SIL-PAD 400®
The Original Fiberglass Based Sil-Pad
SIL-PAD 400
Sil-Pad 400 is the original Sil-Pad material. Sil-Pad 400
is a composite of silicone rubber and fiberglass. It is flame
retardant and is specially formulated for use as a thermally
conductive insulator. Primary use is to electrically isolate
power sources from heat sinks.
Sil-Pad 400 has excellent mechanical and physical
characteristics. Surfaces are pliable and allow complete
surface contact with excellent heat dissipation. Sil-Pad 400
actually improves its thermal resistance with age. The
reinforcing fiberglass gives excellent cut-through resistance
and Sil-Pad 400 is non-toxic and resists damage from
cleaning agents.
SIL-PAD 600
Special Thicknesses, Rolls and Sheets
Sil-Pad 600 is a silicone elastomer filled with special
ingredients to provide higher thermal performance. This
material has similar physical characteristics of the Sil-Pad
400 material with enhanced thermal performance.
Physical Properties
Color
Thickness Inches
(mm)
Breaking Strength Lbs/inch (kN/m)
Elongation, % 45° to warp and fill
Hardness, Shore A
Tensile Strength, kPsi (MPa)
Continuous Use Temp., °C
Specific Gravity
Construction
Thermal Vacuum Weight Loss
% (TML) as manufactured
Post Cure 24 Hrs. 400 °F
Volatile Condensable Material
% (CVCM) as manufactured
Post Cure 24 Hrs. 400°F
Sil-Pad 400 can be supplied on special order in a variety
of thicknesses from .007 to .045 inches to fulfill special
requirements of insulation path minimums or other spacing
needs. Sil-Pad 400 and 600 are available in die-cut parts,
sheets (6" x 6" min., 6" x 12", 8" x 8", 10" x 10" and 12" x
12") and roll form.
Sil-Pad 400, .007 in.
Gray
.007 ± .001"
0.178 ±0.025
100 (18)
40
85
Sil-Pad 400, .009 in
Gray
.009 ± .001"
.229 ± .025
100 (18)
40
85
Sil-Pad 600
Green
.009 ± .001"
.229 ± .025
100 (18)
40
85
Test Method
-60 to +180
2.0
Silicone/Fiberglass
3 (20)
-60 to +180
2.0
Silicone/ Fiberglass
3 (20)
-60 to +180
1.8
.40
.25
.40
.25
NASA
SP-R-0022A
.11
.07
.11
.07
NASA
Thermal Properties
Thermal Resistance, °C-in2/W
Thermal Conductivity, W/m-K
0.45
0.9
0.50
0.9
Sil-Pad 600
0.35
1.0
Test Method
ASTM D 5470
ASTM D 5470
Electrical Properties
Breakdown Voltage, Volts a-c Min.
Dielectric Constant, 1000 Cps (Hz)
Volume Resistivity, Ohm Metre
3500
5.5
1.0 x 1011
4500
5.5
1.0 x 1011
Sil-Pad 600
4500
5.0
1.0 x 1011
Test Method
ASTM D 149
ASTM D 150
ASTM D 257
ASTM D 374
ASTM D 1458
ASTM D 412
ASTM D 2240
ASTM D 412
ASTM D 792
SP-R-0022A
25
很抱歉,暂时无法提供与“3223-07FR-43”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+6.88170
- 50+6.35964
- 100+5.95623
- 250+5.62401
