BP100-0.005-00-12/12
    BERGQUIST
    BERGQUIST - BP100-0.005-00-12/12 - Thermal Adhesive Tape, Bond-Ply® 100, 0.8 W/m.K, 0.005 "
BP100-0.005-00-12/12 数据手册
Bond-Ply 100 ® Thermally Conductive, Fiberglass Reinforced Pressure Sensitive Adhesive Tape Features and Benefits Fiberglass Fiberglass — 0.005, 0.008, 0.011 0.127, 0.203, 0.279 ASTM D374 Temp. Resistance, 30 sec. (°F) / (°C) 392 200 — Elongation (%45° to Warp & Fill) 70 70 ASTM D412 Tensile Strength (psi) / (MPa) 900 6 ASTM D412 CTE (ppm) 325 325 ASTM D3386 Glass Transition (°F) / (°C) -22 -30 ASTM 1356 -22 to 248 -30 to 120 — ADHESION Lap Shear @ RT (psi) / (MPa) 100 0.7 ASTM D1002 Lap Shear after 5 hr @ 100°C 200 1.4 ASTM D1002 Lap Shear after 2 min @ 200°C 200 1.4 ASTM D1002 Static Dead Weight Shear (°F) / (°C) 302 150 PSTC#7 ELECTRICAL Dielectric Breakdown Voltage - 0.005" (Vac) VALUE 3000 TEST METHOD ASTM D149 Dielectric Breakdown Voltage - 0.008" (Vac) 6000 ASTM D149 Dielectric Breakdown Voltage - 0.011" (Vac) 8500 ASTM D149 Flame Rating V-O U.L.94 THERMAL Thermal Conductivity (W/m-K) 0.8 ASTM D5470 Continuous Use Temp (°F) / (°C) THERMAL PERFORMANCE vs PRESSURE Pressure (psi) 10 25 50 100 200 TO-220 Thermal Performance (°C/W) 0.005" 4.39 4.02 3.48 3.15 3.05 TO-220 Thermal Performance (°C/W) 0.008" 5.11 4.69 4.53 4.45 4.38 TO-220 Thermal Performance (°C/W) 0.011" 6.26 5.92 5.73 5.63 5.53 Thermal Impedance (°C-in2/W) 0.005" (1) 0.78 0.61 0.58 0.55 0.54 Thermal Impedance (°C-in2/W) 0.008" (1) 1.28 0.94 0.90 0.86 0.84 Thermal Impedance (°C-in2/W) 0.011" (1) 2.47 1.22 1.19 1.14 1.11 Configurations Available: Building a Part Number BP100 – 0.008 The Bergquist Company - Europe Bramenberg 9a, 3755 BT Eemnes Netherlands Phone: 31-35-5380684 Fax: 31-35-5380295 – 1112 – Standard Options NA NA = Selected standard option. If not selecting a standard option, insert company name, drawing number, and revision level. 11/250 = 11" x 250' rolls, or 00 = custom configuration 00 = No adhesive Standard thicknesses available: 0.005", 0.008", 0.011" BP100 = Bond-Ply 100 Material Note: To build a part number, visit our website at www.bergquistcompany.com. Bond-Ply ®: U.S. Patent 5,090,484 and others. www.bergquistcompany.com The Bergquist Company North American Headquarters 18930 West 78th Street Chanhassen, MN 55317 Phone: 800-347-4572 Fax: 952-835-0430 – 00 Section E Shelf Life: The double-sided, pressure sensitive adhesive used in Bond-Ply products requires the use of dual liners to protect the surfaces from contaminants. Bergquist recommends a 6-month shelf life at a maximum continuous storage temperature of 35°C, or 3-month shelf life at a maximum continuous storage temperature of 45°C, for maintenance of controlled adhesion to the liner.The shelf life of the Bond-Ply material, without consideration of liner adhesion (which is often not critical for manual assembly processing), is recommended at 12 months from date of manufacture at a maximum continuous storage temperature of 60°C. 1) The ASTM D5470 (Bergquist modified) test fixture was used.The recorded value includes interfacial thermal resistance.These values are provided for reference only. Actual application performance is directly related to the surface roughness, flatness and pressure applied. Section A • Sheet form, roll form, and die-cut parts TEST METHOD Visual Thickness (inch) / (mm) Section D • Mount heat sink onto BGA graphic processor or drive processor • Mount heat spreader onto power converter PCB or onto motor control PCB METRIC VALUE White Reinforcement Carrier Section C Typical Applications Include: IMPERIAL VALUE White Section B • Thermal impedance: 0.86°C-in2/W (@100 psi) • High bond strength to a variety of surfaces • Double-sided, pressure sensitive adhesive tape • High performance, thermally conductive acrylic adhesive • Can be used instead of heat-cure adhesive, screw mounting or clip mounting TYPICAL PROPERTIES OF BOND-PLY 100 PROPERTY Color The Bergquist Company - China Rm. 7C, Aihe Mansion No. 629 Ling Ling Road Shanghai, China 200030 Ph: 86-21-6464-2206 Fax: 86-21-6464-2209 All statements, technical information and recommendations herein are based on tests we believe to be reliable, and THE FOLLOWING IS MADE IN LIEU OF ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING THE IMPLIED WARRANTIES OF MARKETABILITY AND FITNESS FOR PURPOSE. Sellers’ and manufacturers’ only obligation shall be to replace such quantity of the product proved to be defective. Before using, user shall determine the suitability of the product for its intended use, and the user assumes all risks and liability whatsoever in connection therewith. NEITHER SELLER NOR MANUFACTURER SHALL BE LIABLE EITHER IN TORT OR IN CONTRACT FOR ANY LOSS OR DAMAGE, DIRECT, INCIDENTAL, OR CONSEQUENTIAL, INCLUDING LOSS OF PROFITS OR REVENUE ARISING OUT OF THE USE OR THE INABILITY TO USE A PRODUCT. No statement, purchase order or recommendations by seller or purchaser not contained herein shall have any force or effect unless in an agreement signed by the officers of the seller and manufacturer. PDS_10110_BP_100_0305
BP100-0.005-00-12/12 价格&库存
很抱歉,暂时无法提供与“BP100-0.005-00-12/12”相匹配的价格&库存,您可以联系我们找货
