4262LP
4262LP
    VIDEK
4262LP 数据手册
1 Shielded Cat.6 System Cat6 In-Line Couplers Part No: See Chart The Cat.6 in-line coupler adaptors enable two existing RJ45 patch cables to be joined together with a mininmum effort. They are wired in a straight through configuration and available in both standard and low profile versions. The fully shielded version is supplied as a unit with internal metal can (for RFI/ EMC protection) contained in a metalised casing. Features & Benefits Compact RJ45 socket to socket Cat.6 compliant device with low profile version Two inch solid adaptor - designed for joining two standard wired patch cables Part Number Chart Part Code Description 4262P VIDEK Cat6 STP RJ45 Punch Down Coupler 4262LP VIDEK Cat6 UTP RJ45 F to F Low Profile Coupler
4262LP 价格&库存
很抱歉,暂时无法提供与“4262LP”相匹配的价格&库存,您可以联系我们找货
