2255-5
2255-5
    VIDEK
2255-5 数据手册
DVI Digital Monitor Cables Featuring the unique Digital Visual Interface (DVI) connector, the cables are referred to as DVI/D; for use between mother board, graphics cards and monitors fitted with the same interface termination. These DVI Digital cables are available in two variants; either Single link (up to 165 Mhz bandwidth) or Dual link (up to 330 Mhz) versions. As most XGA monitors tend to run at 50 Mhz, then Single link cables will, at the moment, tend to be the most likely required. Features: • • • • • • Connects host device to a display unit supporting high resolution video signals Now commonly fitted to digital monitors - either instead of or alongside the analogue VGA interface Available in Single link (18 pin) and Dual link (24 pin) versions Single link cables support bandwidths up to 165 Mhz, Dual link 330 Mhz Manufactured using UL 20276 cable and high quality moulded connectors Available in up to 15m length only - with custom lengths not available 2255 Stock No Description Single Link 2255-1 DVI/D M to M Single Link Digital Monitor Cable 1Mtr 2255 DVI/D M to DVI M Single Link Digital Monitor Cable 2Mtr 2255-3 DVI/D M to M Single Link Digital Monitor Cable 3Mtr 2255-5 DVI/D M to M Single Link Digital Monitor Cable 5Mtr 2255-10 DVI/D M to M Single Link Digital Monitor Cable 10Mtr 2255-15 DVI/D M to M Single Link Digital Monitor Cable 15Mtr 2255-20 DVI/D M to M Single Link Digital Monitor Cable 20Mtr Dual Link 2255D-1 DVI/D M to M Dual Link Digital Monitor Cable 1Mtr 2255D-2 DVI/D M to M Dual Link Digital Monitor Cable 2Mtr 2255D-3 DVI/D M to M Dual Link Digital Monitor Cable 3Mtr 2255D-5 DVI/D M to M Dual Link Digital Monitor Cable 5Mtr 2255D-10 DVI/D M to M Dual Link Digital Monitor Cable 10Mtr 2255D-15 DVI/D M to M Dual Link Digital Monitor Cable 15Mtr 2255D-20 DVI/D M to M Dual Link Digital Monitor Cable 20Mtr Female to Female Genderchanger 8109 DVI Skt to Skt Gender Changer
2255-5 价格&库存
很抱歉,暂时无法提供与“2255-5”相匹配的价格&库存,您可以联系我们找货
