1172900301
1172900301
    BRENNENSTUHL
    BRENNENSTUHL - 1172900301 - PIR FLOODLIGHT, 6500K, 2530LM, 30W, 12M
1172900301 数据手册
LED light in a particularly slim design! Slim LED floodlight Technical highlights        For wall mounting, indoor and outdoor, IP54 User-friendly assembly thanks to functional connection box Sturdy, state-of-the-art aluminium casing, particularly slim design Adjustable holding bracket for assembly With 30cm cable and connection box This floodlight includes integrated LED lamps The lamps cannot be exchanged in floodlight Technical data Supply voltage: Cable length: Cable designation: Colour temperature: Colour rendering index: IP class: Life cycle LED: Radiation angle: Swivel range, vertical: Protection class: Operating temperature: Colour: 230V, 50/60Hz 30cm H05RN-F 3G1.0 6500K 80 IP54 50,000h 110° 180° I -10°C ~ +40°C silver Versions without motion sensor (PIR): Type designation L DN 2810 FL DE 3925 Power 1172900100 4007123649853 10W LEDs 28 x 0.36W Art. no. EAN Luminous flux Efficiency, lamp total energy consumption Energy efficiency class Dimensions Weight L DN 5630 FL DE 3925 1172900300 4007123649891 30W 56 x 0.5W L DN 9850 FL DE 3925 1172900500 4007123649921 50W 98 x 0.5 W 950lm 2530lm 4750lm 95 lm/W 84 lm/W 96 lm/W 9.9kWh / 1000h 30.2kWh / 1000h 49.2kWh / 1000h A+ A A+ 13.6x14.7x4.1cm 0.5kg 20.2x23.1x3.5cm 1.3kg 23.5x27.7x4.0cm 2.0kg 3 Versions with motion sensor (PIR): Type designation Art. no. EAN Power LEDs Luminous flux Efficiency, lamp total energy consumption Energy efficiency class Detection range PIR Detection angle PIR L DN 2810 FL PIR DE 3925 1172900101 4007123649860 10W L DN 5630 FL PIR DE 3925 1172900301 4007123649907 30W L DN 9850 FL PIR DE 3925 1172900501 4007123649914 50W 28 x 0.36W 56 x 0.5W 98 x 0.5 W 950lm 2530lm 4750lm 95 lm/W 84 lm/W 96 lm/W 9.9kWh / 1000h 30.4kWh / 1000h 49.2kWh / 1000h A+ A A+ max. 12m max. 12m max. 12m 90° 90° 90° Duty-cycle PIR 10sec ~ 5 min 10sec ~ 5 min 10sec ~ 5 min Swivel range PIR 180° horizontal 180° horizontal 180° horizontal 16.6x14.7x4.3cm 0.5kg 25.2x23.1x4.1cm 1.4kg 29.0x27.7x4.1cm 2.1kg Dimensions Weight Scope of delivery / art. No. / EAN no.   Packed in a coloured sales cardboard box Art. no./ EAN see at top   PU: 1 Available from September 2017 4
1172900301 价格&库存
很抱歉,暂时无法提供与“1172900301”相匹配的价格&库存,您可以联系我们找货
