1175603
1175603
    BRENNENSTUHL
    BRENNENSTUHL - 1175603 - Work Light, LED, Tripod, 240 V, 20 W, 2 m Length, UK Plug - Work Light, LED...
1175603 数据手册
Tripod work lamp with super-bright SMD LEDs Tripod SMD LED light SL DN 2806 S IP 54 1175600 Characteristics • High-quality SMD LEDs from LG Innotek • Casing made of aluminum pressure casting, surface coated. • On/Off switch for light on the back. • Floodlight can be pivoted and locked in place steplessly. • Front pane made of safety glass. • Very stable, robust tripod • Stable steel pipe, powder coated • Stepless height adjustment from 0.9m to 2m. • Handy, reliable pipe clamping nuts. SL DN 2806 S IP54 Technical highlights • • Brand-name SMD LEDs from LG Innotek with a high degree of efficiency GS-certified product (light L DN 2806 S IP54) Technical specifications • • • • • • • • • • • • • • • • • Art. No.: Type description: LEDs: Power input: Flux: Efficiency: Weighted energy consump.: Energy efficiency class: Type of protection: Supply voltage: Color temperature: LED service life: Radiation angle: Protection class: Connection cable: Tripod height: Weight: 1175600 SL DN 2806 S IP54 (light: L DN 2806 S IP54) 28 x 0.6W SMD 20 W 1720 lm 86 lm/W 22 kWh/1000h A IP 54 220-240 V~ 50/60 Hz 5700 K 50,000 hrs approx. 110° I 3m H05RN-F3G1,0 0.9m bis 2m approx. 3.9 kg
1175603 价格&库存
很抱歉,暂时无法提供与“1175603”相匹配的价格&库存,您可以联系我们找货
