GP2500-0.040-02-0404
    BERGQUIST
GP2500-0.040-02-0404 数据手册
Gap Pad 2500 ® Thermally Conductive, Un-Reinforced Gap Filling Material Features and Benefits • Thermal conductivity: 2.7 W/m-K • High thermal performance, cost-effective solution • Un-reinforced construction for additional compliancy • Medium compliancy and conformability TYPICAL PROPERTIES OF GAP PAD 2500 PROPERTY Color IMPERIAL VALUE Light Brown — — — Thickness (inch) / (mm) 0.020 to 0.125 0.508 to 3.175 ASTM D374 Inherent Surface Tack (1- or 2-sided) 2 2 — Density (g/cc) 3.1 3.1 ASTM D792 Heat Capacity (J/g-K) 1.0 1.0 ASTM E1269 Hardness, Bulk Rubber (Shore 00) (1) 80 80 ASTM D2240 Young’s Modulus (psi) / (kPa) (2) 113 779 ASTM D575 Continuous Use Temp (°F) / (°C) -76 to 392 -60 to 200 — >6000 ASTM D149 6.8 6.8 ASTM D150 Volume Resistivity (Ohm-meter) 1011 1011 ASTM D257 Flame Rating V-O V-O U.L. 94 THERMAL Thermal Conductivity (W/m-K) 2.7 2.7 ASTM D5470 1) Thirty second delay value Shore 00 hardness scale. 2) Young's Modulus, calculated using 0.01 in/min. step rate of strain with a sample size of 0.79 inch2. For more information on Gap Pad modulus, refer to Bergquist Application Note #116. Typical Applications Include: • Multiple heat-generating components to a common heat sink • Graphics chips to heat sinks • Processors to heat sinks • Mass storage drives • Wireline / wireless communications hardware Configurations Available: • Sheet form and die-cut parts Building a Part Number Resultant Thickness (mils) Thickness vs. Thermal Resistance Gap Pad 2500 120 100 80 60 40 20 0 0.20 00 – Standard Options ACME 89302 Rev a Section E – Section D 0.100 – 02 Section C GP2500 – Section B Note: Resultant thickness is defined as the final gap thickness of the application. >6000 Dielectric Constant (1000 Hz) Section A Gap Pad 2500 is offered with inherent natural tack on both sides of the material allowing for stick-in-place characteristics during application assembly.The material is supplied with protective liners on both sides. TEST METHOD Visual Reinforcement Carrier ELECTRICAL Dielectric Breakdown Voltage (Vac) Gap Pad 2500 is a thermally conductive, electrically insulating, un-reinforced gap filling material. Gap Pad 2500 is a filled-polymer material yielding an elastic polymer that allows for easy handling and converting without the need for reinforcement.These properties also allow for good wet-out and interfacing characteristics to surfaces with roughness and/or topography. All these characteristics make this material ideal for applications using either clip or screw-mounted assemblies. METRIC VALUE Light Brown NA = Selected standard option. If not selecting a standard option, insert company name, drawing number, and revision level. 0816 = Standard sheet size 8" x 16", or 00 = custom configuration 02 = Natural tack, both sides Standard thicknesses available: 0.020", 0.040", 0.060", 0.080", 0.100", 0.125" GP2500 = Gap Pad 2500 Material Note: To build a part number, visit our website at www.bergquistcompany.com. 0.60 1.00 1.40 1.80 Thermal Resistance (C-in2/W) Gap Pad ®: U.S. Patent 5,679,457 and others www.bergquistcompany.com The Bergquist Company North American Headquarters 18930 West 78th Street Chanhassen, MN 55317 Phone: 800-347-4572 Fax: 952-835-0430 The Bergquist Company European Headquarters Bramenberg 9a, 3755 BT Eemnes Netherlands Phone: 31-35-5380684 Fax: 31-35-5380295 The Bergquist Company - Asia Room 15, 8/F Wah Wai Industrial Centre No. 38-40, Au Pui Wan Street Fotan, Shatin, N.T. Hong Kong Ph: 852.2690.9296 Fax: 852.2690.2344 All statements, technical information and recommendations herein are based on tests we believe to be reliable, and THE FOLLOWING IS MADE IN LIEU OF ALL WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING THE IMPLIED WARRANTIES OF MARKETABILITY AND FITNESS FOR PURPOSE. Sellers’ and manufacturers’ only obligation shall be to replace such quantity of the product proved to be defective. Before using, user shall determine the suitability of the product for its intended use, and the user assumes all risks and liability whatsoever in connection therewith. NEITHER SELLER NOR MANUFACTURER SHALL BE LIABLE EITHER IN TORT OR IN CONTRACT FOR ANY LOSS OR DAMAGE, DIRECT, INCIDENTAL, OR CONSEQUENTIAL, INCLUDING LOSS OF PROFITS OR REVENUE ARISING OUT OF THE USE OR THE INABILITY TO USE A PRODUCT. No statement, purchase order or recommendations by seller or purchaser not contained herein shall have any force or effect unless in an agreement signed by the officers of the seller and manufacturer. PDS_GP_2500_12.08
GP2500-0.040-02-0404 价格&库存
很抱歉,暂时无法提供与“GP2500-0.040-02-0404”相匹配的价格&库存,您可以联系我们找货
