2409EMV
2409EMV
    VIDEK
    VIDEK - 2409EMV - DVI to VGA Audio / Video Adapter, Mini DisplayPort Plug, VGA Receptacle
2409EMV 数据手册
1 Display Port Adapters Mini Display Port Adapters Part No: 2409EMV The mini DisplayPort 1.1a compliant adaptors and cables are designed to be used to connect equipment that feature the mini DisplayPort connector. They support high definition video as well as multi channel digital audio. Specification Input Mini DisplayPort M Max 1920x1200 Output VGA F Max 1920x1200 Operating Frequency Vertical Frequency 50/60Hz Range 162MHz Bandwidth 225MHz/2.25Gbps / channel Physical Size (LxWxD) Weight (Net) Colour Conector Operational Operating Temp. Operating Humidity Storage Temp. Storage Humidity 45 x 45 x 15mm 30g White Nickel Plated 0°C to +55°C 10% to 85% RH (no condensation) 0°C to +70°C 5% to 90% RH (no condensation) Power Requirement No external power needed Regulatory Approvals CE, FCC, RoHS Features & Benefits Supports pure digital direct HD video and audio from source High performance cables featuring Mini DisplayPort connection Designed to improve digital display connectivity 2 Display Port Adapters Mini Display Port Adapters Part No: 2409EMV MacBook LCD Monitor Mac Mini HD TV iMac Mac Pro Projector Ordering Information DV Part No: 2409EMV Product Description: VIDEK Mini Display Port Plug to VGA Socket Adaptor - White
2409EMV
物料型号为2409EMV的Mini DisplayPort转VGA适配器,是符合Mini DisplayPort 1.1a标准的。
它支持高清视频和多声道数字音频,输入接口为Mini DisplayPort M,输出为VGA F,最大分辨率支持1920x1200。
操作频率为50/60Hz,162MHz,传输速率为2.25Gbps/通道。
产品尺寸为45 x 45 x 15mm,重量为30g,外表涂层为白色镀镍。
它在0°C至+55°C的温度范围内工作,存储温度为0°C至+70°C。
不需要外部电源,通过了CE、FCC、RoHS等认证。
VIDEK的这款适配器设计用于改善数字显示连接性,适用于MacBook、Mac Mini、Mac Pro、iMac、HD电视和投影仪等设备。
产品描述为VIDEK Mini Display Port Plug到VGA Socket的适配器,颜色为白色。
2409EMV 价格&库存
很抱歉,暂时无法提供与“2409EMV”相匹配的价格&库存,您可以联系我们找货
