1270780
1270780
    BRENNENSTUHL
    BRENNENSTUHL - 1270780 - LED, Oval, 5.5 W, IP 44, 70 mm x 175 mm x 127 mm
1270780 数据手册
Our classic light now also with LEDs! Oval LED light L DN 3002 IP44 / L DN 5402 IP44 Technical Highlights         Ideal for garage, basement, workshop or outside. Compact LED oval lamp made of plastic with a translucent cover. Can be mounted on the ceiling or wall. Uses approx. 80% less energy than conventional light sources. Instant bright light. Extremely long LED service life, impact-proof, maintenance-free. Color: light gray With GS certificate Specifications Type Item No. EAN Supply voltage Output Light current Efficiency Weighted energy consumption Energy efficiency category Color temperature Protection class LED service life Beam angle Protection class Operating temperature Dimensions Weight L DN 3002 IP44 L DN 5402 IP44 1270780 4007123641680 220–240V 50Hz 5.5W 460 lm 84 lm/W 5.5 kWh/1000h 1270790 4007123641697 220–240V 50Hz 10W 800 lm 80 lm/W 10 kWh/1000h A+ 6400K IP44 50,000 hrs > 120° II -15°C – +40 °C 12.7 x 7.0 x 17.5 cm 0.2kg A+ 6400K IP44 50,000 hrs > 120° II -15°C – +40 °C 12.7 x 7.0 x 17.5 cm 0.25kg Content/ Item No./ EAN   Colorful display carton Item No. / EAN see above   PU: 1 Available February 2017 2
1270780 价格&库存
很抱歉,暂时无法提供与“1270780”相匹配的价格&库存,您可以联系我们找货
