12D1-100SST1
12D1-100SST1
    AMPERITE
12D1-100SST1 数据手册
Solving your relay requirements since 1922 ST1 Series Solid State Delay-On-Make Timers Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com … 100% solid state circuitry - no moving parts … Two terminal series connection to load … Fixed or field adjustable delays from milliseconds to hours … Up to 1 ampere continuous load current … CMOS digital circuitry … UL File #E96739(M) … CSA File #LR62586 Timing Mode: Delay on operate begins upon application of input power. The load is energized at the end of the delay period and remains so until input power is removed. Timing Diagram: Contact Information: Solid state switching device 1 form A, normally open series connection. Continuous current rating 1 ampere. Maximum inrush 10 amperes. Minimum load current 5 milliamperes. Voltage drop typically 2.5 volts RMS @ 1 ampere. Environmental Information: Temperature Range: -40° C to +65° C (-40° F to +149° F) Timing Specifications: Timing: Factory fixed, or .1 seconds to 100 hours in any one of eight ranges. Timing is set by user supplied resistor or potentiometer. *Timing ranges: .1 to 10 seconds .2 to 20 seconds 1 to 100 seconds 10 to 1000 seconds Solving your relay requirements since 1922 .1 to 10 minutes 1 to 100 minutes 10 to 1000 minutes .1 to 10 hours 1 to 100 hours *See External Resistor Selection Graph for specific resistor value. Timing tolerance: fixed units = +/- 10% Timing repeatability: +/- 2% Timing cycle interrupt transfer: none Outline Dimensions: AC (60 Hz) and DC INPUT VOLTAGES & LIMITS: Nominal Minimum Maximum 12V 10V 14V 24V 20V 28V 48V 41V 55V 110V 95V 125V 120V 105V 130V 230V 190V 255V Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com External Resistor Selection: * Note: use appropriate timing scale in accordance with Timing ranges specified above. Wiring Diagrams: Mechanical Information: Enclosure 2 x 2 x 3/4 inch black plastic, epoxy sealed. Center hole mounting. Two or four 1/4 inch quick connect male terminals. Ordering Information: Ordering Information: Definition of a part number for the Amperite ST1 Series Time Delay Relay: Example: Solving your relay requirements since 1922 Amperite Co. 567 52nd Street P.O. Box 329 West New York, NJ 07093 (800) 752-2329 www.Amperite.com A: Denotes nominal input voltage. Voltages available: 12, 24, 48, 120, and 230 volts AC; 12, 24, 36, 48, and 110 volts DC. For other voltages consult factory. B: Denotes type of input power required for operation A = AC - Alternate Current D = DC - Direct Current C&D: Denotes range of adjustability using an external resistor or potentiometer, where C is the minimum timing and D is the maximum timing. Standard timing span is 100:1. For fixed timing units specify a single number. E: Denotes unit of time delay: S = seconds; M = minutes; H = hours. F: Denotes Amperite ST1 Series solid state, normally open time delay. Solving Your Relay Requirements Since 1922
12D1-100SST1 价格&库存
很抱歉,暂时无法提供与“12D1-100SST1”相匹配的价格&库存,您可以联系我们找货
