105-C30-0S
105-C30-0S
    AMETEK
    AMETEK PROGRAMMABLE POWER - 105-C30-0S - RACK SLIDE KIT (24")
105-C30-0S 数据手册
NEW PART RELEASE FORM PART NUMBER: REVISION: F PAGE 1 OF 4 INSPECTION CODE DESCRIPTION: ENTER # 0 - UNDECLARED 105-C30-0S RACK SLIDE,24 INCH,85 LBS 1 - NUCLEAR 2 - LEAD FREE ADDITIONAL INFORMATION: 3 - ROHS COMPLIANT 3 4 - NON COMPLIANT 5 - ROHS W/EXEMPTION CODE APPROVED MANUFACTURER MANUFACTURER PART NUMBER GENERAL DEVICES C-300-S-124-AR ECO REV DATE - D 5-Jul-15 EC-016223 E EC-019261 F APPROVALS DESCRIPTION ORIGINATOR ENGINEER Removed Zero no longer makes rack Slides JRoth JRoth 18-Oct-17 NPFR updated to show RoHS compliance. AJohn JWillingham 21-Jan-19 Change NPRF RoHS Certificate attachment ABigornia OBoyarko PREPARED BY: Angel John Form: 0650003 rev C NOTES DATE 18-Oct-17 RESPONSIBLE ENGINEER: Jack Willingham DATE 18-Oct-17 FIRST USED ON: GENERAL USE 105-C30-0S C-300-S Slide Catalog Number C-300-S-110 C-300-S-112 C-300-S-114 C-300-S-116 C-300-S-118 C-300-S-120 C-300-S-122 C-300-S-124 C-300-S-126 C-300-S-128 C-300-S-130 A B C 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 9.25 9.25 13.25 13.25 13.25 19.25 19.25 19.25 25.25 25.25 25.25 8.63 8.63 12.63 12.63 12.63 18.63 18.63 18.63 24.63 24.63 24.63 D D E E F (min) (max) (min) (max) 11.00 11.00 15.00 15.00 15.00 21.00 21.00 21.00 27.00 27.00 27.00 11.00 13.00 15.00 17.00 19.00 21.00 23.00 25.00 27.00 29.00 31.00 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 2.13 0.13 2.13 4.13 0.13 2.13 4.13 0.13 2.13 4.13 G H 3 2.31 0.78 3 2.31 0.78 4 4.31 1.16 4 4.31 1.16 4 4.31 1.16 5 7.31 3.53 5 7.31 3.53 5 7.31 3.53 7 10.31 2.28 7 10.31 2.28 7 10.31 2.28 Load Capacity 95 LBS. 95 LBS. 90 LBS. 90 LBS. 90 LBS. 85 LBS. 85 LBS. 85 LBS. 80 LBS. 80 LBS. 80 LBS. TO ORDER, SPECIFY C-300-S Stationary Section Length 1 - Cabinet Mount 2 - Strap Mount 4 - Closed Slot AR - Automatic Release if desired AND/OR RC - See chart below For information on Strap Mount option see page 27. Notes 1. Finish: All standard slides are coated with PoxylubeTM dry film lubricant. 2. All standard slides are designed to lock-out in the extended position and are available with an optional automatic release if lock-out is not desirable. 3. Standard hardware packages include all the hardware necessary to mount your Chassis Trak® slides: • Rear mounting bracket (B-217 or B-161) included • Bar Nuts (CA8056-06-0017 or CA8056-06-0014) • #10-32 screws and keps nuts 4. All sliding members of the standard slide are made from cold rolled steel. 5. All Chassis Trak® solid bearing slides are supplied with a quick disconnect feature. 6. Optional mounting patterns, slide lengths and extensions are available. 7. For optional mounting brackets see page 34. 17 www.generaldevices.com Phone: 317-897-7000 Email: sales@generaldevices.com ISO 9001:2000 Registered
105-C30-0S 价格&库存
很抱歉,暂时无法提供与“105-C30-0S”相匹配的价格&库存,您可以联系我们找货
