4261LP
4261LP
    VIDEK
    VIDEK - 4261LP - In-Line Adapter, RJ45, F Coupler, Adaptor, In-Line, Jack, 8 Ways
4261LP 数据手册
1 Cat5e UTP Couplers/Economisers Cat5e In-Line Couplers Part No: See chart The Cat5e in-line coupler adaptors enable two existing RJ45 patch cables to be joined together with a minimum effort. They are wired in a straight through configuaration and available in both standard and low profile versions. The fully shielded version is supplied as a unit with internal metal can (for RFI/ EMC protection) contained in a metalised casing. Features & Benefits Compact RJ45 socket to socket Cat.5E compliant device with new low profile version Two inch solid adaptor - designed for joining two standard wired patch cables Supplied in both unshielded & shielded versions Part Number Chart Part Code Description 4261LP VIDEK Cat5e UTP RJ45 F to F Low Profile Coupler 4261 VIDEK Cat5e UTP RJ45 Socket to Socket Coupler 4261KY VIDEK Cat5e UTP RJ45 Socket to Socket Inline Keystone Coupler
4261LP 价格&库存
很抱歉,暂时无法提供与“4261LP”相匹配的价格&库存,您可以联系我们找货
