24D1-10MHDOD
24D1-10MHDOD
    AMPERITE
24D1-10MHDOD 数据手册
Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 Solving your relay requirements since 1922 HDOD Series Delay-On-Dropout Time Delay Relay Solid state CMOS digital circuitry True delay on dropout: Timing cycle after power removal DPDT (2 form C) isolated 4 ampere relay contacts Built-in timing adjust potentiometer Numerous models from 0.1 seconds to hours Timing Mode Upon the application of input voltage the relay immediately energizes. The timing cycle begins when input voltage is removed. When the timing cycle is complete, the relay will de-energize TIMING DIAGRAM: CONTACT INFORMATION Arrangement: 2 form C (DPDT) Contact material: Gold Clad Silver Alloy Rating: Maximum Switching Power - 1000 VA, 90W (Resistive); Maximum Switching Voltage - 250V AC, 48V DC Maximum Switching Current - 4 Amperes Nominal Switching Capacity - 4A 250V AC, 3A 30V DC UL/CSA Rating - 4 A 1/20 HP 125, 250V AC, 3A 30V DC Expected Life @ 25°C Mechanical: 100 Million operations Electrical 100,000 operation at 4A 250V AC 200,000 operations at 3A 30V DC ENVIRONMENTAL INFORMATION temperature Range: Ambient: - 40°C to 65°C (-40° to +149°F) OUTLINE DIMENSIONS www.Amperite.com Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 Solving your relay requirements since 1922 Timing Specifications Fixed timing: 0.1 seconds to hour, tolerance 5% consult factory for availability. Adjustable Timing Ranges: .1 to 1 sec; 1 to 10 sec; 10 to 100 sec; 1 to 10 min; 10 to 100 min. Availability of long delay time depends upon voltage; consult factory for details. INITIAL DIELECTRIC STRENGTH: Between open contacts: 750V RMS Between adjacent contacts: 1000V RMS Between contacts & coil: 1500V RMS INPUT INFORMATION Voltage: 12, 24, 48, 120 volts AC or DC Custom voltages are available Power requirements: 2 VA or Watts Transient: protection: 1 Joule MOV Polarity protection DC units INPUT VOLTAGES & LIMITS: Nominal Minimum Maximum 10V 11V 15V 24V 20V 28V 48V 20V 28V 110V 41V 55V 120V 95V 125V WRING DIAGRAM MECHANICAL INFORMATION Termination: 1/4 inch quick-connect male terminals Enclosure: 21/2 by 3/4 inch, epoxy sealed Single 1/4 inch hole flat panel mounting. www.Amperite.com Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 Solving your relay requirements since 1922 Ordering Information Definition of a part number for the Amperite HDOD Series Time Delay Relay Example: A: Denotes nominal input voltage. Voltages: 12, 24 and120V AC; 12, 24, 48, and 110V DC. B: Denotes type of input power: A = AC, D = DC C & D: Denotes timing range if knob adjustability. See Standard ranges. For fixed units specify a single number. Costume timing available. E: Denotes unit of time delay: S = seconds; M = minutes H = hours F: Denotes Amperite HDOD Series DPDT 4 ampere delay-on-dropout TDR. www.Amperite.com
24D1-10MHDOD 价格&库存
很抱歉,暂时无法提供与“24D1-10MHDOD”相匹配的价格&库存,您可以联系我们找货
