401-51501-51
401-51501-51
    EPT
    EPT - 401-51501-51 - Mezzanine Connector, 5mm Height, COM Express, Header, 0.5 mm, 2 Rows, 440 Conta...
401-51501-51 数据手册
0.5 mm SMT Board-to-Board Connector System Text Tape and Reel for fully automated processing Text Colibri ® Receptacle (COM Module) Plug (Carrier Board) Colibri® for COM Express® Key Features ept‘s Colibri® connector is a shielded, 2-row, SMT interconnect system in 0.5 mm pitch. • Meets the requirements of PICMG COM Express® and SFF-SIG CoreExpress® It is designed to meet the requirements according to specifications not only of PICMG COM Express®, but also of SFF-SIG Core Express®. Furthermore Colibri® products are compatible with all common connectors available on the market and extensively tested. The connector system is available with 8 mm and 5 mm stacking height plus 220 and 440 pins. Additional versions with flexible pin count as well as multiple stacking heights are available on request. • Intermatability with available connectors in the market • Tested up to 5 Gbit/s; applications up to 8 Gbit/s possible • Robust connector design • Custom configurations in pin count • Integrated Pick & Place area • Packed in Tape & Reel Applications • COM Express® • CoreExpress® • Mezzanine Add-on Cards GBps 4 www.ept.de Receptacle for COM Module 0.5 mm SMT Board-to-Board Connector System Text area for pick-and-place optional: pick-and-place cap 0.5 mm pitch 196 signal and 24 ground pins Plug for Carrier Board Text Colibri SMT fixing shield ® Colibri® for COM Express® Technical Specifications Basics 0.5 mm SMT Board-to-Board Connector System Specification No. of contacts Termination technology Operating temperature range Material SMT – 40 °C to + 85 °C LCP, UL 94 V-0 Contact material Copper alloy Grid Au over Ni 0.5 mm Mating force per pin max. 0.9 N Separating force per pin min. 0.1 N Durability Coplanarity Electrical Operational current Operating voltage Contact resistance Insulation resistance Test voltage Data transfer rate Processing 220 / 440 Insulator material Plating Mechanical PICMG® COM.0 Soldering temperature MSL Approval www.ept.de 30 mating cycles max. 0.1 mm max. 0.5 A 50 VAC max. 75 mΩ > 100 MΩ 200 VAC 5 Gbit/s (8 Gbit/s) 260 °C per J-STD-020 1 Packaging Tape and reel Assembly Pick and place Flammability UL pending Environment RoHS compliant 5 0.5 mm SMT Board-to-Board Connector System ® Colibri Drawing shows version with 8 mm stacking height, dimensions in mm Plug (Base Board) Colibri® Plug 4,45 7,45 No. of contacts Part number 8 mm stacking height Part number 5 mm stacking height 220 401-55101-51 401-51101-51 220 with pick & place cap 401-55151-51 401-51151-51 440 with pick & place cap 401-55501-51 401-51501-51 6 Options On request Note – Tray packaging (please add VP1 to the part number!) – Other contact numbers – Other stack heights – Different plating thickness – For detailed information see customer drawing www.ept.de Colibri 0.5 mm SMT Board-to-Board Connector System ® Dimensions in mm Receptacle (COM Module) Colibri® Receptacle No. of contacts Part number 220 402-51101-51 440 402-51501-51 Options On request Note – Tray packaging (please add VP1 to the part number!) – Other contact numbers – Different plating thickness – For detailed information see customer drawing www.ept.de 7
401-51501-51 价格&库存
很抱歉,暂时无法提供与“401-51501-51”相匹配的价格&库存,您可以联系我们找货
