244-61300-15
    EPT
244-61300-15 数据手册
2.0 Connector System IEC 61076-4-101 Definition of Terms Connector according to IEC 61076-4-101 The hardmetric connector system ept-hm 2.0 was developed according to the international standard IEC 61076-4-101. As a result, a worldwide standard for the combination of PCBs is safeguarded by multicontact plug-and-socket connectors for customers. PCBs can be exchanged without problems from system to system. Important parameters like fixing, shielding and coding remain compatible to all applications. Contact length of the rear and front mating area ept offers 3 different lengths for the front mating area and 4 lengths for the rear mating area for the hm 2.0 male connectors. Different contact lengths are required for signal and ground contacts to establish first make and last break features. The long contacts with 11,25 mm are predominantly used for the shielding rows z and f. Thru hole specification of the PCB Throughplated holes for signal contacts and shieldings in press-fit techniques. The spacing The ept-hm 2.0 connectors have been developed with a spacing of 2 mm between contacts. These connectors are modular and therefore can be stacked together without interrupting the continuity of the 2 mm design. No space is wasted within a row of connectors. Module stacking To improve stacking and to avoid accidental reversal of connectors the end of the housings engage the adjacent connector to insure exact positioning onto the PCB board and give the modules the necessary support. Hole Ø 0,6 mm Drillhole 0,68 - 0,72 mm Cu min. 25 µm Sn 5 - 15 µm Plated through hole 0,55 - 0,65 mm Derating Diagram A Coding Multifunction block 3,5 loaded like a chess board 3 Operating Current [A] In order to avoid accidental plug in among PC boards the IEC 61076-4-101 standard provides protection through coding. Coding keys are easily hand inserted into the multifunction block of the connector module A, L and M. The pins are color coded for fast visual recognition. every 2nd row loaded 2,5 fully loaded 2 1,5 1 The modules A, L, M and compact PCI are equipped with a multifunction block. The coding devices, according to the IEC standard, can be added to the multifunction block. The guides guaranty the correct mating and prohibit accidental reversal of the male and fermale connectors. 0,5 20 40 60 80 100 120 140 C Ambient Temperature [ C] That coding devices may be assembled by a single plug and pulling tool and/or again removed. 2.2 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Technical Notes Electrical and mechanical data Spacing 2 mm Temperature range - 55°C bis +125°C Mechanical durability > 250 Mating Cycles Housing Polyester Glass filled acc. UL 94V-0 max. 20mΩ Contact resistance acc. to IEC 512-5 Male contact Contact material Bronze Female contact Bronze Male and female contact surface Insulation resistance acc. IEC 512-5 Insertion force per pin Extraction force per pin Au over PdNi over Ni Contact/Contact min. 104 MΩ Contact/Shield min. 104 MΩ Contact max. 0,75 N Shield max. 1 N Contact min. 0,15 N Shield min. 0,15 N Test voltage Row a, c, e Row b, d Row a, b, c Row a, b, c, d Row a, b, c, d, e fully loaded ever y 2nd position Chessboard within row 750 Veff 1500 Veff -- between rows 1500 Veff 1500 Veff -- within row 750 Veff 1500 Veff 1500 Veff between rows 750 Veff 750 Veff 1200 Veff Creepage- and air gaps fully loaded Row a, c, e Row b, d Row a, b, c Row a, b, c, d Row a, b, c, d, e within row every 2nd positon Chessboard Male connector Modules Female connector Backplane Male connector Modules Female connector Backplane Male connector Modules Female connector 0,8 mm 0,6 mm 2,5 mm 2,5 mm -- -- between rows 2,5 mm 2,5 mm 2,5 mm 2,5 mm -- -- within row 0,8 mm 0,6 mm 2,5 mm 2,5 mm 2,5 mm 2,5 mm between rows 0,8 mm 0,6 mm 0,8 mm 0,6 mm 1,5 mm 1,2 mm ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.3 2.0 Connector System IEC 61076-4-101 Electrical Characteristics The connector system ept hm 2.0 was specially designed for high data rates. Below are a few examples of the HF characteristics. A spice model is available for simulations during system design. The simulation model was verified with TDR measurements. Z [Ohm] 383 116 116 108 100 92 Change of impedance along the pin of row d of the ept connector hm2.0 84 76 Impedance after the elimination of multiple reflections, after impedance peeling. 68 Female part male part 60 52 36 Connector (Pin length of Row d = 22.5 mm) Solder joint 44 25 Solder joint 75 175 125 225 275 325 375 425 475 Time [psec] Ureflect_max = f(trise) 15% Ureflect_max is the maximum voltage reflected from the connector in percent. Ureflect_max is plotted as a function of the signal rise time. The connector is the only electrical discontinuity in a chosen 50Ohm System. 14% 13% Ureflect_max [%] 10% 9% 5% 1% 0% 0% 0 2.4 200 400 600 800 1000 trise [psec] ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Coupling (Cross talk) The near end and far end coupling was measured and simulated for different arrangements. A 200 mV signal with a rise time of 25 psec was used. Ucoupling [V] 0.030 Crosstalk of a row d pin into an adjacent row d pin (from C to G) Measured Ucoupling, near end coupling Measured Ucoupling, far end coupling Basic signal noise Simulated Ucoupling, near end coupling Simulated Ucoupling, far end coupling 0.024 0.018 0.012 Near End Coupling 0.006 0 -0.006 Far End Coupling -0.012 0 200 400 600 800 1000 1200 1400 1600 1800 2000 Time [psec] Ucoupling [V] Crosstalk of a pin in row d pin to an adjacent row e pin. (From C to A or E) Measured Ucoupling, near end coupling Measured Ucoupling, far end coupling Basic signal noise Simulated Ucoupling, near end coupling Simulated Ucoupling, far end coupling 0.011 0.009 0.007 0.005 0.003 0.001 0.001 0.003 0.005 0.007 0.009 0.011 0.013 Near End Coupling Far End Coupling 0 200 400 600 800 1000 1200 1400 1600 1800 2000 Time [psec] b c d e B C 0 D A D E G ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.5 2.0 Connector System IEC 61076-4-101 0 A A A M A L A A 25 50 C A A B A B B 75 * 100 ** N A A A A 125 150 B B A B 175 200 C A L A 225 * 250 ** * total length for Europa cards ** total length for ETSI PCB`s System modularity B B ept-hm 2.0 modules offer a great versatility to optimize large contact densities. Especially the combination with coaxial or fiberoptic connections. Stacking can be arranged from 50 mm using type A module, increasing in 25 mm steps to required lengths. 275 300 A A 325 Connectors with multifunction block (type A, M, L) are preferably used at the top of any column. Type B is only used between other modules. 350 The modules type C and N (25 mm) are polarized and are used at the bottom end of the columns. Correct mating is assured by use of coding keys within the multifunction block and by use of type C and N modules. A 375 400 2.6 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Dimensions of Contacts Contact Options Front mating Used for 8,25–0,1 signal contact 9,75–0,1 signal contact C 11,25–0,1 shielding K 8,25–0,1 signal contact 9,75–0,1 signal contact M 11,25–0,1 shielding N 8,25–0,1 signal contact 9,75–0,1 signal contact Q 11,25–0,1 shielding R 8,25–0,1 signal contact 9,75–0,1 signal contact 11,25–0,1 shielding A B L P S T without mating area with mating area 13 mm with mating area 14,5 mm with mating area 16 mm ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.7 2.0 Connector System IEC 61076-4-101 Male Connectors Type A Dimensions in mm Printed Circuit Layout 2.8 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Assembly Drawing No. of Positions Row Type Pin length Part Numbers 110 z a b c d e f A A A A A - -/8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 -/- 243-11010-15 110 z a b c d e f B B B B B - -/9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 -/- 243-11020-15 154 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-11310-15 154 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-11320-15 154 z a b c d e f C B * * * B C 11,25/3,7 9,75/3,7 * * * 9,75/3,7 11,25/3,7 243-11322-15 100 z a b c d e f – * * * * * * – * * * * * * 243-11323-15 154 z a b c d e f T P P P P P T 11,25/16,0 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 11,25/16,0 243-11360-15 154 z a b c d e f T N N N N N T 11,25/16,0 8,25/14,5 8,25/14,5 8,25/14,5 8,25/14,5 8,25/14,5 11,25/16,0 243-11735-15 cPCI Hot Swap cPCI Telephony Spec. * Attention: Please consider the different pin length in the assembly drawing. Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-700-W25 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.9 2.0 Connector System IEC 61076-4-101 Female Connectors Type A Dimensions in mm Printed Circuit Layout Type No. of Positions connector without shielding 110 connector with shielding connector with shielding cPCI Telephony Spec. lower shield 26 110 90 Quality Class Part Numbers I 244-11000-18 II 244-11000-15 I 244-11300-18 II 244-11300-15 I 244-11305-18 II 244-11305-15 244-11600-1 ept Guglhör Peiting GmbH&Co. • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de Engineering Notes ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.11 2.0 Connector System IEC 61076-4-101 Male Connectors Type B Dimensions in mm Printed Circuit Layout Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-701-W25 Assembly Drawing 2.12 No. of Positions Row Type Pin length Part Numbers 125 z a b c d e f – A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 243-21010-15 125 z a b c d e f – B B B B B – –/– 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 –/– 243-21020-15 175 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-21310-15 175 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-21320-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type B Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers without shielding 125 244-21000-15 with shielding 125 244-21300-15 lower shield 244-21600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.13 2.0 Connector System IEC 61076-4-101 Male Connectors Type B-22 (Compact PCI P2/P5) Dimensions in mm Printd Circuit Layout Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-701-W22 Assembly Drawing No. of Positions Row Type Pin lenght Part Numbers 154 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-22310-15 154 z a b c d e f C * * * * * C 11,25/3,7 * * * * * 11,25/3,7 243-22311-15 154 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-22320-15 154 z a b c d e f T P P P P P T 11,25/16,0 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 11,25/16,0 243-22360-15 cPCI Telephony Spec. 2.14 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type B-22 (Compact PCI J2/J5) Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers without shielding 110 244-22000-15 with shielding 110 244-22300-15 lower shield 244-22600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.15 2.0 Connector System IEC 61076-4-101 Male Connectors Type B-19 (VME J0 and C-PCI P3) Dimensions in mm Printed Circuit Layout Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-701-W19 Assembly Drawing 2.16 No. of Positions Row Type Pin length Part Numbers 95 z a b c d e f – A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 243-23010-15 133 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-23310-15 133 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-23320-15 133 z a b c d e f T P P P P P T 11,25/16,0 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 11,25/16,0 243-23360-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type B-19 (VME P0 and C-PCI J3) Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers without shielding 95 244-23000-15 with shielding 95 244-23300-15 lower shield 244-23600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.17 2.0 Connector System IEC 61076-4-101 Male Connectors Type C Dimensions in mm Printed Circuit Layout Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-702-W11 Assembly Drawing 2.18 No. of Positions Row Type Pin length Part Numbers 55 z a b c d e f – A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 243-31010-15 55 z a b c d e f – B B B B B – –/– 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 –/– 243-31020-15 77 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-31310-15 77 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-31320-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type C Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers without shielding 55 244-31000-15 with shielding 55 244-31300-15 lower shield 244-31600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.19 2.0 Connector System IEC 61076-4-101 Male Connectors Type AB-25 Dimensions in mm Printed Circuit Layout Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-701-W25 Assembly Drawing 2.20 No. of Positions Row Type Pin length Part Numbers 125 z a b c d e f – A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 243-61010-15 169 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-61310-15 169 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-61320-15 169 z a b c d e f T P P P P P T 11,25/16,0 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 11,25/16,0 243-61360-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type AB-25 Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connectors without shielding 125 244-61000-15 connectors with shielding 125 244-61300-15 lower shield 244-11600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.21 2.0 Connector System IEC 61076-4-101 Male Connectors Type AB-22 Dimensions in mm Printed Circuit Layout Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-701-W22 Assembly Drawing 2.22 No. of Positions Row Type Pin length Part Numbers 110 z a b c d e f – A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 243-62010-15 146 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-62310-15 146 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-62320-15 146 z a b c d e f T P P P P P T 11,25/16,0 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 11,25/16,0 243-62360-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type AB-22 Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connectors without shielding 110 244-62000-15 connectors with shielding 110 244-62300-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.23 2.0 Connector System IEC 61076-4-101 Male Connectors Type AB-19 Dimensions in mm Printed Circuit Layout Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part No. 884-701-W19 Assembly Drawing 2.24 No. of Positions Row Type Pin length Part Numbers 95 z a b c d e f – A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 243-63010-15 127 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-63310-15 127 z a b c d e f C B B B B B C 11,25/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 9,75/3,7 11,25/3,7 243-63320-15 127 z a b c d e f T P P P P P T 11,25/16,0 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 11,25/16,0 243-63360-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type AB-19 Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connectors without shielding 95 244-63000-15 connectors with shielding 95 244-63300-15 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.25 2.0 Connector System IEC 61076-4-101 Male Connectors Type Compact PCI (P1+P2/P4+P5) Dimensions in mm Printed Circuit Layout Assembly Drawing Type Pin length Part Numbers 308 z a b c d e f C B * * * B C 11,25/3,7 9,75/3,7 * /3,7 * /3,7 * /3,7 9,75/3,7 11,25/3,7 243-12322-15 308 z a b c d e f C A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 243-12310-15 308 z a b c d e f T P P P P P T 11,25/16,0 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 9,75/14,5 11,25/16,0 243-12360-15 No. of Pos. Row * Attention: Please consider the different pin length in the assembly drawing. Is used for Compact PCI Insertion Tool: Part No. 884-703-W47 On Request: Telephony Spec./Hot Swap Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 2.26 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de Engineering Notes ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.27 2.0 Connector System IEC 61076-4-101 Male Connectors Type D Dimensions in mm Printed Circuit Layout Assembly Drawing No. of Positions Row Type Pin length Part Numbers 176 z a b c d e f g h y – A A A A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 245-11010-15 220 z a b c d e f g h y C A A A A A A A A C 11,25/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 11,25/3,7 245-11310-15 Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part Number 884-710-W25 2.28 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type D Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connector without shielding 176 246-11000-15 connector with shielding 176 246-11300-15 lower shield 246-11600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.29 2.0 Connector System IEC 61076-4-101 Male Connectors Type E Dimensions in mm Printed Circuit Layout Assembly Drawing No. of Positions Row Type Pin length Part Numbers 200 z a b c d e f g h y – A A A A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 245-21010-15 250 z a b c d e f g h y C A A A A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 245-21310-15 Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: Part Number 884-711-W25 2.30 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type E Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connector without shielding 200 246-21000-15 connector with shielding 200 246-21300-15 lower shield 246-21600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.31 2.0 Connector System IEC 61076-4-101 Male Connectors Type F Dimensions in mm Printed Circuit Layout Assembly Drawing No. of Positions Row Type Pin length Part Numbers 88 z a b c d e f g h y – A A A A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 245-31010-15 110 z a b c d e f g h y C A A A A A A A A C 11,25/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 8,75/3,7 11,25/3,7 245-31310-15 Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: 2.32 Part Number 884-713-W11 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type F Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connector without shielding 88 246-31000-15 connector with shielding 88 246-31300-15 lower shield 246-31600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.33 2.0 Connector System IEC 61076-4-101 Male Connectors Type DE Dimensions in mm Printed Circuit Layout Assembly Drawing No. of Positions Row Type Pin length Part Numbers 200 z a b c d e f g h y – A A A A A A A A – –/– 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 –/– 245-61010-15 244 z a b c d e f g h y C A A A A A A A A C 11,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 8,25/3,7 11,25/3,7 245-61310-15 Note: PCB thickness 1,6 - 2,8 mm Part No. XXX-XXXXX-05 Insertion Tool: 2.34 Part Number 884-712-W25 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type DE Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connector without shielding 200 246-61000-15 connector with shielding 200 246-61300-15 lower shield Insertion tool: 246-11600-1 Part Number ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.35 2.0 Connector System IEC 61076-4-101 Male Connectors Type L Dimensions in mm Printed Circuit Layout Assembly Drawing No. of Positions 6 Insertion Tool: 2.36 Row special contact Part Number power / cable contacts 243-51000 pressfit coax 243-53000 – Part Number 884-707-W1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type L Dimensions in mm Printed Circuit Layout Type No. of Positions Part Number connector without shielding 6 244-51000 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.37 2.0 Connector System IEC 61076-4-101 Male Connectors Type M Dimensions in mm Printed Circuit Layout Assembly Drawing No. of Positions Row Type 55+3 z a b c d e f – A A A A A – –/– power / 8,25/3,7 8,25/3,7 cable contacts 8,25/3,7 8,25/3,7 8,25/3,7 pressfit coax –/– z a b c d e f C A A A A A C 11,25/3,7 power / 8,25/3,7 8,25/3,7 cable contacts 8,25/3,7 8,25/3,7 8,25/3,7 pressfit coax 11,25/3,7 77+3 Insertion Tool: 2.38 Pin length special contacts Part Numbers 243-41010-15 243-42010-15 243-41310-15 243-42310-15 Part Number 884-707-W2 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type M Dimensions in mm Printed Circuit Layout Type No. of Positions Part Numbers connector without shielding 55+3 244-41000-15 connector with shielding 55+3 244-41300-15 lower shield 244-31600-1 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.39 2.0 Connector System IEC 61076-4-101 Male Connectors Type N Dimensions in mm Printed Circuit Layout Assembly Drawing No. of Positions 3 Insertion Tool: 2.40 Row special contact Part Number power / cable contacts 243-52000 pressfit coax 243-54000 – Part Number 884-707-W3 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Female Connectors Type N Dimensions in mm Printed Circuit Layout Type No. of Positions Part Number connector without shielding 3 244-52000 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.41 2.0 Connector System IEC 61076-4-101 High Current Contacts for use with Type L, M and N Solder Contact Press-fit Contact Press-fit Contact Silicon Rubber 3.57 6.07 Mating Area Au over Ni 17.17 4.75 5.21 Printed Circuit Layout Printed Circuit Layout min. 0.1 3.5–0.076 5-12 m Sn Dimensions in mm Termination Methods min. 2.36 Pressfit Area Au over Ni 3.76 25-80 m Cu Operating Current Part Numbers Solder Female Contact 30 A 916-42002 40 A 916-62002 40 A 915-61002 Press-fit Female Contact Press-fit Male Contact 2.42 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Coaxial Contacts for use with Type L, M and N for female connectors for male connectors Printed Circuit Layout Printed Circuit Layout Dimensions in mm Termination Methods for male connectors 243-42... / 243-53... / 243-54... Impedance Part Numbers 50 W 916-63002 50 W 915-64002 for female connectors ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.43 2.0 Connector System IEC 61076-4-101 Shrouds for Male Connectors Type A, B, B-22, B-19 and C Dimensions in mm PCB thickness < 4,8 mm X 6,3 mm 4,9 mm 4,5 mm 3,7 mm 2,9 mm Shroud 16,75 mm 15,35 mm 14,95 mm 14,15 mm 13,35 mm 243-5525-2 243-5525-3 Part Numbers Connector Type A On request: 2.44 243-5525-5 243-5525-4 243-5525-1 B - - 243-5625-1 243-5625-2 243-5625-3 B-22 243-5622-5 243-5622-4 243-5622-1 243-5622-2 243-5622-3 B-19 243-5619-5 243-5619-4 243-5619-1 243-5619-2 243-5619-3 C - - 243-5511-1 243-5511-2 243-5511-3 other hights and special shrouds ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Shrouds for Male Connectors Type AB Dimensions in mm PCB thickness < < 3,2 mm 3,2 - 4 mm 4,0 - 4,8 mm > 4,8 mm X 6,3 mm 4,9 mm 4,5 mm 3,7 mm 2,9 mm Shroud hight 16,75 mm 15,35 mm 14,95 mm 14,15 mm 13,35 mm Part Numbers Connector Type AB-25 - - 243-5725-1 243-5725-2 243-5725-3 AB-22 243-5722-5 243-5722-4 243-5722-1 243-5722-2 243-5722-3 AB-19 243-5719-5 243-5719-4 243-5719-1 243-5719-2 243-5719-3 On request: other hights and special shrouds ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.45 2.0 Connector System IEC 61076-4-101 Overview compactPCI Connectors Female connector for daughter card Location Shielding ept Part Number J1 / rJ1 / J4 / rJ4 With upper shield 244-11300-15 J2 / J5 With upper shield 244-22300-15 rJ2 / rJ5 With upper shield 244-62300-15 Type B19 J3 With upper shield 244-23300-15 Type AB19* rJ3 With upper shield 244-63300-15 Type A for telephony J4 With split shield 244-11305-15 Type A for telephony (mirrored) rJ4 With split shield 244-11306-15 Location Contact loading * ept Part Number Type A Hot Swap P1 CB***BC 243-11322-15 Type A Hot Swap for Midplane P1 TP***PT 243-11710-15 P1+P2 TP***PT 243-12322-15 P2 CBBBBBC 243-22320-15 Type B22 AB compatible P2 / P5 *PPPPP* 243-22361-15 Type B22 AB compatible P2 / P5 *NNNNN* 243-22734-15 Type B22 AB compatible P2 / P5 *SSSSS* 243-22371-15 Type B19 P3 CBBBBBC 243-23320-15 Type B19 AB compatible P3 *PPPPP* 243-23361-15 Type B19 AB compatible P3 *NNNNN* 243-23712-15 Type B19 AB compatible P3 *SSSSS* 243-23371-15 Type A for telephony P4 -****** 243-11323-15 Type A for telephony Midplane P4 -****** 243-11709-15 Type A P4 TPPPPPT 243-11360-15 Type A P4 TNNNNNT 243-11734-15 Type A P4 TSSSSST 243-11715-15 Type B22 for telephony P5 C*****C 243-22311-15 Type B22 for telephony, Z row not loaded P5 -*****C 243-22312-15 Type B22 for telephony, Z row not loaded P5 -****** 243-22351-15 Type A Type B22 Type AB22* * AB connector are used for rear transition cards if AB shrouds are used all connectors are also available without upper shield Male connector for Backplane Type monoblock Hot Swap Type B22 *different pins in that row / - not loaded all connectors are also without Z row loaded available / for other pin arrangements consult ept 2.46 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Coding keys Color application ept Part Number Male Backplane Brilliant Blue 5V – P1 243-8014 Male Backplane Cadmium Yellow 3,3V – P1 243-8031 Male Backplane Strawberry red Telephony – P4 243-8012 Female Daughtercard Brilliant Blue 5V – J1 244-8014 Female Daughtercard Cadmium Yellow 3,3V – J1 244-8031 Female Daughtercard Strawberry red Telephony – J4 244-8012 Shrouds Location height Base thickness ept Part Number Type A P1 / P4 16,75 mm 6,3 mm 243-5525-5 Type A P1 / P4 15,35 mm 4,9 mm 243-5525-4 Type A P1 / P4 14,95 mm 4,5 mm 243-5525-1 Type A P1 / P4 14,15 mm 3,7 mm 243-5525-2 Type A P1 / P4 13,35 mm 2,9 mm 243-5525-3 Type AB22 P2 / P5 16,75 mm 6,3 mm 243-5722-5 Type AB22 P2 / P5 15,35 mm 4,9 mm 243-5722-4 Type AB22 P2 / P5 14,95 mm 4,5 mm 243-5722-1 Type AB22 P2 / P5 14,15 mm 3,7 mm 243-5722-2 Type AB22 P2 / P5 13,35 mm 2,9 mm 243-5722-3 Type AB19 P3 16,75 mm 6,3 mm 243-5719-5 Type AB19 P3 15,35 mm 4,9 mm 243-5719-4 Type AB19 P3 14,95 mm 4,5 mm 243-5719-1 Type AB19 P3 14,15 mm 3,7 mm 243-5719-2 Type AB19 P3 13,35 mm 2,9 mm 243-5719-3 The height / base thickness of the shrouds depend on the thickness of the Backplane ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.47 2.0 Connector System IEC 61076-4-101 Coding Devices Male connectors Coding key 2.48 Female connectors Code No. Colour Part Numbers Code No. Colour Part Numbers 1236 Nut brown RAL 8011 243-8011 4578 Nut brown RAL 8011 244-8011 1248 Strawberry red RAL 3018 Telephony Spec. 243-8012 3567 Strawberry red RAL 3018 Telephony Spec. 244-8012 1356 Blue lilac RAL 4005 243-8013 2478 Blue lilac RAL 4005 244-8013 1567 Brillant blue RAL 5007 5,0 V C-PCI 243-8014 2348 Brilliant blue RAL 5007 5,0 V C-PCI 244-8014 2578 Reseda green RAL 6011 243-8021 1346 Reseda green RAL 6011 244-8021 3456 Cadmium yellow RAL 1021 3,3 V C-PCI 243-8031 1278 Cadmium yellow RAL 1021 3,3 V C-PCI 244-8031 3467 Slate grey RAL 7015 243-8032 1258 Slate grey RAL 7015 244-8032 3478 Steel blue RAL 5011 243-8033 1256 Steel blue RAL 5011 244-8033 3568 Pastel orange RAL 2003 243-8034 1247 Pastel orange RAL 2003 244-8034 4678 Ocher yellow RAL 1024 243-8041 1235 Ocher yellow RAL 1024 244-8041 Coding key ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Fax request (5+2) Company Phone Number First Name Last Name Fax Number Adress E-Mail Adress Signature Please quote me for _________________ pieces. Please send me ________________ sample pieces. Male-Type A B C K L M N P Q Assembly reference: R S T In order to be able to load the connectors economically we recommend a serial determination of the contact length. If only position 1 of a line is indicated, the entire line is loaded with this contact length. Exceptions can be registered at the respective position. Surface: Quality level 2 acc. to IEC 61076-4-101. Au over PdNi over Ni. ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.49 2.0 Connector System IEC 61076-4-101 Fax request (8+2) Company Phone Number First Name Last Name Fax Number Adress E-Mail Adress Signature Please quote me for _________________ pieces. Please send me ________________ sample pieces. Male-Type A B C K L M N P Q R S T Assembly reference: In order to be able to load the connectors economically we recommend a serial determination of the contact length. If only position 1 of a line is indicated, the entire line is loaded with this contact length. Exceptions can be registered at the respective position. Surface: Quality level 2 acc. to IEC 61076-4-101. Au over PdNi over Ni. 2.50 ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.0 Connector System IEC 61076-4-101 Fax request AB Company Phone Number First Name Last Name Fax Number Adress E-Mail Adress Signature Please quote me for _________________ pieces. Please send me ________________ sample pieces. Male-Type A B C K L M N P Q R S T Assembly reference: In order to be able to load the connectors economically we recommend a serial determination of the contact length. If only position 1 of a line is indicated, the entire line is loaded with this contact length. Exceptions can be registered at the respective position. Surface: Quality level 2 acc. to IEC 61076-4-101. Au over PdNi over Ni. ept GmbH & Co. KG • Phone 0 88 61/25 01-0 • Fax 0 88 61/55 07 • E-Mail sales@ept.de • http://www.ept.de 2.51
244-61300-15 价格&库存
很抱歉,暂时无法提供与“244-61300-15”相匹配的价格&库存,您可以联系我们找货
