2409EMD
2409EMD
    VIDEK
    VIDEK - 2409EMD - MINI DISPLAY PORT PLUG TO DVI ADAPTOR
2409EMD 数据手册
1 Display Port Adapters Mini Display Port Adapters Part No: 2409EMD The mini DisplayPort 1.1a compliant adaptors and cables are designed to be used to connect equipment that feature the mini DisplayPort connector. They support high definition video as well as multi channel digital audio. Specification Input Mini DisplayPort M Max 1920x1200 Output DVI F Max 1920x1200 Operating Frequency Vertical Frequency 50/60Hz Range Bandwidth 225MHz/2.25 Gbps / channel Physical Size (LxWxD) Weight (Net) Colour Conector Operational Operating Temp. Operating Humidity Storage Temp. Storage Humidity 45 x 45 x 15mm 30g White Nickel Plated 0°C to +55°C 10% to 85% RH (no condensation) 0°C to +70°C 5% to 90% RH (no condensation) Power Requirement No external power needed Regulatory Approvals CE, FCC, RoHS Features & Benefits Supports pure digital direct HD video and audio from source High performance cables featuring Mini DisplayPort connection Designed to improve digital display connectivity 2 Display Port Adapters Mini Display Port Adapters Part No: 2409EMD MacBook LCD Monitor Mac Mini HD TV iMac Mac Pro Projector Ordering Information DV Part No: 2409EMD Product Description: VIDEK Mini DisplayPort Plug to DVI Socket Adaptor -White
2409EMD 价格&库存
很抱歉,暂时无法提供与“2409EMD”相匹配的价格&库存,您可以联系我们找货
