1322.1530
1322.1530
    MENTOR
    MENTOR - 1322.1530 - LED Light Bulb, Cool White, 5600 K
1322.1530 数据手册
powered by • M-Tubes from optoelectronic innovators Mentor GmbH deliver many of the properties of fluorescent or cold cathode technologies but have all of the advantages of LEDs. • Either standard or hi-brightness LED-sourced light is input at each end of a crystal-clear light guide tube (both rigid and flexible versions are available). A printed reflective strip along the length of the tube delivers even, diffused and targeted light. • There are no “hot spots” of lights as found with LED strips. • M-Tubes are suitable for multiple applications including:• Architecture - stairs and edges, emergency lighting, ambience / decorative lighting, cove lighting, lift doors etc. • Industrial electronics - switchgear cabinet illumination, service light, danger signals etc. • Household - illumination and backlighting of all kinds.• • Automotive and marine - light curtains, signal lights, contour illumination , ambience/decorative lighting. Flexible or rigid LED-powered light tubes for low energy, long-life illumination. • The light guide tubes can be up to 700mm in length and either 6mm or 10mm diameter. • Service life of around 50,000 hours to 50% brightness compares with typical tungsten bulb life of around 1,000 hours. • Brightness level of a 548mm ultra-white hi-brightness M-Tube is 250lx compared with 307lx from a typical 10W 500mm fluorescent tube. • Energy-efficient with minimal heat generation - in terms of cost per KWh, the hi-brightness version is 63% cheaper than fluorescent tube and 94% cheaper than tungsten bulbs (approximate). • Service life is unaffected by on/off actuations. • Immediate full luminosity (no warm-up). • Impervious to extremes of temperature - operating range -40ºC to +70ºC. • Available in red, green, blue and up to three Kelvins of white. RGB available on special order. • Dimmability of all LEDs and RGB colour control are possible using alternative power sources (not supplied). powered by Standard LEDs Image Order Code Mftrs. List Description No. 177-3081 1321.1202 ● M-Tube corner housing with red std LED 177-3083 1321.1402 ○ M-Tube corner housing with white 3,500K std LED 177-3084 1321.1502 ○ M-Tube corner housing with white 5,600K std LED 177-3085 1321.1602 ● M-Tube corner housing with blue std LED ● M-Tube corner housing with green std LED M-Tube end shade - Black One plug 1320.0200 for 177-3056 1320.0011 Ø6mm or 1320.0400 for Ø10mm is required for each end shade. M-Tube coupler shade - Black Two plugs 1320.0200 for 177-3058 1320.0012 Ø6mm or 1320.0400 for Ø10mm are required for each coupler shade. M-Tube corner shade - Black Two plugs 1320.0200 for 177-3059 1320.0013 Ø6mm or 1320.0400 for Ø10mm are required for each corner shade. 177-3086 1321.1802 • Standard LEDs for lower brightness illumination • Available in a modular system Image Order Code Mftrs. List Description No. 177-3048 1320.0610 Ø6mm light guide (100mm long) 177-3049 1320.0630 Ø6mm light guide (300mm long) 177-3050 1320.0650 Ø6mm light guide (500mm long) 177-3051 1320.0670 Ø6mm light guide (700mm long) 177-3052 1320.1010 Ø10mm light guide (100mm long) 177-3053 1320.1030 Ø10mm light guide (300mm long) 177-3060 1320.0200 Plug for Ø6mm M-Tube 177-3054 1320.1050 Ø10mm light guide (500mm long) 177-3061 1320.0400 Plug for Ø10mm M-Tube 177-3055 1320.1070 Ø10mm light guide (700mm long) 177-3062 1320.0020 Fastening device for Ø6mm M-Tube 177-3046 1320.0002 Split sleeve for Ø6mm M-Tube 177-3063 1320.0040 Fastening device for Ø10mm M-Tube 177-3047 1320.0004 Split sleeve for Ø10mm M-Tube Terminal box - use to connect power to up to 177-3064 1321.1000 12 LED housings (six double-ended M-Tubes). Note:- Used to connect the light guide to the M‑Tube LED housing. One split sleeve is required for every LED housing. 177-3071 1321.1200 ● M-Tube housing with red std LED 177-3072 1321.1400 ○ M-Tube housing with white 3,500K std LED 177-3073 1321.1500 ○ M-Tube housing with white 5,600K std LED 177-3074 1321.1600 ● M-Tube housing with blue std LED 177-3075 1321.1800 ● M-Tube housing with green std LED 177-3076 1321.1201 ● M-Tube coupler with red std LED 177-3077 1321.1401 ○ M-Tube coupler with white 3,500K std LED 177-3078 1321.1501 ○ M-Tube coupler with white 5,600K std LED ● M-Tube coupler with 177-3079 1321.1601 blue std LED 177-3080 1321.1801 ● M-Tube coupler with green std LED 177-3065 1321.0100 M-Tube power supply extension cable (3m) M-Tube terminal box to 177-3066 1321.0010 LED extension cable (3m) M-Tube terminal box to 177-3067 1321.0020 LED extension cable (5m) M-Tube terminal box to 177-3068 1321.0030 LED extension cable (10m) M-Tube System Basic including AC/DC adapter 177-3087 1321.2001 (for use with one doubleended M-Tube). M-Tube System Basic (supplementary). Up to two of these can be 177-3088 1321.2002 added to 1321.2002 to power a total of three double-ended M-Tubes. powered by Hi Brightness LEDs Image Order Code Mftrs. List Description No. 177-3062 1320.0020 Fastening device for Ø6mm M-Tube 177-3063 1320.0040 Fastening device for Ø10mm M-Tube Complete Hi-Brightness units with aluminium profiles, DC/DC converters and female plug sockets. 448.3 mm long aluminium profile • The Dragon LEDs used in Hi-Brightness M-Tubes deliver an impressive intensity of illumination whilst still retaining the benefits of low-energy and longevity. • An aluminium profile regulates the thermo-management of these powerful LEDs, whilst at the same time acting as a reflector and an elegant design feature. • As well as fully assembled units with sockets for power-in, unusual design requirements are accommodated for by the availability of modular components incorporating stranded wires for attachment to suitable power sources. Image Order Code Mftrs. List Description No. 177-3103 1322.1320 ☼ Ultra-white (6,500K) Hi-Bright LEDs 177-3104 1322.1420 ○ Warm-white (3,500K) Hi-Bright LEDs 177-3105 1322.1520 ○ Std-white (5,600K) Hi‑Bright LEDs 177-3106 1322.1220 ● Red Hi-Bright LEDs 177-3107 1322.1620 ● Blue Hi-Bright LEDs 177-3108 1322.1820 ● Green Hi-Bright LEDs 548.3 mm long aluminium profile 177-3109 1322.1330 ☼ Ultra-white (6,500K) Hi-Bright LEDs 177-3110 1322.1430 ○ Warm-white (3,500K) Hi-Bright LEDs 177-3111 1322.1530 ○ Std-white (5,600K) Hi‑Bright LEDs 177-3113 1322.1230 ● Red Hi-Bright LEDs 177-3114 1322.1630 ● Blue Hi-Bright LEDs Modular 177-3115 1322.1830 ● Green Hi-Bright LEDs M-Tube Hi-Brightness LED and Housing (32.6mm alu) single module with stranded wire and split sleeve for Ø10mm flexible or rigid M-Tube light guides (one required for each unit.) 748.3 mm long aluminium profile 177-3116 1322.1340 ☼ Ultra-white (6,500K) Hi-Bright LEDs 177-3089 1322.1300 ☼ Ultra-white (6,500K) Hi-Bright 177-3117 1322.1440 ○ Warm-white (3,500K) Hi-Bright LEDs 177-3090 1322.1400 ○ Warm-white (3,500K) Hi-Bright 177-3118 1322.1540 ○ Std-white (5,600K) Hi‑Bright LEDs 177-3091 1322.1500 ○ Standard-white (5,600K) Hi-Bright 177-3092 1322.1600 ● Blue Hi-Bright 177-3093 1322.1800 ● Green Hi-Bright 177-3095 1322.1200 ● Red Hi-Bright M-Tube Hi-Brightness LED and Housing (63.1mm alu) single module with DC/DC converter, stranded wire and split sleeve for Ø10mm flexible or rigid M-Tube light guides (one required for each unit.) 177-3119 1322.1240 ● Red Hi-Bright LEDs 177-3120 1322.1640 ● Blue Hi-Bright LEDs 177-3121 1322.1840 ● Green Hi-Bright LEDs 948.3 mm long aluminium profile 177-3122 1322.1350 ☼ Ultra-white (6,500K) Hi-Bright LEDs 177-3123 1322.1450 ○ Warm-white (3,500K) Hi-Bright LEDs ○ Std-white (5,600K) Hi‑Bright LEDs 177-3096 1322.1301 ☼ Ultra-white (6,500K) Hi-Bright 177-3125 1322.1550 177-3097 1322.1401 ○ Warm-white (3,500K) Hi-Bright 177-3126 1322.1250 ● Red Hi-Bright LEDs 177-3098 1322.1501 ○ Standard-white (5,600K) Hi-Bright 177-3128 1322.1850 ● Green Hi-Bright LEDs 177-3099 1322.1601 ● Blue Hi-Bright 177-3101 1322.1801 ● Green Hi-Bright 177-3102 1322.1201 ● Red Hi-Bright 177-3127 1322.1650 ● Blue Hi-Bright LEDs 177-3129 1322.0020 Diffuser cover with end caps (450mm long) 177-3130 1322.0030 Diffuser cover with end caps (550mm long) 177-3052 1320.1010 Ø10mm light guide (100mm long) 177-3131 1322.0040 Diffuser cover with end caps (750mm long) 177-3053 1320.1030 Ø10mm light guide (300mm long) 177-3132 1322.0050 Diffuser cover with end caps (950mm long) 177-3054 1320.1050 Ø10mm light guide (500mm long) 177-3133 1322.1000 AC/DC adapter for HB M-Tubes 177-3055 1320.1070 Ø10mm light guide (700mm long) 177-3134 1322.0100 Power supply extension (3m) powered by Standard LEDs Stranded Wire Version Image Order Code Mftrs. List Description No. Image Order Code Mftrs. List Description No. 178-1949 1320.1000 M-TUBE HOUSING, STD, WIRED, EMPTY 178-1965 1320.1002 M-TUBE CORNER, STD, WIRED, EMPTY 178-1950 1320.1200 M-TUBE HOUSING, STD, WIRED, RED 178-1966 1320.1202 M-TUBE CORNER, STD, WIRED, RED 178-1951 1320.1400 M-TUBE HOUSING, STD, WIRED, WRM WHT 178-1967 1320.1402 M-TUBE CORNER, STD, WIRED, WRM WHT 178-1952 1320.1500 M-TUBE HOUSING, STD, WIRED, WHT 178-1968 1320.1502 M-TUBE CORNER, STD, WIRED, WHT 178-1953 1320.1600 M-TUBE HOUSING, STD, WIRED, BLUE 178-1969 1320.1602 M-TUBE CORNER, STD, WIRED, BLUE 178-1954 1320.1800 M-TUBE HOUSING, STD, WIRED, GREEN 178-1970 1320.1802 M-TUBE CORNER, STD, WIRED, GREEN 178-1955 1320.1900 M-TUBE HOUSING, STD, WIRED, RGB 178-1956 1320.1001 M-TUBE COUPLER, STD, WIRED, EMPTY 178-1957 1320.1201 M-TUBE COUPLER, STD, WIRED, RED 178-1958 1320.1401 M-TUBE COUPLER, STD, WIRED, WRM WHT 178-1961 1320.1501 M-TUBE COUPLER, STD, WIRED, WHT 178-1962 1320.1601 M-TUBE COUPLER, STD, WIRED, BLUE 178-1963 1320.1801 M-TUBE COUPLER, STD, WIRED, GREEN 178-1964 1320.1901 M-TUBE COUPLER, STD, WIRED, RGB Flexible Light Guides use with Standard or Hi-Brightness LEDs Image Order Code Mftrs. List Description No. 177-3135 1320.0631 Ø6mm flexible light guide (300mm long) 177-3137 1320.0651 Ø6mm flexible light guide (500mm long) 177-3138 1320.0671 Ø6mm flexible light guide (700mm long) Note:- Hi Brightness LED housings are supplied with split sleeves for Ø10mm rigid or flexible light guides. For other combinations of size/LED types, split sleeves should be ordered separately. • Simply order these flexible light guides instead of rigid ones to add a twist to your lighting solutions! • Compatible with both the standard LED and Hi-Brightness LED modules, flexible M-Tubes works on the same principle as rigid ones. LED-sourced light is input at each end and a printed reflective strip ensures even distribution of diffused light along the tube’s length. 177-3139 1320.1031 Ø10mm flexible light guide (300mm long) 177-3140 1320.1051 Ø10mm flexible light guide (500mm long) 177-3141 1320.1071 Ø10mm flexible light guide (700mm long) 177-3062 1320.0020 Fastening device for Ø6mm M-Tube 177-3063 1320.0040 Fastening device for Ø10mm M-Tube • There are no “hot spots” of lights as found with LED strips. Low-energy and longevity features remain the same as rigid M-Tubes. • Flexible M-Tubes can easily be bent into the desired shape and location and are secured by means of transparent holders. • Choose standard LEDs for a mood-setting glow or hibrightness LEDs for more intense illumination (dimmability is possible). • Potential applications are limitless but include the illumination of round objects, mirrors, displays, advertising, vending machines, curved staircases etc.
1322.1530
物料型号: - 标准LED模块和高亮度LED模块,以及相应的配件和固定装置。
器件简介: - M-Tubes是LED驱动的照明管,提供柔性或刚性版本,用于低能耗、长寿命照明。
引脚分配: - 文档中未明确提供引脚分配信息。
参数特性: - 服务寿命约50,000小时,亮度级别、能效、温度范围、立即全亮度、对开关次数不敏感。
功能详解: - M-Tubes适用于建筑、工业电子、家庭、汽车和海洋等多个领域,提供均匀、无热点的照明。
应用信息: - 包括楼梯边缘、紧急照明、环境/装饰照明、电梯门等。
封装信息: - 提供不同长度和直径的光导管,以及多种颜色选项和调光功能。
1322.1530 价格&库存
很抱歉,暂时无法提供与“1322.1530”相匹配的价格&库存,您可以联系我们找货
