115NO15
115NO15
    AMPERITE
115NO15 数据手册
Solving your relay requirements since 1922 G Series TDR Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com … Hermetically sealed … Delay on Make or Delay on Break timing modes … Thermal device … 3 AMP rating … 1 - 115V input voltage range - works on AC or DC … Isolated output contacts … Fixed delay times only … Initial and reset (release) delay device … Long life … UL File #E96739 (M) Timing Mode: Timing cycle begins upon application of power to the heater terminals. At the end of the initial delay time the relay contacts transfer and remain in a transferred state until input power is removed. When the heater input power is removed, the contacts transfer back to their original state at the end of a reset (release) delay period. Timing Diagram: Contact Information: Arrangement: 1 form A (SPST - Normally open) - Delay on Make 1 form B (SPST - Normally closed) - Delay on Break Contact Material: Silver - Cadmium Oxide Rating (Resistive): 3A @ 115V AC Expected Life @ 25°C: 500,000 operations minimum at rated loads Environmental Information: Temperature Range: Operating & storage: -55°C to +80°C, (-67°F to +176°F) Mechanical Information: Termination & Enclosure: Octal style, or 9-pin miniature style glass envelope. See Diagram A & B. Weight: 1 oz. (28g) Outline Dimensions: Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Timing Specifications: Timing - Fixed: 1 through 300 secs. - (octal style) or 1 - 120 secs. (9-pin miniature style) Timing Tolerance: ±20% - Tighter tolerances are available. Repeatability: ±5% Release Time: Contact factory Timing Cycle Interrupt Transfer: none Initial Dielectric Strength: 1-10 Second Type: Between open contacts: 250V RMS; Between contacts & coil: 500V RMS 15 - 300 Second Type: Between open contacts: 800V RMS; Between contacts & coil: 500V RMS Input Information: Voltage: AC or DC - 6V, 12V, 26V, 50V and 115V. Other voltages are available. Power Requirement: 2.0 Watts approx. Transient Protection: impervious to transients Polarity Protection: None required Input Voltages & Limits: Nominal Minimum Maximum 6V AC/DC 4V 8V 12V AC/DC 10V 14V 26V AC/DC 22V 30V 50V AC/DC 42 58V Solving your relay requirements since 1922 115V AC/DC 90V Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com 130V Wiring Diagrams: Ordering Information: Definition of a part number for the Amperite G Series Time Delay Relay. Example: A: Denotes nominal Input voltage. Voltages Available: 6, 12, 26, 50 & 115V AC/DC. Custom Voltages are available. B: Denotes contact form: NO = normally open (Delay on Make) -1 form A - SPST C = normally closed (Delay on Break) -1 form B - SPST C: Denotes timing value: Factory preset time delays from 1 - 300 secs. are available (octal style) and 1 - 120 secs. (9-pin miniature style) D: Denotes type of glass envelope: Blank = octal style. T = 9-pin miniature style. Solving your relay requirements since 1922 Solving Your Relay Requirements Since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com
115NO15 价格&库存
很抱歉,暂时无法提供与“115NO15”相匹配的价格&库存,您可以联系我们找货
