0.5 mm SMT Board-to-Board Connector System
Text
Tape and Reel
for fully automated processing
Text
Colibri
Receptacle
(COM Module)
Plug
(Carrier Board)
Colibri® for COM Express®
Key Features
ept‘s Colibri® connector is a shielded, 2-row, SMT interconnect
system in 0.5 mm pitch.
• Meets the requirements
of PICMG COM Express®
and SFF-SIG CoreExpress®
It is designed to meet the requirements according to
specifications not only of PICMG COM Express®, but also
of SFF-SIG Core Express®. Furthermore Colibri® products
are compatible with all common connectors available on the
market and extensively tested.
The connector system is available with 8 mm and 5 mm
stacking height plus 220 and 440 pins.
Additional versions with flexible pin count as well as multiple
stacking heights are available on request.
• Intermatability with available
connectors in the market
• Tested up to 5 Gbit/s;
applications up to 8 Gbit/s
possible
• Robust connector design
• Custom configurations in pin
count
• Integrated Pick & Place area
• Packed in Tape & Reel
Applications
• COM Express®
• CoreExpress®
• Mezzanine Add-on Cards
GBps
4
www.ept.de
Receptacle for COM Module
Text
area for pick-and-place
optional: pick-and-place cap
0.5 mm pitch
196 signal and 24 ground pins
Plug for Carrier Board
Text
Colibri
SMT fixing
shield
Technical Specifications
Basics
Specification
No. of contacts
Termination technology
Operating temperature range
Material
SMT
– 40 °C to + 85 °C
LCP, UL 94 V-0
Contact material
Copper alloy
Grid
Au over Ni
0.5 mm
Mating force per pin
max. 0.9 N
Separating force per pin
min. 0.1 N
Durability
Coplanarity
Electrical
Operational current
Operating voltage
Contact resistance
Insulation resistance
Test voltage
Data transfer rate
Processing
220 / 440
Insulator material
Plating
Mechanical
PICMG® COM.0
Soldering temperature
MSL
Approval
www.ept.de
30 mating cycles
max. 0.1 mm
max. 0.5 A
50 VAC
max. 75 mΩ
> 100 MΩ
200 VAC
5 Gbit/s (8 Gbit/s)
260 °C per J-STD-020
1
Packaging
Tape and reel
Assembly
Pick and place
Flammability
UL pending
Environment
RoHS compliant
5
Colibri
Drawing shows version with 8 mm stacking height, dimensions in mm
Plug (Base Board)
Colibri® Plug
4,45
7,45
No. of contacts
Part number
Part number
5 mm stacking height
220
401-55101-51
401-51101-51
220
with pick & place cap
401-55151-51
401-51151-51
440
401-55501-51
401-51501-51
6
Options
On request
Note
– Tray packaging
(please add VP1 to the part number!)
– Other contact numbers
– Other stack heights
– Different plating thickness
– For detailed information
see customer drawing
www.ept.de
Colibri
Dimensions in mm
Receptacle (COM Module)
Colibri® Receptacle
No. of
contacts
Part number
220
402-51101-51
440
402-51501-51
Options
On request
Note
– Tray packaging
www.ept.de
7
很抱歉,暂时无法提供与“401-55501-51”相匹配的价格&库存,您可以联系我们找货
