1206TD-15A
1206TD-15A
    PROSEMI(普罗森美)
    一次性保险丝(熔断) 15A 32V
1206TD-15A 数据手册
Circuit Protection 1206TD Series Time Delay | 0.126x0.064 inch Thick Film Chip Fuses 1206TD Series are the fuses set the industry standard for performance, reliability and quality. The solder-free design provides excellent on-off and temperature cycling characteristics during use and also makes our SMD fuses more heat and shock tolerant than typical subminiature fuses. Features O Compatible with reflow and wave solder Ceramic and glass construction P Halogen free, lead free and RoHS compliant Excellent environmental integrity One time positive disconnect AEC-Q200 Automotive Grade Certified Electrical Characteristics Appications Flat panel displays and televisions Automotive infotainment and ECU Computer servers Portable electronics Mobile device chargers Power Battery Packs Amp Rating % of Amp Rating 0.75~30A 0.75~3A 0.75~5A 0.75~5A 6~30A 0.75~30A 100% 200% 250% 300% 350% 1000% Opening Time 4 Hours Min. 1sec~60sec 5 Seconds Max. 0.1sec~3sec 5 Seconds Max. 0.2ms~20ms Specification Part Number Ampere Rating (A) 1206TD-R750 1206TD-1A 1206TD-1.5A 1206TD-2A 1206TD-2.5A 1206TD-3A 1206TD-3.5A 1206TD-4A 1206TD-4.5A 1206TD-5A 1206TD-6A 1206TD-7A 1206TD-8A 1206TD-10A 1206TD-12A 1206TD-15A 1206TD-20A 1206TD-25A 1206TD-30A 0.75 1.00 1.50 2.00 2.50 3.00 3.50 4.00 4.50 5.00 6.00 7.00 8.00 10.0 12.0 15.0 20.0 25.0 30.0 Voltage Rating Interrupting Rating 72Vdc @ 50A 32Vdc @ 150A 24Vdc @ 300A 45Vdc @ 50A 32Vdc @ 150A 24Vdc @ 300A 32Vdc @ 150A 24Vdc @ 300A Typical Cold Resistance (Ohms) Typical Melting I 2 t (A 2 Sec) Typical Voltage Drop (V) Marking Code 0.83 0.46 0.25 0.13 0.077 0.048 0.036 0.033 0.022 0.019 0.015 0.010 0.007 0.0065 0.005 0.0033 0.0027 0.0022 0.0019 0.02 0.13 0.18 0.43 0.69 1.7 2.3 3.1 3.9 5 12.2 15 17 25 13 41 52 60 100 1.11 0.5 0.356 0.309 0.24 0.189 0.187 0.175 0.17 0.142 0.138 0.12 0.097 0.099 0.087 0.075 0.089 0.091 0.090 0.75 H K N O P R S X T F 7 M U 12 15 Q L Z DC Interrupting Rating - Measured at designated voltage, time constant < 50 microseconds. DC Cold Resistance are measured at
1206TD-15A 价格&库存
很抱歉,暂时无法提供与“1206TD-15A”相匹配的价格&库存,您可以联系我们找货
1206TD-15A
    • 5+0.73106
    • 50+0.58072
    • 150+0.50555
    • 500+0.44918
    • 3000+0.39064
    • 6000+0.36807
    库存:2394
