DLM 300-2R
DLM 300-2R
    AMETEK
    AMETEK PROGRAMMABLE POWER - DLM 300-2R - Bench Power Supply, Programmable, 1 Output, 0 V, 300 V, 0 A...
DLM 300-2R 数据手册
Sorensen DLM 600 Series 375–600 W 5–300 V Half Rack Programmable DC Power Supply 2–75 A • High Power Density: 600 watts in 1U (1.75 inches) high, half rack (8.5 inches) wide; no top or bottom clearance spacing required. 110 • Near Linear Ripple & Noise Ripple as low as 2.5mV rms, noise as low as 15mV p-p. 220 • Remote Control • LXI Compliant Ethernet LAN / RS-232C (16 bit) • IEEE-488.2 / RS-232C (12 bit) • Standard analog programming 0-5V, 0-10V, or 0-5kΩ. The Sorensen DLM 600 series of programmable power supplies is designed to provide continuously variable output voltage and current for a broad range of applications in a compact 1U (1.75 inches) high, half-rack (8.5 inch) wide chassis. With the use of Zero Voltage Switching (ZVS) technology, these supplies are able to achieve exceptionally low ripple and noise rivaling larger and more expensive linear power supplies. In addition, the high efficiency and fast load transient response assure that the DLM 600 is ideal for even the most demanding applications. The DLM 600 models are ideal for high density multiple output rackmount requirements or low profile benchtop applications. Output voltages from 0-5VDC to 0-300VDC and currents from 0-2A to 0-75A are available. The cooling air intake is at the front and sides with exhaust at the rear and sides. Variable speed fans are controlled as a function of ambient air temperature and load, thus reducing acoustic noise and increasing fan life. This allows supplies to be stacked one directly on top of another without space in between, yielding maximum rackmount packing density and a wide operating temperature of 0-50° C. An optional rackmount kit is available to easily mount one or two units side-by-side. The front panel layout makes the DLM 600 series easy to use. Voltage and current can be set from individual 10-turn potentiometer knobs. Control push buttons include power on, output on, local/remote, voltage/current preview and overvoltage protection preview. Set-point or actual voltage/ current values can be viewed on two 3 ½digit LED displays. Supplies can be connected in series or parallel. All models automatically accept any standard single phase input without manual set up. AMETEK Programmable Power 9250 Brown Deer Road San Diego, CA 92121-2267 USA 858.458.0223 sales.ppd@ametek.com 09142017 23 DLM 600 Series : Product Specifications Common Remote Sense The maximum load line drop is up to the full voltage rating of the supply. The drop in the load leads subtracts from the maximum voltage available for the load except as follows: maximum rated voltage is available at the load and voltage regulation specifications apply for line drops of
DLM 300-2R 价格&库存
很抱歉,暂时无法提供与“DLM 300-2R”相匹配的价格&库存,您可以联系我们找货
