24DF10-120DFV
24DF10-120DFV
    AMPERITE
24DF10-120DFV 数据手册
Solving your relay requirements since 1922 DFV Series Flasher Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com … Solid state analog flasher circuitry … DPDT (2 form C) isolated 10 ampere relay contacts … Variable flash rate: standard flash rate range 10-120 F.P.M. … Single knob adjustment on top of unit … 12V to 120V input voltage available - both AC & DC models … UL File #E96739 (M) … CSA File #LR62586 Timing Mode: On/off adjustable recycling flasher. The flash rate is adjustable from 10 to 120 flashes per minute (FPM). Custom rates are available within ranges between minimum of 1 FPM & maximum of 240 FPM. Duty cycle is 50%. Flash rate is adjustable by means of a knob potentiometer on top of the unit. Timing diagram: Contact Information: Arrangement: 2 form C (DPDT) - Diagram C Contact Material: Silver - Cadmium Oxide Rating (Resistive): 10A @ 240V AC Resistive 15A @ 30V DC Resistive 15A @ 120V AC Resistive 1/3 HP @ 120V AC 1/2 HP @ 250V AC Expected Life @ 25°C : 10 Million operations, Mechanical 100,000 operations minimum at rated loads Environmental Information: Temperature Range: Storage: -60°C to +105°C (-76°F to +221°F) Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Operating: -45°C to +70°C (-49°F to +158°F) Mechanical Information: Termination: 8 pin Octal Style Plug or 11 pin spade terminals (Diagram C & D). Enclosure: White plastic case with a dial scale for knob adjustment, reference only. LDFV version has a black case. Weight: 4 oz (114g) approx. Outline Dimensions: Timing Specifications: Flash Rate - Adjustable: Standard - 10 to 120 flashes per minute (FPM). Custom rates are available within ranges between minimum of 1 FPM and a maximum of 240 FPM. Timing Adjustment: Knob adjustable potentiometer. Initial Dielectric Strength: Between open contacts: 1000V RMS, Between adjacent contacts: 1500V RMS, Between contacts & coil: 1500V RMS Input Information: Voltage: AC units- 12V, 24V, and 120V; DC units- 12V, 24V, 48V and 110V. Other voltages are available. Power Requirement: AC units: 3 VA or less; DC units: 3 Watts or less Transient Protection: 1 JOULE MOV Polarity Protection: On DC units - Yes Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Input Voltages & Limits: Nominal Minimum Maximum 12V AC 10V 14V 24V AC 20V 28V 120V AC 105V 130V 12V DC 11V 14V 24V DC 20V 32V 48V DC 41V 55V 110V DC 95V 125V Wiring Diagrams: Ordering Information: Definition of a part number for the Amperite DFV Series Adjustable Flasher. Example: A: Denotes nominal input voltage. Voltages Available: 12, 24 & 120V AC; 12, 24, 48 & Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com 110V DC. Custom Voltages are available. B: Denotes type of input current required for operation: A = AC - Alternating Current, D = DC - Direct Current C: Denotes flasher configuration. D & E: Denotes range of knob adjustability for flash rate where: D = Minimum number of flashes per minute (FPM). E = Maximum number of flashes per minute (FPM). Note: Standard rate is from 10 to 120 FPM. Custom rates are available within ranges between minimum of 1 FPM and a maximum of 240 FPM. F: Enter "L" if optional 11-pin spade terminals are required (Diagrams B & D). G: Denotes 10A DPDT (2 form C) adjustable flasher - DFV Series. Solving Your Relay Requirements Since 1922
24DF10-120DFV 价格&库存
很抱歉,暂时无法提供与“24DF10-120DFV”相匹配的价格&库存,您可以联系我们找货
