1965-3X
1965-3X
    VIDEK
1965-3X 数据手册
1 Cat5e Patch Cables Crossover Cat5e UTP Patch Cables Part No: See Chart (Length) + (Colour) The Cat.5E cross-wired patch cables are designed for use in copper Gigabit applications; acting as the link cable between Gigabit card to switch or switch to switch. Supplied as an unbooted cable, all eight lines of the cable are connected whereas only four lines with the Cat.5 version. Wired as follows: Pin No. Colour Pin No. 1 White/Orange 3 2 Orange/White 6 3 White/Green 1 4 Blue/White 7 5 White/Blue 8 6 Green/White 2 7 White/Brown 4 8 Brown/White 5 Features & Benefits Cat.5E UTP 24 AWG stranded cross-wired patch cables with all line connected designed for use with copper Gigabit environments Full range of lengths and colours with backward compatibility with standard Cat.5 systems Supplied as unbooted cables which are fully tested with custom lengths available upon request 2 Cat5e Patch Cables Crossover Cat5e UTP Patch Cables Part No: See Chart (Length) + (Colour) Part Number Chart Length Black Blue 1965-0.5X 1965-0.5XBK 1965-0.5XB 1965-0.5XG 1965-0.5XR 1965-0.5XY 1965-1X 1965-1XBK 1965-1XB 1965-1XG 1965-1XR 1965-1XY 1965-1.5X 1965-1.5XBK - 1965-1.5XG 1965-1.5XR - 2 Metre 1965-2X 1965-2XBK 1965-2XB 1965-2XG 1965-2XR 1965-2XY 3 Metre 1965-3X 1965-3XBK 1965-3XB 1965-3XG 1965-3XR 1965-3XY 5 Metre 1965-5X 1965-5XBK 1965-5XB 1965-5XG 1965-5XR 1965-5XY 10 Metre 1965-10X 1965-10XBK 1965-10XB 1965-10XG 1965-10XR 1965-10XY 15 Metre 1965-15X 1965-15XBK - - 1965-15XR 1965-15XY 25 Metre 1965-25X 1965-25XBK 1965-25XB 1965-25XG 1965-25XR - 0.5 Metre 1 Metre 1.5 Metre Beige Green Red Yellow
1965-3X
物料型号为VIDEK Cat5e Patch Cables Crossover Cat5e UTP Patch Cables,具体型号根据长度和颜色编码确定。
器件简介:这些Cat.5E交叉线缆设计用于铜质千兆应用,作为千兆网卡到交换机或交换机到交换机之间的连接线。
与Cat.5版本相比,Cat.5E版本所有八条线路均连接。
引脚分配:1-白橙/3,2-橙/6,3-白绿/1,4-蓝白/7,5-白蓝/8,6-绿白/2,7-白棕/4,8-棕白/5。
参数特性:Cat.5E UTP 24 AWG绞合线缆,所有线路连接,设计用于铜质千兆环境。
提供多种长度和颜色选择,并且与标准Cat.5系统向后兼容。
功能详解:提供全系列长度和颜色选择,支持定制长度,并且提供未装配的线缆,这些线缆已经过全面测试。
应用信息:适用于铜质千兆环境,提供向后兼容性,并且可以定制长度。
封装信息:提供未装配的线缆,并且可以根据请求提供定制长度。
1965-3X 价格&库存
很抱歉,暂时无法提供与“1965-3X”相匹配的价格&库存,您可以联系我们找货
