DCS 10-120ER
DCS 10-120ER
    AMETEK
    AMETEK PROGRAMMABLE POWER - DCS 10-120ER - Bench Power Supply, Programmable, 1 Output, 0 V, 10 V, 0 ...
DCS 10-120ER 数据手册
Sorensen DCS Series 1–3 kW General Purpose Systems Power Supply 8–600 V 1.7–350 A • High power density / low ripple and noise • High programming resolution with Ethernet interface • Constant voltage and current mode 115 230 208 230 • Remote sensing • Isolated analog control and monitoring (optional) DCS Applications The Sorensen DCS Series (hereafter DCS Series) is ideally suited for a wide range of applications requiring DC power in a small form factor. Applications range from manufacturing test and burn-in of automotive components, avionics electronics, telecommunications and consumer products to beam steering, process control and laboratory R&D use. The DCS Series is comprised of 1kW, 1.2kW and 3kW programmable power supplies utilizing switchmode technology to achieve high power density in a low profile chassis. The design platform provides a highly reliable power supply for years of constant use. The unique design is available in a variety of maximum voltages from 8V to 600V and maximum currents from 1.7A to 350A with low ripple and noise. This user-friendly platform can be controlled from the front panel with 10-turn potentiometers to adjust voltage, current and OVP settings. LEDs indicate over temperature, remote programming, shutdown and overvoltage protection Remote control options allow full computer control through IEEE-488 (option M9C), LXI Standard Compliant* Ethernet LAN (option M130) or RS-232 (options M9C, M130) 858.458.0223 Automotive Component Test The 16-bit resolution of the Ethernet programming and hardware triggering allows for detailed sequencing associated with battery fluctuation simulation. The tight load regulation capability of the DCS series makes it a superior source for validation and acceptance testing and burn-in of automotive components. The 20V models, in particular, provide a full range of testing to simulate battery conditions. Margin testing of 12V and 14V nominal components, such as electronic control units (ECU) and electromechanical components, is easily achieved. Rackmount ATE Systems The high power density of the DCS series makes it ideal for ATE System integration. The wide variety of voltage and current combinations in 1U and 2U heights allows multiple voltage outputs in a small amount of space. The wide variety of control methods possible, allows easy integration into legacy systems as well as high speed systems. Battery Charging Battery charging requires high accuracy voltage and stable current output for fast bulk and absorption phase charging and high accuracy and stable voltage for float charging to avoid “gassing” the battery. The DCS series provides a high accuracy voltage output to optimize battery charging. With the remote interface options, the charging process can easily be automated for volume production.) sales.ppd@ametek.com AMETEK Programmable Power 9250 Brown Deer Road San Diego, CA 92121-2267 USA 02122016 53 DCS Series : Product Specifications Common Meter Accuracy 1% of full scale + 1 count Max. Voltage Differential from Output to Safety Ground 150 VDC Remote Start/Stop and Interlock TTL compatible input or 12-250 VAC (12-130 VDC) or a contact closure Cooling Internal fan, over temperature shutdown if internal heat sink exceeds set temperature Remote Sense The maximum allowed sense line drop is 4V per line (2V on the DCS 8/10V 1 kW/1.2 kW models and 1V/line for all 3 kW models). Line drop subtracts from the maximum available output voltage at full rated power. Remote Programming Enabled via external jumper on rear panel connector J3 Overvoltage Protection Crowbar type adjustable from 5-110% of rated output using front panel control (local or remote program selectable via J3 jumper) Remote Analog Programming Linearity Typical error is less an 0.5% setting. Accuracy Accuracy is 1% of rated output. Regulatory Certified to UL/CSA 61010 (Not DCS 3K) and IEC/EN 61010-1 CE. Compliant (LVD and EMC directive) Input 1 kW 1.2 kW 3 kW Voltage Ranges 200-250 VAC / 100-132 VAC 200-250 VAC / 100-132 VAC 190-250 VAC / 200-250 VAC Phases Single Phase Single Phase Three Phase / Single Phase * (See Below) Current 8A typical, 47-63 Hz 15A typical, 47-63 Hz 9A typical, 47-63 Hz 18A typical, 47-63 Hz 190-250 VAC, three phase, 14A, 47-63Hz. * (See Below) User configurable for: 200-250VAC, single-phase operation, 20A, 47- 63Hz. * See the modified operation curve below. Output Stability ±0.05% of maximum voltage or current over 8 hours after 30 minute warm-up time at fixed line, load and temperature Line Regulation For input voltage variation over the AC input voltage range, with constant rated load. Load Regulation For 0-100% load variation, with constant nominal line voltage. Voltage Resolution 0.02% Transient Response Typically recovers in 500 μs (1 & 1.2 kW) or 1ms (3k W) to 1% of steady-state output voltage (within 1% of Vmax) for 70-100% or 100-70% load change. Output : Voltage and Current 1 kW Model Voltage Current 1.2 kW Model Voltage Current 3 kW Model Voltage Current DCS 8-125E 0-8 0-125 DCS 8-140E 0-8 0-140 DCS 8-350E 0-8 0-350 DCS 10-100E 0-10 0-100 DCS 10-120E 0-10 0-120 DCS 12-250E 0-12 0-250 DCS 20-50E 0-20 0-50 DCS 20-60E 0-20 0-60 DCS 20-150E 0-20 0-150 DCS 33-33E 0-33 0-33 DCS 33-36E 0-33 0-36 DCS 40-75E 0-40 0-75 DCS 40-25E 0-40 0-25 DCS 40-30E 0-40 0-30 DCS 55-55E 0-55 0-55 DCS 50-20E 0-50 0-20 DCS 50-24E 0-50 0-24 DCS 60-50E 0-60 0-50 DCS 60-18E 0-60 0-18 DCS 60-20E 0-60 0-20 DCS 80-37E 0-80 0-37 DCS 80-13E 0-80 0-13 DCS 80-15E 0-80 0-15 DCS 150-20E 0-150 0-20 DCS 100-10E 0-100 0-10 DCS 100-12E 0-100 0-12 DCS 150-7E 0-150 0-7 DCS 150-8E 0-150 0-8 DCS 300-3.5E 0-300 0-3.5 DCS 300-4E 0-300 0-4 DCS 600-1.7E 0-600 0-1.7 Modified Operation Curve for DCS Series 3 kW Single Phase AC Input Rated Current 2.5kW Rated Voltage Current Voltage 54 www.ProgrammablePower.com DCS Series : Product Specifications 1–3 kW Environmental Operating Temperature 0°C to 50°C (no derating) Storage Temperature -55°C to 85°C Humidity (Non-condensing) 0 to 85% RH Physical 1kW 1.2kW 3kW Dimensions Width: 19” (483 mm) Height: 1.72” (43 mm) - 1U Depth: 17.52” (445 mm) Width: 19” (483 mm) Height: 1.72” (43 mm) - 1U Depth: 17.52” (445 mm) Width: 19” (483 mm) Height: 3.46” (87 mm) - 2U Depth: 17.52” (445 mm) Weight 19 lbs. ( 8.6 kg ) 19 lbs. ( 8.6 kg ) 33 lbs. ( 15 kg ) Shipping Weight 24 lbs. ( 10.9 kg ) 24 lbs. ( 10.9 kg ) 42 lbs. ( 19 kg ) Programming Accuracy Model Readback Accuracy M130 / M131 / M9C / M85 Options Voltage 0.1%+ Current 0.1%+ OVP 0.5%+ Voltage 0.1%+ Current 0.1%+ 44mV 12mV 500mA DCS Series 1 kW DCS 8-125E 8mV 500mA DCS 10-100E 10mV 400mA 55mV 15mV 400mA DCS 20-50E 20mV 200mA 110mV 30mV 200mA DCS 33-33E 33mV 132mA 182mV 50mV 132mA DCS 40-25E 40mV 100mA 220mV 60mV 100mA DCS 50-20E 50mV 80mA 275mV 75mV 80mA DCS 60-18E 60mV 72mA 330mV 90mV 72mA DCS 80-13E 80mV 52mA 440mV 120mV 52mA DCS 100-10E 100mV 40mA 550mV 150mV 40mA DCS 150-7E 150mV 28mA 825mV 225mV 28mA DCS 300-3.5E 300mV 14mA 1650mV 450mV 14mA DCS 600-1.7E 600mV 6.8mA 3300mV 900mV 7mA DCS Series 1.2 kW DCS 8-140E 8mV 560mA 44mV 12mV 560mA DCS 10-120E 10mV 480mA 55mV 15mV 480mA DCS 20-60E 20mV 240mA 110mV 30mV 240mA DCS 33-36E 33mV 144mA 182mV 50mV 144mA DCS 40-30E 40mV 120mA 220mV 60mV 120mA DCS 50-24E 50mV 96mA 275mV 75mV 96mA DCS 60-20E 60mV 80mA 330mV 90mV 80mA DCS 80-15E 80mV 60mA 440mV 120mV 60mA DCS 100-12E 100mV 48mA 550mV 150mV 48mA DCS 150-8E 150mV 32mA 825mV 225mV 32mA DCS 300-4E 300mV 16mA 1650mV 450mV 16mA DCS 8-350E 8mV 1400mA 44mV 12mV 1400mA DCS 12-250E 12mV 1000mA 66mV 18mV 1000mA DCS 20-150E 20mV 600mA 110mV 30mV 600mA DCS 40-75E 40mV 300mA 220mV 60mV 300mA DCS 55-55E 55mV 220mA 303mV 83mV 220mA DCS 60-50E 60mV 200mA 330mV 90mV 200mA DCS 80-37E 80mV 148mA 440mV 120mV 148mA DCS 150-20E 150mV 80mA 825mV 225mV 80mA DCS Series 3 kW 858.458.0223 sales.ppd@ametek.com 55 DCS Series : Product Specifications Output Power Model Programming Constants Voltage Mode Constant Voltage Mode* Voltage VDC Current ADC@ 50 °C Combined Regulation Line and Load % DCS 8-125E 0-8 0-125 0.2 4 60 500 0.02 0.05 625 DCS 10-100E 0-10 0-100 0.2 4 60 500 0.02 0.05 500 Ripple** (rms) mV Noise** (p-p) mV Transient Response Time μs (Typ) Temp. Coeff. Voltage% /°C (Typ) Voltage Drift %Vmax (Typ) Ohms / V V/V DCS Series 1 kW DCS 20-50E 0-20 0-50 0.2 4 60 500 0.02 0.05 250 DCS 33-33E 0-33 0-33 0.2 4 60 500 0.02 0.05 151.5 DCS 40-25E 0-40 0-25 0.2 4 60 500 0.02 0.05 125 DCS 50-20E 0-50 0-20 0.2 4 60 500 0.02 0.05 100 DCS 60-18E 0-60 0-18 0.2 4 60 500 0.02 0.05 83 DCS 80-13E 0-80 0-13 0.2 4 60 500 0.02 0.05 62.5 DCS 100-10E 0-100 0-10 0.2 6 60 500 0.02 0.05 50 DCS 150-7E 0-150 0-7 0.2 12 160 500 0.02 0.05 33.3 DCS 300-3.5E 0-300 0-3.5 0.2 20 200 500 0.02 0.05 16.67 DCS 600-1.7E 0-600 0-1.7 0.2 50 300 500 0.02 0.05 8.33 0-10V = 0-100% V° or 0-5V = 0-100% V° DCS Series 1.2 kW DCS 8-140E 0-8 0-140 0.2 5 60 500 0.02 0.05 625 DCS 10-120E 0-10 0-120 0.2 5 60 500 0.02 0.05 500 DCS 20-60E 0-20 0-60 0.2 5 60 500 0.02 0.05 250 DCS 33-36E 0-33 0-36 0.2 5 60 500 0.02 0.05 151.5 DCS 40-30E 0-40 0-30 0.2 5 60 500 0.02 0.05 125 DCS 50-24E 0-50 0-24 0.2 5 60 500 0.02 0.05 100 DCS 60-20E 0-60 0-20 0.2 5 60 500 0.02 0.05 83 62.5 DCS 80-15E 0-80 0-15 0.2 5 60 500 0.02 0.05 DCS 100-12E 0-100 0-12 0.2 10 60 500 0.02 0.05 50 DCS 150-8E 0-150 0-8 0.2 15 160 500 0.02 0.05 33.3 DCS 300-4E 0-300 0-4 0.2 25 200 500 0.02 0.05 16.67 0-10V = 0-100% V° or 0-5V = 0-100% V° DCS Series 3 kW DCS 8-350E 0-8 0-350 0.2 15 100 1000 0.02 0.05 625 DCS 12-250E 0-12 0-250 0.2 10 100 1000 0.02 0.05 416.7 DCS 20-150E 0-20 0-150 0.2 10 100 1000 0.02 0.05 250 DCS 40-75E 0-40 0-75 0.2 20 100 1000 0.02 0.05 125 DCS 55-55E 0-55 0-55 0.2 20 100 1000 0.02 0.05 90.9 DCS 60-50E 0-60 0-50 0.2 20 100 1000 0.02 0.05 83 DCS 80-37E 0-80 0-37 0.2 20 100 1000 0.02 0.05 62.5 DCS 150-20E 0-150 0-20 0.2 30 200 1000 0.02 0.05 33.3 * Typical resolution is 0.02% ** Typical P-P noise and ripple (20Hz to 300kHz) 56 www.ProgrammablePower.com 0-10V = 0-100% V° or 0-5V = 0-100% V° DCS Series : Product Specifications 1–3 kW Programming Constants, Current Mode Constant Current Mode* Model Regulation Line and Load% Combined Ripple (rms)** mA DCS 8-125E 0.2 160 0.03 0.05 40 82 DCS 10-100E 0.2 128 0.03 0.05 50 82 DCS 20-50E 0.2 25 0.03 0.05 100 82 DCS 33-33E 0.2 10 0.03 0.05 151.5 84 DCS 40-25E 0.2 7 0.03 0.05 200 DCS 50-20E 0.2 7 0.03 0.05 250 DCS 60-18E 0.2 6 0.03 0.05 277.8 DCS 80-13E 0.2 4 0.03 0.05 384.6 DCS 100-10E 0.2 3 0.03 0.05 500 86 DCS 150-7E 0.2 2 0.03 0.05 714.3 86 DCS 300-3.5E 0.2 1 0.03 0.05 1428.6 86 DCS 600-1.7E 0.2 1 0.03 0.05 2941.2 86 Temperature Coefficient %/°C (Typ.) Current Drift %I out Max. (Typ.) Ohms/A V/A Efficiency % (Typ.) DCS Series 1 kW 84 0-10V = 0-100% I° or 0-5V = 0-100% I° 84 86 86 DCS Series 1.2 kW DCS 8-140E 0.2 180 0.03 0.05 35.7 82 DCS 10-120E 0.2 153 0.03 0.05 41.7 82 DCS 20-60E 0.2 30 0.03 0.05 83.3 82 DCS 33-36E 0.2 11 0.03 0.05 138.9 84 DCS 40-30E 0.2 9 0.03 0.05 166.7 DCS 50-24E 0.2 8.5 0.03 0.05 208.3 DCS 60-20E 0.2 6.6 0.03 0.05 250.0 DCS 80-15E 0.2 6 0.03 0.05 333.3 85 DCS 100-12E 0.2 3.6 0.03 0.05 416.7 85 DCS 150-8E 0.2 2.3 0.03 0.05 625.0 85 DCS 300-4E 0.2 1.2 0.03 0.05 1250.0 85 0-10V = 0-100% I° or 0-5V = 0-100% I° 84 84 85 DCS Series 3 kW DCS 8-350E 0.2 0.03 0.05 82 DCS 12-250E 0.2 0.03 0.05 82 DCS 20-150E 0.2 0.03 0.05 DCS 40-75E 0.2 0.03 0.05 DCS 55-55E 0.2 0.03 0.05 DCS 60-50E 0.2 0.03 0.05 DCS 80-37E 0.2 0.03 0.05 86 DCS 150-20E 0.2 0.03 0.05 86 82 0-10V = 0-100% I° or 0-5V = 0-100% I° 86 82 86 * Typical resolution is 0.02% ** rms ripple typical from 20 Hz to 300 kHz 858.458.0223 sales.ppd@ametek.com 57 DCS Series : Diagram 1 kW and 1.2 kW 3 kW 1.10 (28) 1.10 (28) 17.52 (445) 17.52 (445) Top View 1.00 (25) 19.00 (482) 1.72 (43) Front View Top View 1.00 (25) 1.25 (32) 19.00 (482) 3.00 (76) 3.46 (87) Front View 16.90 (429) 16.90 (429) Rear View Rear View Dimensions in inches (millimeters) J3 Connector 58 1 90-250 VAC Remote Shutdown 14 TTL Shutdown 2 Shutdown Return 15 +12 VDC 3 OVP Program 16 1 mA Current Source (OVP) 4 Remote/Local Status Indicator 17 OVP Indicator 5 Mode Status Indicator 18 Thermal S/DN Status 6 Ground 19 0-5V Voltage Monitor 7 0-5V Current Monitor 20 Remote Voltage Select 8 Voltage Control 21 1 mA Current Source (V) 9 Voltage Program Input 22 1 mA Current Source (I) 10 Current Program Unit 23 Remote Current Select 11 Current Control 24 Return 12 Return Sense 25 POS Output (8-100V Models Only) 13 POS Sense (8-100V Models Only) www.ProgrammablePower.com 1–3 kW DCS Series Model Number Description DCS 20 50E (MXX) Series Options Voltage Current Options and Accessories M1 Factory configured for 115 VAC input (1 kW and 1.2 kW units only) M9C Internal IEEE-488/RS-232 Interface (can only support 12-bit slaves) M13 Locking shafts (front panel potentiometers) M32 Master/slave paralleling cable configured for two units M33 Replace input connector with terminal block (3 kW only) M51A Isolated analog programming control of V/I/OVP and isolated V/I monitor outputs up to 500V relative to the supply’s return line. This isolation allows users to control power supplies not connected to a common ground. In addition, in systems with high ambient noise or with large ground loop currents the control ground can be isolated from the power ground eliminating problems. M85 12-bit slave interface option for use with M9 or M130 master (3 ft. control cable included) M102 Front panel binding posts for 1 kW or 1.2 kW, Models ≤30A, ≤100V. Not compatible with M9C, M85, M130, M131, M133, M135, M136 M130 LXI™compliant 10/100 Base T Ethernet remote control master interface; includes web server for direct control of power supply via web browser (MS Internet Explorer 6.0 or later) M131 16-bit slave interface option for use with a M130 master (3 ft. control cable included) M133 Output disconnect and polarity reversal relays controlled via SCPI commands. Limited to 1kW or 1.2 kW, ≤100V, ≤60A M135 M130 & M133 combination. Limited to 1kW or 1.2 kW, ≤100V, ≤60A M136 M131 & M133 combination. Limited to 1kW or 1.2 kW, ≤100V, ≤60A 105-300-26 Rack slide kit (3 kW only) Software IVI-Com and Labview drivers available for free download at http://www.elgar.com/products/DCS/DCS_Downloads.htm © 2009 AMETEK Programmable Power All rights reserved. AMETEK Programmable Power is the trademark of AMETEK Inc., registered in the U.S. and other countries. Elgar, Sorensen, California Instruments, and Power Ten are trademarks of AMETEK Inc., registered in the U.S. 858.458.0223 sales.ppd@ametek.com 59 Notes 60 www.ProgrammablePower.com
DCS 10-120ER 价格&库存
很抱歉,暂时无法提供与“DCS 10-120ER”相匹配的价格&库存,您可以联系我们找货
