DLM 60-50ER
DLM 60-50ER
    AMETEK
    AMETEK PROGRAMMABLE POWER - DLM 60-50ER - Bench Power Supply, Programmable, 1 Output, 0 V, 60 V, 0 A...
DLM 60-50ER 数据手册
Sorensen DLM 3 & 4 kW Series 3–4 kW DC Power Supply 5–600 V • High Power Density : 3 kW and 4 kW models, 2U (3½” high), (19” wide); no top or bottom clearance spacing required 5–450 A • Preview Push-button : Overvoltage protection (OVP), voltage and current preview buttons • Remote Voltage Sense : Sense leads are easily connected to a solderless connector 208 208 230 400 480 • Parallel or Series Operation Field configurable • Power Factor Correction ≥0.98 1 Ф 3kW The Sorensen DLM 3kW and 4kW Series programmable DC power supplies are designed to provide highly stable, continuously variable output voltage and current for a broad range of applications in a compact 2U ( 3½” high) chassis. Both the 3 kW and 4 kW models have output voltages from 0-5 VDC to 0-600 VDC and a current range from 0-5A to 0-450A. The output rms noise is as low as 10 mV. The output will recover to 1% of its steady-state voltage within 1 ms for a step load change of 100% to 70% or 70% to 100%. The front panel layout makes the series extremely easy to use. Control switches include: power on, enable/ standby and local/ remote. Displays and indicators show programmed set points and operational control status. The programmed voltage, current and overvoltage set points are displayed with two large 3½ digit LED displays. Operational Status LEDs indicate power on, shutdown, over temperature, overvoltage, constant current and voltage mode status. Control Status LEDs indicate front panel lockout, remote control and standby status. IEEE- 488.2 control LEDs indicate error, service request and remote address status. The 3 kW Models will accept 200*/230 VAC single phase and 200*/208 VAC three phase input power. The 4 kW Models will accept 200*/208 VAC, three phase or optional 400 or 480 VAC three phase input power. *Operating temperature below 40°C AMETEK Programmable Power 9250 Brown Deer Road San Diego, CA 92121-2267 USA 858.458.0223 sales.ppd@ametek.com 06222016 61 DLM 3 & 4 kW Series : Product Specifications Common Front Panel Controls Knobs with 3½ digit digital displays to control output voltage and current settings. Power on/off switch, output enable/standby switch and local/remote switch. Voltage, current and overvoltage preview push buttons allow you to preview the programmed settings at any time; overvoltage limit is adjusted with a set screw accessible through the front panel. Displays and Indicators Voltage and overvoltage setting 3½ digit LED display, current setting 3½ digit LED display. LED indicators for power on, shutdown, remote, overvoltage protection, over temperature and front panel lockout, constant voltage and constant current modes. IEEE-488.2 indicators include error, SRQ and address (M9E option). Overvoltage Protection Output overvoltage (resets by cycling the enable/standby switch) Cooling Internal fans with over temperature protection Remote Sense The maximum load line drop is up to the full voltage rating of the supply. The drop in the load leads subtracts from the maximum voltage available for the load except as follows: maximum rated voltage is available at the load and voltage regulation specifications apply for line drops of
DLM 60-50ER 价格&库存
很抱歉,暂时无法提供与“DLM 60-50ER”相匹配的价格&库存,您可以联系我们找货
