2409EMH
2409EMH
    VIDEK
    VIDEK - 2409EMH - DVI to HDMI Audio / Video Adapter, Mini DisplayPort Plug, HDMI Receptacle
2409EMH 数据手册
1 Display Adapters & Convertors DisplayPort Adapters Part No: 2409EMH This high quality adaptor supports the link from a PC featuring the Mini DisplayPort interface to a HDMI display. Specification Input Mini DisplayPort M Max 1920x1200 Output HDMI F Max 1920x1200 Operating Frequency Vertical Frequency Range 50/60Hz 162Mhz Bandwidth 225MHz/2.25 Gbps / channel Physical Size (LxWxD) Weight (Net) Colour Connector Operational Operating Temperature Operating Humidity Storage Temperature Storage Humidity Power Requirement Regulatory Approvals 45 x 45 x 12mm 19g White Nickel Plated 0 °C to +55 °C 10% to 85% RH (no condensation) 0 °C to +70 °C 5% to 90% RH (no condensation) No external power needed CE, FCC, RoHS Features & Benefits Complies with DisplayPort 1.1 standard Supports HDMI resolution up to 1080P Supports extend/mirror display Easy to use adapter, no software required POWERED from mini DisplayPort Plug-n-Play Ordering Information Part No: 2409EMH Product Description: VIDEK Mini DisplayPort Plug to HDMI Socket Adaptor - White 2 Display Adapters & Convertors DisplayPort Adapters Part No: 2409EMH MacBook LCD Monitor Mac Mini HD TV iMac Projector Mac Pro DV
2409EMH 价格&库存
很抱歉,暂时无法提供与“2409EMH”相匹配的价格&库存,您可以联系我们找货
