120A A/A DFA
120A A/A DFA
    AMPERITE
    AMPERITE - 120A A/A DFA - TIME DELAY RELAY, DPDT, 10S, 240VAC
120A A/A DFA 数据手册
Solving your relay requirements since 1922 DFA Series Adjustable Recycling Timer Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com … Solid state CMOS digital recycle (flasher) timer circuitry … DPDT (2 form C) isolated 10 ampere relay contacts … Off and On time-user adjustable over a 100:1 span … 12V to 120V input voltage available-both AC and DC models … UL File #E96739 (M) … CSA File #LR62586-5 The Amperite DFA series adjustable recycling timers provide a continuously operating off/on cycle as long as power is applied to the input terminals. Two knob operated potentiometers provide user adjustment of both the flash rate and duty cycle. One knob sets the Off time; the other sets the On time. Standard models allow both the Off time and On time to be adjusted over a 100:1 range. Custom timing is available. Timing Mode: Off/On recycling (flasher) timer. The initial timing period, after application of power, is "off". An option allows the unit to cycle "on" upon application of power. Standard timing ranges (Off and On time) are as follows: A: 0.1 second to 10 seconds G: 1 - 4 hours B: 0.25 second to 25 seconds H: 14.4 minutes to 24 hours C: 0.6 second to 60 seconds I: .6 minutes to 60 minutes D: 1.2 second to 120 seconds J: .1 minute to 10 minutes E: 1.8 second to 180 seconds K: 10 minutes to 24 hours F: 1 minute to 100 minutes M: 1 - 10 hours Custom Timing Is Available. Fixed timing is available from 0.1 secs thru 240 Hrs. If Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com fixed timing is desired, please indicate S for secs., M for mins., & H for hours. Timing Diagram: Contact Information: Arrangement: 2 form C (DPDT) - Diagram C Contact Material: Silver - Cadmium Oxide Rating (Resistive): 10A @ 240V AC Resistive 15A @ 30V DC Resistive 15A @ 120V AC Resistive 1/3 HP @ 120V AC 1/2 HP @ 250V AC Expected Life @ 25°C : 10 Million operations, Mechanical 100,000 operations minimum at rated loads Environmental Information: Temperature Range: Storage: -60°C to +105°C (-76°F to +221°F); Operating: -45°C to +70°C (-49°F to +158°F) Mechanical Information: Termination: 8 pin Octal Style Plug or 11-pin spade terminals (Diagram C & D) Enclosure: White plastic case. Knob adjustable models have a dial scale for reference only. LDFA version has a black case. Weight: 4 oz (114g) approx. Timing Specifications: Timing - Fixed: 0.1 secs thru 240 Hrs. Timing Adjustment: Two (2) knob adjustable potentiometers. Timing Ranges: See Above. Timing Tolerance: Fixed Units: ± 5%; 1% units are available at extra cost. Adjustable Units: -0 to +10% of maximum specified delay time. Minimum specified value or less at low end. Repeatability: ± 1% Release Time: 60 ms typical, 100 ms maximum Timing Cycle Interrupt Transfer: None Reset: Upon interruption of power Initial Dielectric Strength: Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Between open contacts: 1000V RMS Between adjacent contacts: 1500V RMS Between contacts & coil: 1500V RMS Input Information: Voltage: AC units- 12V, 24V and 120V; DC units- 12V, 24V, 48V and110V. Custom voltages are available. Power Requirement: AC units: 3 VA or less DC units: 3 Watts or less Transient Protection: 1 JOULE MOV, Polarity Protection: On DC units - Yes Input Voltages & Limits: Nominal Minimum Maximum 12V AC 10V 14V 24V AC 20V 28V 120V AC 105V 130V 12V DC 11V 14V 24V DC 20V 32V 48V DC 41V 55V 110V DC 95V 125V Outline Dimensions: Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Wiring Diagrams: Ordering Information: Definition of a part number for the Amperite DFA Series recycling Flasher. Example: A: Denotes nominal input voltage. Voltages Available: 12, 24, & 120V AC; 12, 24, 48 & 110V DC. Custom Voltages are available. B: Denotes type of input current required for operation: A = AC - Alternating Current D = DC - Direct Current C: Denotes first timing period. See timing mode chart above for proper code letter. For standard units this is an "OFF"time delay. Fixed timing available. If fixed timing is desired, please indicate S for secs., M for mins., or H for hours. Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com D: Denotes second timing period. For standard units this is an "ON" timing period. Fixed timing available. *Note: If the ON time delay period is desired to occur first upon application of input power, place an "R" after the second timing period code letter, and enter range for ONTIME in "C" & OFF-TIME in "D". E: Enter "L" if optional 11-pin spade terminals are required (Diagrams B & D). F: Denotes 10 ampere 2 form C adjustable recycle flasher - DFA Series. Solving Your Relay Requirements Since 1922
120A A/A DFA 价格&库存
很抱歉,暂时无法提供与“120A A/A DFA”相匹配的价格&库存,您可以联系我们找货
