GP2000S40-0.080-02-4/4 数据手册
Gap Pad 2000S40
Highly Conformable,Thermally Conductive, Reinforced “S-Class” Gap Filling Material
Features and Benefits
TYPICAL PROPERTIES OF GAP PAD 2000S40
PROPERTY
Color
• Thermal conductivity: 2.0 W/m-K
• Low “S-Class” thermal resistance at very
low pressures
• Highly conformable, low hardness
• Designed for low-stress applications
• Fiberglass reinforced for puncture, shear
and tear resistance
IMPERIAL VALUE
Gray
METRIC VALUE
Gray
TEST METHOD
Visual
Reinforcement Carrier
Fiberglass
Fiberglass
Thickness (inch) / (mm)
0.020 to 0.125
0.508 to 3.175
ASTM D374
Inherent Surface Tack (1- or 2-sided)
2
2
Density (g/cc)
2.9
2.9
ASTM D792
Heat Capacity (J/g-K)
0.6
0.6
ASTM E1269
Hardness, Bulk Rubber (Shore 00) (1)
30
30
ASTM D2240
Young’s Modulus (psi) / (kPa) (2)
45
310
ASTM D575
Continuous Use Temp (°F) / (°C)
-76 to 392
-60 to 200
ELECTRICAL
Dielectric Breakdown Voltage (Vac)
>5000
>5000
ASTM D149
Dielectric Constant (1000 Hz)
6.0
6.0
ASTM D150
Volume Resistivity (Ohm-meter)
1011
1011
ASTM D257
Flame Rating
V-O
V-O
U.L. 94
THERMAL
Thermal Conductivity (W/m-K)
2.0
2.0
ASTM D5470
1) Thirty second delay value Shore 00 hardness scale.
2) Young's Modulus, calculated using 0.01 in/min. step rate of strain with a sample size of 0.79 inch2. For more information on Gap Pad
modulus, refer to Bergquist Application Note #116.
Gap Pad 2000S40 is recommended for lowstress applications that require a mid to high
thermally conductive interface material.The
highly conformable nature of the material
allows the pad to fill in air voids and air gaps
between PC boards and heat sinks or metal
chassis with stepped topography, rough
surfaces and high stack-up tolerances.
Typical Applications Include:
• Power electronics DC/DC; 1/4, 1/2, full bricks, etc.
• Mass storage devices
• Graphics card/processor/ASIC
• Wireline/wireless communications hardware
• Automotive engine/transmission controls
Gap Pad 2000S40 is offered with inherent
natural tack on both sides of the material
allowing for stick-in-place characteristics during
application assembly.The material is supplied
with protective liners on both sides.The top
side has reduced tack for ease of handling.
Configurations Available:
• Sheet form and die-cut parts
Building a Part Number
Resultant Thickness (mils)
125
NA
NA = Selected standard option. If not selecting a standard
option, insert company name, drawing number, and
revision level.
0816 = Standard sheet size 8" x 16", or
00 = custom configuration
02 = Natural tack, both sides
100
Standard thicknesses available: 0.020", 0.040", 0.060",
0.080", 0.100", 0.125"
75
50
GP2000S40 = Gap Pad 2000S40 Material
25
– 0816 –
Section E
– 02
Section D
0.020
Section C
Section A
Thickness vs. Thermal Resistance
Gap Pad 2000S40
Section B
GP2000S40
Note: Resultant thickness is defined as the final gap
thickness of the application.
Standard Options
Note: To build a part number, visit our website at www.bergquistcompany.com.
0.50
1.00
1.50
2.00
Thermal Resistance (C-in2/W)
2.50
Gap Pad ®: U.S. Patent 5,679,457 and others
The Bergquist Company North American Headquarters
18930 West 78th Street
Chanhassen, MN 55317
Phone: 800-347-4572
Fax: 952-835-0430
The Bergquist Company European Headquarters
Bramenberg 9a, 3755 BT Eemnes
Netherlands
Phone: 31-35-5380684
Fax: 31-35-5380295
The Bergquist Company - Asia
Room 15, 8/F Wah Wai Industrial Centre
No. 38-40, Au Pui Wan Street
Fotan, Shatin, N.T. Hong Kong
Ph: 852.2690.9296
Fax: 852.2690.2344
All statements, technical information and recommendations herein are based on tests we believe to be reliable, and
THE FOLLOWING IS MADE IN LIEU OF ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING THE IMPLIED
WARRANTIES OF MARKETABILITY AND FITNESS FOR PURPOSE. Sellers’ and manufacturers’ only obligation shall be to
replace such quantity of the product proved to be defective. Before using, user shall determine the suitability of the product
for its intended use, and the user assumes all risks and liability whatsoever in connection therewith. NEITHER SELLER NOR
MANUFACTURER SHALL BE LIABLE EITHER IN TORT OR IN CONTRACT FOR ANY LOSS OR DAMAGE, DIRECT,
INCIDENTAL, OR CONSEQUENTIAL, INCLUDING LOSS OF PROFITS OR REVENUE ARISING OUT OF THE USE OR
THE INABILITY TO USE A PRODUCT. No statement, purchase order or recommendations by seller or purchaser not
contained herein shall have any force or effect unless in an agreement signed by the officers of the seller and manufacturer.
PDS_GP_2000S40_12.08
GP2000S40-0.080-02-4/4 价格&库存
很抱歉,暂时无法提供与“GP2000S40-0.080-02-4/4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+228.80466
- 5+224.52140
- 10+220.22627
- 20+215.93114
- 50+211.63601
