103-90064
103-90064
    EPT
103-90064 数据手册
Product Data Sheet DIN 41612 Male 90°, type C/2, Part No. 103-90064 Illustration similar Perpendicular Through Hole Rugged Termination length 3 mm 48 contacts solder performance level 2 » to product on www.ept.de » to product group DIN 41612 Version from 24.09.2020, 00:47 - subject to change without notice ept GmbH | Bergwerkstr. 50 | 86971 Peiting | Tel. +49 (0) 8861 / 25 01 0 | Fax +49 (0) 8861 / 55 07 | sales@ept.de | www.ept.de Page 1 Product Data Sheet DIN 41612 Male 90°, type C/2, Part No. 103-90064 Technical Specifications Basics Specification Performance Level No. of Contacts IEC 60603-2 (DIN 41612) 2 48 Termination Technology solder Termination Length 3 mm Operating Temperature Range -55°C to +125°C Material Insulator Material Contact Material PBT glass filled UL 94 V-0 Copper alloy Mechanical Pitch Mating Force Separating Force per Pin Durability 2.54 mm < 45 N > 0.15 N 400 mating cycles Electrical Operational Current 1.5 A Contact Resistance 106 MΩ Test Voltage 1000 V Processing Soldering Temperature to 260°C UL file E130314 Approval / Compliance Environment RoHS compliant Version from 24.09.2020, 00:47 - subject to change without notice ept GmbH | Bergwerkstr. 50 | 86971 Peiting | Tel. +49 (0) 8861 / 25 01 0 | Fax +49 (0) 8861 / 55 07 | sales@ept.de | www.ept.de Page 2 Product Data Sheet DIN 41612 Male 90°, type C/2, Part No. 103-90064 Derating Diagram Version from 24.09.2020, 00:47 - subject to change without notice ept GmbH | Bergwerkstr. 50 | 86971 Peiting | Tel. +49 (0) 8861 / 25 01 0 | Fax +49 (0) 8861 / 55 07 | sales@ept.de | www.ept.de Page 3 Product Data Sheet DIN 41612 Male 90°, type C/2, Part No. 103-90064 Options Board Lock 90° Suitable for connectors with type B, C, D, E, F, G male connectors and R female connectors Type of Insertion Forces PCB Thickness Part Number 103-90064C1 Fm not soldered Fh soldered Fh Locked < 30 N > 10 N > 20 N ≤ 1.6 mm Under Tension < 30 N > 7.5 N > 20 N > 1.6 mm Modifications Available on request Pre-mating and late-mating contacts Contact arrangement Performance levels I + III or customer-specific Special contact length Accessories » DIN 41612 Coding pliers Part Number 894-301 Drawings Component data in 2D and 3D format you can download here: Version from 24.09.2020, 00:47 - subject to change without notice ept GmbH | Bergwerkstr. 50 | 86971 Peiting | Tel. +49 (0) 8861 / 25 01 0 | Fax +49 (0) 8861 / 55 07 | sales@ept.de | www.ept.de Page 4 Powered by TCPDF (www.tcpdf.org) Product Data Sheet Drawings Component data in 2D and 3D format you can download here: » PDF » 3D IGES » 3D STEP » 3D PDF Version from 24.09.2020, 00:47 - subject to change without notice ept GmbH | Bergwerkstr. 50 | 86971 Peiting | Tel. +49 (0) 8861 / 25 01 0 | Fax +49 (0) 8861 / 55 07 | sales@ept.de | www.ept.de Page 5
103-90064 价格&库存
很抱歉,暂时无法提供与“103-90064”相匹配的价格&库存,您可以联系我们找货
