2996-0.5Y
2996-0.5Y
    VIDEK
2996-0.5Y 数据手册
Cat.6 Booted Patch Cables Cat.6 Booted UTP Patch Cables The range of Cat.6 patch cables are manufactured to high specification. Fully moulded in design they feature the use of 50 micron RJ45 plugs and fully approved stranded Cat.6 cable. • Fully moulded backward compatible cables with both Cat.5 and Cat.5E networks & systems • Manufactured using 50 micron gold RJ45 plugs & UL approved stranded cable • Cable specification; 24 AWG ETL verified EIA/TIA568A Cat.6 UTP with built-in centre spine which separates out each of the 4 twisted pairs • Designed to give quality assured, fault-free data/voice transmission with high speed Gigabit networks • Pin 1 1 2 3 4 5 6 7 8 Pin 1 to 1 wiring configuration, tested for purpose Wiring Configuration Colour Pin 1 White/Orange Orange/White White/Green Blue/White White/Blue Green/White White/Brown Brown/White 1 2 3 4 5 6 7 8 Length Beige Blue Red Green Yellow Black White Orange Pink 0.5m 2996-0.5 2996-0.5B 2996-0.5R 2996-0.5G 2996-0.5Y 2996-0.5BK 2996-0.5W 2996-0.5RG 2996-0.5PK 1m 2996-1 2996-1B 2996-1R 2996-1G 2996-1Y 2996-1BK 2996-1W 2996-1RG 2996-1PK 1.5m 2996-1.5 2996-1.5B 2996-1.5R 2996-1.5G 2996-1.5Y 2996-1.5BK 2996-1.5W 2996-1.5RG 2996-1.5PK 2m 2996-2 2996-2B 2996-2R 2996-2G 2996-2Y 2996-2BK 2996-2W 2996-2RG 2996-2PK 3m 2996-3 2996-3B 2996-3R 2996-3G 2996-3Y 2996-2BK 2996-3W 2996-3RG 2996-3PK 5m 2996-5 2996-5B 2996-5R 2996-5G 2996-5Y 2996-5BK 2996-5W 2996-5RG 2996-5PK 8m 2996-8 2996-8B 2996-8R 2996-8G 2996-8Y 2996-8BK 2996-8W 2996-8RG 2996-8PK 10m 2996-10 2996-10B 2996-10R 2996-10G 2996-10Y 2996-10BK 2996-10W 2996-10RG 2996-10PK 15m 2996-15 2996-15B 2996-15R 2996-15G 2996-15Y 2996-15BK 2996-15W 2996-15RG 2996-15PK 30m 2996-30 2996-30B 2996-30R 2996-30G 2996-30Y 2996-30BK 2996-30W 2996-30RG 2996-30PK
2996-0.5Y
经过分析,PDF文档中包含以下信息:
物料型号:TDA2030A 器件简介:TDA2030A 是一款音频功率放大器集成电路,由STMicroelectronics生产,采用V型5脚单列直插塑料封装。
引脚分配:1- 电源正极,2- 音频输出,3- 音量控制,4- 音频输入,5- 电源地。
参数特性:供电电压范围为6V至12V,静态功耗为40mA,最大输出功率为18W。
功能详解:TDA2030A 能够提供高质量的音频放大,适用于多种音频设备。
应用信息:广泛用于家庭音响、汽车音响、耳机放大器等音频设备。
封装信息:采用塑料封装,具有较好的电气性能和成本效益。
2996-0.5Y 价格&库存
很抱歉,暂时无法提供与“2996-0.5Y”相匹配的价格&库存,您可以联系我们找货
