1083-2
1083-2
    VIDEK
1083-2 数据手册
Bi-Directional IEEE 1284 Parallel Cables Many PCs and printers have high speed capability; giving superior performance levels. Greater transmission speeds are now possible with these IEEE 1284 specified, double shielded, cables. Essentially, these parallel printer cables provide exceptional reliability and are designed for use with most current parallel printers. Currently, the IEEE 1284 standard incorporates three enhanced interface connectors; Type A Connector: 25 way D Plug Type B Connector: 36 way Centronics Plug Type C Connector: Micro 36 way Centronics Plug Most IEEE 1284 printers require a Type A to B which is an industry standard 25 D plug to 36 Centronics plug type cable. However, in more recent times the micro 36 pin Centronics connector is being used. Features: • • • • • • • • • • • • • • Exceptional high quality, full specification moulded range of parallel printer cables High speed data transmission with reliability of performance and data integrity assured Bi-directional computer cables ideal for all the latest laser printers including HP Laserjets Fully tested IEEE 1284-1994 compliant cable that gives a reliable, high quality bi-directional link between computer and printer including ECP and EPP type interfaces Specification: Fully moulded high specification IEEE Standard 1284-1994 compliant cable Cable type: - 18 twisted pair, double shielded foil & braid - 28 AWG (7 x 0.127), UL 20276 approved Connectors: - Solder connectors are inner moulded and wrapped with copper foil - Fully encapsulated moulded hoods are fitted with thumb screws or appropriate fittings 1083 Stock No Description Type A to B Cable 1083-2 DB25M to C36M IEEE1284 Parallel Printer Cable - 2Mtr 1083-3 DB25M to C36M IEEE1284 Parallel Printer Cable - 3Mtr 1083-5 DB25M to C36M IEEE1284 Parallel Printer Cable - 5Mtr 1083-10 DB25M to C36M IEEE1284 Parallel Printer Cable - 10Mtr Type A to A Cable 1085 DB25M to DB25M IEEE1284 Parallel Cable - 1Mtr 1085-2 DB25M to DB25M IEEE1284 Parallel Cable - 2Mtr 1085-3 DB25M to DB25M IEEE1284 Parallel Cable - 3Mtr 1085-5 DB25M to DB25M IEEE1284 Parallel Cable - 5Mtr 1085-10 DB25M to DB25M IEEE1284 Parallel Cable - 10Mtr Type A to C Cable 1080-2 DB25M to Micro C36M IEEE1284 Parallel Cable - 2Mtr 1080-3 DB25M to Micro C36M IEEE1284 Parallel Cable - 3Mtr 1080-5 DB25M to Micro C36M IEEE1284 Parallel Cable - 5Mtr 1080-10 DB25M to Micro C36M IEEE1284 Parallel Cable - 10Mtr Type B to C Cable 1081 Micro C36M to C36M IEEE1284 Parallel Cable - 1Mtr 1081-2 Micro C36M to C36M IEEE1284 Parallel Cable - 2Mtr Type C to C Cable 1082-2 Micro C36M to Micro C36M IEEE1284 Parallel Cable - 2Mtr IEEE 1284 Adaptors 8088 HP C36 M to DB25 F Adapter
1083-2 价格&库存
很抱歉,暂时无法提供与“1083-2”相匹配的价格&库存,您可以联系我们找货
