,125; 4,602,678; 4,685,987; 4,842,911 and others www.bergquistcompany.com The Bergquist Company North American Headquarters 18930 West 78th Street Chanhassen, MN 55317 Phone: 800-347-4572 Fax: 952-835-0430 The Bergquist Company European Headquarters Bramenberg 9a, 3755 BT Eemnes Netherlands Phone: 31-35-5380684 Fax: 31-35-5380295 The Bergquist Company - Asia Room 15, 8/F Wah Wai Industrial Centre No. 38-40, Au Pui Wan Street Fotan, Shatin, N.T. Hong Kong Ph: 852.2690.9296 Fax: 852.2690.2344 All statements, technical information and recommendations herein are based on tests we believe to be reliable, and THE FOLLOWING IS MADE IN LIEU OF ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING THE IMPLIED WARRANTIES OF MARKETABILITY AND FITNESS FOR PURPOSE. Sellers’ and manufacturers’ only obligation shall be to replace such quantity of the product proved to be defective. Before using, user shall determine the suitability of the product for its intended use, and the user assumes all risks and liability whatsoever in connection therewith. NEITHER SELLER NOR MANUFACTURER SHALL BE LIABLE EITHER IN TORT OR IN CONTRACT FOR ANY LOSS OR DAMAGE, DIRECT, INCIDENTAL, OR CONSEQUENTIAL, INCLUDING LOSS OF PROFITS OR REVENUE ARISING OUT OF THE USE OR THE INABILITY TO USE A PRODUCT. No statement, purchase order or recommendations by seller or purchaser not contained herein shall have any force or effect unless in an agreement signed by the officers of the seller and manufacturer. PDS_SP_SP2000_12.08
2015-104 价格&库存
很抱歉,暂时无法提供与“2015-104”相匹配的价格&库存,您可以联系我们找货
