25546NA
25546NA
    APEM(埃斐)
    插件
    滑动开关 插件 双刀双掷 直插
25546NA 数据手册
SLIDE SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SEE PUSHBUTTON SWITCH SELECTION GUIDE ON NEXT PAGE E APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E1 SLIDE SWITCHES MICROMINIATURE SLIDE SWITCHES E SERIES POLES POSITIONS WASHABLE RATINGS LIFE CYCLES MOUNTING ACTUATION PAGE(S) TG (SMT) 1 2&3 0.4 VA @ 20V Yes 60,000 Surface Vertical E4-E7 MJS 1&2 2&3 100 ma @ 12VDC No 10,000 P.C. thru-hole Vert. & rt. angle E8-E9 MSSA & MSSB 2 2 100 ma @ 30VDC or 125VAC & dry circuit No 10,000 P.C. thru-hole Vert. & rt. angle E10 MA 1 2&3 300 ma @ 4VDC No 10,000 Surface Rt. angle E11 MHSS 1&2 2 300 ma @ 6VDC No 5000 P.C. thru-hole Vert. & rt. angle E12 MS 1,2&4 2&3 300 ma @ 6VDC No 10,000 P.C. thru-hole & surface Vert. & rt, angle E13-E15 2&3 300 ma @ 4VDC No 10,000 Surface Right angle E15 MMPS New! 1 MMS 1,2,4&6 2&3 300 ma @ 30VDC No 10,000 P.C. thru-hole Vert. & rt. angle E16-E17 TG 1 2&3 500 ma @ 48V (AC or DC) & dry circuit Some 30,000 & 60,000 P.C. thru-hole Vert. & rt. angle E18-E20 NK 1 2 500 ma @ 12V No 1000 P.C. thru-hole Vertical E21 SERIES POLES POSITIONS RATINGS MSTS 1&2 3 300 ma @ 28VDC MINIATURE SLIDE SWITCHES MHS ! New 1&2 WASHABLE LIFE CYCLES MOUNTING ACTUATION PAGE(S) Yes 10,000 P.C. thru-hole Vertical E22 2&3 300 ma @ 30VDC Yes 10,000 P.C. thru-hole Vertical E23-E26 SLB 1&2 2,3,4&5 300 ma @ 30VDC or 125 VAC Yes 10,000 P.C. thru-hole Vert. & rt. angle E27-E34 SLC 1&2 2 300 ma @ 30VDC or 125 VAC Yes 10,000 Panel Vertical E35 SLG 1 2 300 ma @ 30VDC or 125 VAC Yes 10,000 P.C. thru-hole & panel Vertical E36 SLA 1&2 2 500 ma @ 125VAC Yes 10,000 P.C. thru-hole & panel Vertical E37-E38 SLE 1&2 2 500 ma @ 125VAC Yes 10,000 P.C. thru-hole & panel Vertical E38-E39 G 1&2 2&3 4 amps @ 125VAC, 2 amps @ 250 VAC or 3 amps @ 30 VDC & dry circuit No 20,000 60,000 P.C. thru-hole & panel Vert. & rt. angle E40-E44 25000N 1&2 2&3 4 amps @ 125 VAC, 2 amps @ 250 VAC or 3 amps @ 30 VDC & dry circuit No 10,000 20,000 P.C. thru-hole Vert. & rt. angle E45-E49 STANDARD SIZE SLIDE SWITCHES SERIES POLES POSITIONS MSS 1,2&4 2,3&4 300 ma @ 30VDC or 125 VAC & dry circuit M 1,2,4, 6&8 2&3 PM 1&2 2 E2 LIFE CYCLES MOUNTING ACTUATION PAGE(S) Yes 10,000 P.C. thru-hole Vert. & rt. angle E50-E52 300 ma @30VDC or 125 VAC Yes 10,000 P.C. thru-hole Vert. & rt. angle E53-E57 6 amps @ 125 VAC or 3 amps @ 250 VAC Yes 10,000 Panel Vertical E58 RATINGS WASHABLE APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SLIDE SWITCH SELECTION GUIDE: This catalog contains an extensive variety of slide switches with numerous options and accessories. To facilitate easy selection of the desired switch for your application, the guide on pages E2 & E3 lists the various Series with some key selection parameters. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SLIDE SWITCHES SLIDE SWITCH SELECTION GUIDE (CONT'D.) MINIATURE PUSHBUTTON STYLE SLIDE SWITCHES SERIES POLES POSITIONS RATINGS WASHABLE LIFE CYCLES MPS PB-1 SL-1 PB-1 SL-3 PB - 0.4 VA @ 20 V max. Slide - 300 ma @ 30VDC/125VAC MOUNTING ACTUATION PAGE(S) No 100,000 P.C. thru-hole Rt. angle E59 SERIES POLES POSITIONS RATINGS WASHABLE LIFE CYCLES MOUNTING ACTUATION PAGE(S) MSL 1 3,5&6 200 ma @ 30VDC/125VAC Yes 10,000 P.C. thru-hole Vertical E60 SINGLE POLE MULTI-POSITION SLIDE SWITCHES BATON TOGGLE STYLE SLIDE SWITCHES SERIES POLES POSITIONS MBT 2,4&6 2,3&4 E RATINGS WASHABLE LIFE CYCLES MOUNTING ACTUATION PAGE(S) 300 ma @ 30VDC/125VAC Yes 10,000 P.C. thru-hole Toggle E61-E63 ALPHA-NUMERIC INDEX BY SERIES SERIES Page (s) SERIES Page (s) G M E40 - E44 E53 - E57 MSSA E10 MA MBT E11 E61 - E63 MSSB MSTS E10 E22 MHS MHSS E23 - E26 E12 NK PM E21 E58 MMPS MJS E15 E8 - E9 SLA SLB E37 - E38 E27 - E34 MMS MPS E16 - E17 E59 SLC SLE E35 E38 - E39 MS MSL E13 - E15 E60 SLG 25000N E36 E45 - E49 MSS E50 - E52 TG TG (SMT) E18 - E20 E4 - E7 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E3 DESIGNED EXCLUSIVELY FOR SURFACE MOUNTING SMT TG Series switches incorporate many desireable features that include: ● Tape & reel packaging This type of packaging is recommended for: ● economy ● E ● ● positive component positioning protection of terminals against damage during handling ● high static resistance ● ● ● ● ● ● ● E4 To meet these requirements, APEM has designed a family of tiny surface mount switches that include TL Series toggle switches, TP Series pushbutton switches, TR Series rocker switches & TG Series slide switches. See toggle, pushbutton & rocker switch sections of catalog for TL, TP & TR Series respectively. Reflow solderable ● High temperature plastic materials ● ● suitability for automated placement handling of large quantities of components per packaging unit Surface mount devices (SMD) are subject to more stringent constraints of temperature, solderability, sealing and space savings than through-hole components. Tin plated grounding brackets Tin-lead alloy over nickel terminal plating Terminals turned outward to prevent the shadow effect in infrared soldering and to permit visual inspection of the solder joints .021" (0.55mm) air gap between p.c. board and switch case End stackable with .400" (10.16mm) pitch Available with positioning pins to assure correct switch orientation during the reflow process and provide additional mechanical integrity Washable Switches are designed to withstand cleaning processes, including hot water under pressure. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE TG SERIES - SMT WASHABLE TINY SLIDE SWITCHES TG SERIES - SMT WASHABLE TINY SLIDE SWITCHES ELECTRICAL SPECIFICATIONS Minimum load: 10 mA at 50 mV or 10µA at 5 VD Initial contact resistance: 20 milliohms maximum Insulation resistance: 1000 MΩ min. at 500 VDC Dielectric strength: 1000 V rms between terminals & frame. 500 V rms between terminals Electrical life (at full load): 2 position switches: 60,000 cycles 3 position switches: 30,000 cycles Static resistance: 10 KV (Schaffner equipment) GENERAL SPECIFICATIONS E PACKAGING Moisture resistance: 21 days per IEC 512-6 test 11c Vibration resistance: 10-500 Hz/10g per IEC 512-4 test 6d Shock resistance: 50 g per IEC 512-4 test 6c MATERIALS Case: High temperature plastic UL94V-0 Actuator: High temperature plastic UL94V-0 Grounding brackets: Tin plated steel (includes positioning pins) Contacts: Gold plated brass Terminals: Brass with tin-lead alloy over nickel plate Terminal seal: Epoxy 24.00–0.30 24.00 0.30 (.944 .011) (.944–.011) 24.40 +2.00/-0.00 (.960 +.078/-.000) 100.00 DIA MIN (3.937 DIA MIN) -40°C to +85°C 7.50 (.295) Operating temperature range: 16.00 (.629) .102" (2.60mm) Unrolling Direction Travel: 360.00 DIA MAX (14.173 DIA MAX) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Contact ratings (resistive lds.): 0.4 VA at 20 V max. (AC or DC) SOLDERING AND CLEANING 13.00 DIA–0.25 DIA 0.25 (.511 DIA–.009) DIA .009) Reflow soldering: Infrared, vapor phase and infrared convection Washable: Per IEA-RS448-2: water and detergent preferred. Solvents. 3.00 (.118) Standard packaging unit: 500 pieces Tape meeting international standard IEC Publication 286-3 (EIA481A) Start leader: 15.7" (400mm) min. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E5 TG SERIES - SMT WASHABLE TINY SLIDE SWITCHES Single pole slide switches 3.00 (.118) 1.50 (.059) 1.80 (.070) 7.96 (.313) 0.65 (.025) 4.30 (.169) 0.80 (.031) 2.10 (.082) 3.00 (.118) 2.54 (.100) 0.80 DIA (.031 DIA) 1.80 (.070) 3.81 (.150) 5.08 (.200) 0.50 (.019) P.C. BOARD DIMENSIONS 2.54 (.100) LED INDICATOR IN TINY PACKAGE 5.00 DIA (.196 DIA) 1.10 (.043) 4.20 (.165) 5.08 (.200) 1.30 (.051) 3.05 (.120) 5.55 (.218) 1.50 (.059) 7.96 (.313) 3 1 8.10 (.318) 6.90 (.271) 1.80 (.070) 3.80 (.149) 5.15 (.202) 4.60 DIA (.181 DIA) + 0.60 (.024) Tape & reel 10.16 (.400) 1.30 (.051) PACKAGING 2.10 (.082) 5.55 (.218) ELECTRICAL SPECIFICATIONS Forward voltage: Red; 3.0 volts at 10 milliamps (2V typical) Green; 3.0 volts at 20 milliamps (2.2V typical) Yellow; 3.0 volts at 10 milliamps (2.1V typical) Reverse voltage: 5.0 volts minimum Viewing angle (total): 90° Wavelength: Red; 635 nm Green; 565 nm Yellow; 585 nm 1 2 3 E6 6.90 (.271) 5.80 (.228) 9.60 (.378) 10.16 (.400) 9.45 (.372) 3.20 (.125) 5.55 (.218) 3.05 (.120) 5.00 (.196) 2.50 (.098) 3.81 (.150) 10.10 (.397) CIRCUIT ON ON ON OFF ON COLOR Red Green Yellow 2.54 (.100) 2.50 (.098) 3.05 (.120) MODEL NO. TV01WS00100 TV02WS00100 TV03WS00100 5.08 (.200) 4.30 (.169) 9.60 (.378) 10.16 (.400) 1.30 (.051) 2.54 (.100) Single pole slide switches with positioning pins SWITCH ACTION 2.10 (.082) 0.80 (.031) 0.50 (.019) 5.55 (.218) MODEL NO. TG36WS80065 TG39WS80065 1.50 (.059) 0.80 (.031) 5.08 (.200) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE 5.80 (.228) 3.20 (.125) 3.05 (.120) E 5.00 (.196) CIRCUIT ON ON ON OFF ON 0.90 (.035) MODEL NO. TG36WS80050 TG39WS80050 6.90 (.271) 10.10 (.397) 7.96 (.313) 2.50 (.098) 2.50 (.098) TG SERIES - SMT WASHABLE TINY SLIDE SWITCHES REFLOW SOLDERING - STANDARD PROFILE SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE The printed circuit board, carried by a conveyor belt,travels through the reflow soldering oven and experiences the following programmed cycles: a. pre-heat to a maximum of 200°C for 30 seconds b. reflow at a maximum of 245°C for 10 seconds c. final cleaning PROCESSING STEPS P.C. board TEMPERATURE/TIME PROFILE (typical) Solder paste application C 240 C 240 200 E Component placement 170 C 150 C 60 s 100 Reflow soldering 0 0 60 pre-heating 180 120 drying stabilization reflow peak 240 gradual cooling t (s) Final cleaning P.C. BOARD REWORK RECOMMENDATIONS Hot air reflow technique is preferred. Avoid the use of a soldering iron. Caution: Excessive and/or repeated high temperature exposure may affect switch performance & reliability. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E7 MJS Series SPECIFICATIONS FEATURES Contact rating: 100 mA at 12 VDC ● Bifurcated wiping contact design. Initial contact resistance: 20 milliohms max. ● Molded-in terminals minimize flux or solder entry. ● Molded-in high temperature phenolic base. Electrical life: 10,000 cycles min. ● Low Profile. Operating temperature range: -10°C to +60°C MATERIALS Actuation force: 225g (average) Contacts & terminals: Silver plated Solder heat resistance: 260°C max. for 5 seconds Case & actuator: Thermoplastic Washing not recommended Terminal seal: Molded-in Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS at sea level MODEL NO. MJS12 E VERTICAL ACTUATOR MODEL NO. MJS12R RIGHT ANGLE ACTUATOR 1P2T SCHEMATIC VERTICAL ACTUATOR E8 MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 1P2T SCHEMATIC MODEL NO. MJS13 .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 1P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Microminiature Slide Switches MJS Series Microminiature Slide Switches MODEL NO. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MJS13R RIGHT ANGLE ACTUATOR .079 (2.00) TRAVEL/THROW 1P3T SCHEMATIC MODEL NO. MJS22 VERTICAL ACTUATOR RIGHT ANGLE ACTUATOR P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P2T SCHEMATIC MODEL NO. MJS22R MECHANICAL OUTLINE E MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E9 MSSA & MSSB Series Microminiature Slide Switches FEATURES SPECIFICATIONS 20 V max. (AC or DC) Silver; 100 mA at 125 VAC or 30 VDC Initial contact resistance: 30 milliohms max. Insulation resistance: 100 megohms min. at 250 VDC Dielectric strength: 250 volts RMS at sea level Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Actuation force: 250g ± 150g Solder heat resistance: 260°C max. for 3 seconds Washing not recommended MODEL NO. E Low Profile. ● Epoxy sealed terminals. ● Cosmetic molded case. MATERIALS Contacts & terminals: Gold or silver available (see contact ratings) Housing and Actuator: Thermoplastic Base: High temperature thermoplastic Terminal seal: Epoxy PLATING MSSA22 SILVER MSSA22G GOLD VERTICAL ACTUATOR .098 (2.50) TRAVEL/THROW 2P2T PLATING MSSB22R SILVER MSSB22RG GOLD RIGHT ANGLE ACTUATOR MECHANICAL OUTLINE P.C. BOARD LAYOUT FEATURES Contact ratings: Gold; 0.4 Volt-Amps (VA) max. at 20 V max. (AC or DC) Silver; 100 mA at 125 VAC or 30 VDC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 250 VDC Dielectric strength: 250 volts RMS at sea level Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Actuation force: 200g ± 150g Solder heat resistance: 260°C max. for 3 seconds Washing not recommended MODEL NO. .098 (2.50) TRAVEL/THROW SCHEMATIC SPECIFICATIONS E10 ● ● Bifurcated wiping contact design. ● Low Profile. ● Epoxy sealed terminals. MATERIALS Contacts & terminals: Gold or silver available (see contact ratings) Housing: Tin plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet Terminal seal: Epoxy .079 (2.00) TRAVEL/THROW 2P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Contact ratings: Gold; 0.4 Volt-Amps (VA) max. at MA Series Microminiature Memory Card Slide Switches FEATURES SPECIFICATIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Contact rating: 300 mA at 4 VDC Initial contact resistance: 70 milliohms max. Insulation resistance: 100 megohms min. at 100 VDC Dielectric strength: 100 VAC for 1 minute Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Actuation force: 200g ± 100g Solder heat resistance: Reflow - 260°C max. for 1 min. Manual - iron temperature 305 °C max. for 6 seconds. Washing not recommended ● Ultra-compact size. ● Low Profile. ● Surface mounting with restraining bosses. ● Reflow or hand solderable. MATERIALS Contacts: Silver plated beryllium copper Terminals: Silver plated brass Base: Liquid crystal polymer Cover: Tin plated steel Actuator: Liquid crystal polymer MODEL NO. .059 (1.50) TRAVEL/THROW 1P2T MA12R .098 (2.50) TRAVEL/THROW E RIGHT ANGLE ACTUATOR SCHEMATIC MECHANICAL OUTLINE MODEL NO. P.C. BOARD LAYOUT .059 (1.50) TRAVEL/THROW 1P3T MA13R New! RIGHT ANGLE ACTUATOR SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT MODEL NO. MA12R/TR MA13R/TR Same as above models except supplied on tape & reel as shown. Model No. Dim. A MA12RTR .630 (16.0) .217 (5.5) Dim. B Dim. C .646 (16.4) MA13R/TR .945 (24.0) .453 (11.5) .960 (24.4) CARRIER TAPE REEL DIMENSIONS APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E11 MHSS Series SPECIFICATIONS FEATURES Contact ratings: 300 mA at 6 VDC ● Excellent tactile feed-back (detent action). Initial contact resistance: 60 milliohms max. ● Molded-in terminals minimize flux or solder entry. Insulation resistance: 100 megohms min. at 100 VDC ● Ultra-compact case size. Dielectric strength: 100 VAC for 1 minute ● Low profile. Electrical life: 5000 cycles min. Operating temperature range: -20°C to +70°C Solder heat resistance: 350°C max. for 3 seconds Washing not recommended MATERIALS Contacts & terminals: Silver plated Case: 30% Glass filled nylon, type 6/6, black Actuator: Nylon, type 6/6, black (blue for MHSS2220 only) MODEL NO. E MHSS1104 VERTICAL ACTUATOR .079 (2.00) TRAVEL/THROW 1P2T SCHEMATIC MECHANICAL OUTLINE .079 (2.00) TRAVEL/THROW MODEL NO. MHSS1105 RIGHT ANGLE ACTUATOR 1P2T SCHEMATIC MODEL NO. MHSS2220 RIGHT ANGLE ACTUATOR E12 P.C. BOARD LAYOUT P.C. BOARD LAYOUT MECHANICAL OUTLINE .079 (2.00) TRAVEL/THROW 2P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Microminiature Slide Switches MS Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Microminiature Slide Switches SPECIFICATIONS FEATURES Contact rating: 300 mA at 6 VDC ● Low profile. Initial contact resistance: 70 milliohms max. ● Insert molded terminals. Insulation resistance: 100 megohms max. at 500 VDC ● Stainless steel cover. Dielectric strength: 500 volts RMS at sea level Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Solder heat resistance: 260°C max. for 3 seconds Washing not recommended MODEL NO. MS12 VERTICAL ACTUATOR VERTICAL ACTUATOR VERTICAL ACTUATOR Terminal seal: Insert molded .079 (2.00) TRAVEL/THROW SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 1P3T SCHEMATIC MODEL NO. MS13S Contacts & terminals: Silver plated Cover: Stainless steel Actuator: Thermoplastic Base: High temperature thermoplastic 1P2T MODEL NO. MS13 MATERIALS MECHANICAL OUTLINE P.C. BOARD CUTOUT .079 (2.00) TRAVEL/THROW 1P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E13 MS Series Microminiature Slide Switches MS22 VERTICAL ACTUATOR MODEL NO. MS22R E RIGHT ANGLE ACTUATOR .079 (2.00) TRAVEL/THROW 2P2T SCHEMATIC 2P2T SCHEMATIC MODEL NO. MS23 VERTICAL ACTUATOR RIGHT ANGLE ACTUATOR E14 P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P3T SCHEMATIC MODEL NO. MS23R MECHANICAL OUTLINE MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD CUTOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. MODEL NO. .079 (2.00) TRAVEL/THROW 2P3T SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MS23S SCHEMATIC VERTICAL ACTUATOR MODEL NO. MECHANICAL OUTLINE .079 (2.00) TRAVEL/THROW 4P2T MS42R P.C. BOARD CUTOUT E RIGHT ANGLE ACTUATOR SCHEMATIC MECHANICAL OUTLINE N ew! MMPS Series Microminiature Pushbutton Style Slide Switches SPECIFICATIONS FEATURES Contact rating: 300 mA at 4 VDC ● Initial contact resistance: 70 milliohms max. Insulation resistance: 100 megohms min. at 100 VDC Dielectric strength: 100 VAC for 1 minute Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Actuation force: Pushbutton; 200g average Slide; 275g average Solder heat resistance: 260°C max. for 3 seconds Washing not recommended ● MODEL NO. MMPS101 RIGHT ANGLE ACTUATOR ● ● P.C. BOARD LAYOUT Surface mounting configuration. Combination momentary pushbutton & slide switch mechanism. Ultra-low profile & ultra-compact case. Molded-in terminal seal. MATERIALS Contacts: Gold plated copper alloy Frame: Stainless steel Actuator: 6/6 Nylon or PA Base: High temperature PPS Terminal seal: Molded-in 1P2T, (PB) 1P3T, (Slide) SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E15 MMS Series SPECIFICATIONS FEATURES Contact ratings: 300 mA at 30 VDC ● Bifurcated wiping contact design. Initial contact resistance: 25 milliohms max. ● Low Profile. Insulation resistance: 100 megohms min. at 500 VDC ● Epoxy sealed terminals. Dielectric strength: 500 volts RMS for 1 minute ● Cosmetic molded case. Electrical life: 10,000 cycles min. Operating temperature range: -20°C to +70°C Solder heat resistance: 255°C max. for 5 seconds max. Washing not recommended MODEL NO. MMS22R E RIGHT ANGLE ACTUATOR 2P2T SCHEMATIC MODEL NO. MMS23R RIGHT ANGLE ACTUATOR RIGHT ANGLE ACTUATOR E16 Contacts & terminals: Silver plated Case: Polyacetal Actuator: PBT Base: Glass filled PBT Terminal seal: Epoxy or phenol resin .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P3T SCHEMATIC MODEL NO. MMS42R MATERIALS MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 4P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Microminiature Slide Switches MMS Series Microminiature Slide Switches MODEL NO. .098 (2.50) TRAVEL/THROW 1P2T SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MMS1208 VERTICAL ACTUATOR MODEL NO. SCHEMATIC MECHANICAL OUTLINE .079 (2.00) TRAVEL/THROW 2P2T MMS2214 VERTICAL ACTUATOR SCHEMATIC MODEL NO. P.C. BOARD LAYOUT E MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 4P2T MMS42 New! VERTICAL ACTUATOR MODEL NO. MMS6202 VERTICAL ACTUATOR SCHEMATIC 6P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E17 TG Series SPECIFICATIONS FEATURES Contact ratings: Gold; 0.4 Volt-Amps max. at 20 V max. Silver; 500 mA at 48 V max. (AC or DC) Initial contact resistance: 20 milliohms max. Insulation resistance: 1000 megohms min. at 500 VDC Dielectric strength: 1000 V rms min. between terms. and ground plate (and bracket) Electrical life: 2 position switches-60,000 cycles min. 3 position switches-30,000 cycles min. Operating temperature range: -30°C to +85°C Solder heat resistance: 260°C for 5 seconds max. Washing: Permissible (with model option 50) ● MODEL NO. E TG36P000000 TG39P000000 TG36P010000 TG39P010000 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on MODEL NO. PLATING Gold Gold Silver Silver ACTION on - on on off on on - on on off on PROCESS COMPATIBLE MODEL NO. TG36Y000000 TG39Y000000 TG36Y010000 TG39Y010000 PLATING Gold Gold Silver Silver ACTION on - on on off on on - on on off on ● MATERIALS Contacts & terminals: Gold or silver available (see contact ratings) Actuator: Thermoplastic Ground plate & bracket: Tin plated steel Case: Flame retardant thermoplastic Terminal seal: Epoxy Washable seal: Translucent silicone rubber (with model option 50) TRAVEL/THROW; .102 (2.60) FUNCTION (see page e 20) MECHANICAL OUTLINE STRAIGHT P.C. TERMINALS - WASHABLE MODELS P.C. BOARD LAYOUT TRAVEL/THROW; .102 (2.60) FUNCTION (see page e 20) SCHEMATIC MECHANICAL OUTLINE STRAIGHT P.C. TERMINALS - BRACKET MTG. - STANDARD MODELS P.C. BOARD LAYOUT TRAVEL/THROW; .102 (2.60) FUNCTION (see page e 20) SCHEMATIC E18 ● Ultra-compact case size. Washable models. SPDT maintained action with long electrical life. See additional options on pg. E20. STRAIGHT P.C. TERMINALS - STANDARD MODELS SCHEMATIC TG36P000050 TG39P000050 TG36P010050 TG39P010050 ● MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Microminiature Slide Switches TG Series Microminiature Slide Switches SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. TG36Y000050 TG39Y000050 TG36Y010050 TG39Y010050 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on PROCESS COMPATIBLE MODEL NO. TG36W000000 TG39W000000 TG36W010000 TG39W010000 PLATING Gold Gold Silver Silver ACTION on - on on off on on - on on off on STRAIGHT P.C. TERMINALS - BRACKET MTG. - WASHABLE MODELS FUNCTION (see page e 20) SCHEMATIC MODEL NO. PLATING Gold Gold Silver Silver ACTION on - on on off on on - on on off on PROCESS COMPATIBLE MECHANICAL OUTLINE RIGHT ANGLE TERMINALS - HORIZONTAL MTG. - STANDARD MODELS P.C. BOARD LAYOUT TRAVEL/THROW; .102 (2.60) FUNCTION E (see page e 20) SCHEMATIC TG36W000050 TG39W000050 TG36W010050 TG39W010050 TRAVEL/THROW; .102 (2.60) MECHANICAL OUTLINE RIGHT ANGLE TERMINALS - HORIZONTAL MTG. - WASHABLE MODELS P.C. BOARD LAYOUT TRAVEL/THROW; .102 (2.60) FUNCTION (see page e 20) SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT General tolerances for all TG Series drawings - ± .012" (0.3 mm) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E19 TG Series Microminiature Slide Switches 'BUILD YOUR OWN SWITCH' ORDER FORMAT Fill in boxes shown with options selected from below. Allowable options for each box are shown under each respective box. Series Poles Function T G 3 6 9 E Contact & Terms. Term. Mat'l. Actuator P Y W M 0 0 0 W 0 1 3 8 9 0 0 1 0 Model 0 0 5 0 Poles: 3 = Single Pole Functions: 6 = ON - ON Terminals: P 0 = Straight printed circuit terminals Y 0 = Straight printed circuit terminals, bracket mtg. W 0 = Right angle printed circuit terminals, horizontal mtg. with bracket M W = Wirewrap terminals 9 = ON OFF ON Contact & terminal materials: 0 = Brass, gold plated (standard) 1 = Brass, silver plated 3 = Brass, gold plated (1.27 microns gold) 8 = Brass contacts, gold plated and tin plated terminals 9 = Brass contacts, gold plated (1.27 microns gold) and tin plated terminals Actuators: 0 0 = High (standard) 1 0 = Flush Model: 0 0 = Standard 5 0 = Washable Options MW (wirewrap terminals) and 10 (flush actuator) MW E20 10 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Additional ordering information: Commonly ordered models are shown on preceeding pages with complete model numbers and specifications. Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply selecting from all available options shown and filling in the boxes. ! N e w uator SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Rais NK Series t ed ac Microminiature Slide Switches SPECIFICATIONS FEATURES Contact rating: 500 mA 12V max. - 1mA 10 mV min. Initial contact resistance: 20 milliohms max. Insulation resistance: 10,000 MΩ min. at 500VDC ● Dielectric strength: 250 Vrms between terminals 2000 Vrms between adjacent poles placed side by side Electrical life: 2,000 cycles min. ● MATERIALS Operating temperature range: -40°C to +85°C Solder heat resistance: 250°C max. for 5 seconds Washing not recommended Contacts & terminals: Gold over nickel plated Case: PBT, glass filled (UL94V-0) Actuator: PBT, glass filled (UL94V-0) ● ● ● Cost effective. Flush or raised actuator. Wave solderable, flux sealed. Through-hole round terminals, straight or right angle. Stackable in X & Y directions ( with straight terminals). MODEL NO. NK236 Flush actuator (shown) .062 (1.6) TRAVEL 1P2T E NK236H Raised actuator VERTICAL ACTUATOR SCHEMATIC MECHANICAL OUTLINE MODEL NO. NK236W Flush actuator P.C. BOARD LAYOUT .062 (1.6) TRAVEL 1P2T NK236WH Raised actuator (shown) RIGHT ANGLE TERMINALS SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT EXAMPLE OF PRINTED CIRCUIT BOARD LAYOUT FOR STACKING UNITS Pitch = .100" (2.54mm) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E21 MSTS Series SPECIFICATIONS FEATURES Contact rating: 300 mA at 28 VDC ● Initial contact resistance: 20 milliohms max. ● Insulation resistance: 100 megohms min. at 500 VDC ● ● Dielectric strength: 500 VAC for 1 minute Miniature compact size. Wash-through open frame construction. Snap-in p.c. mounting bracket design. Positive spring loaded ball detent mechanism. Epoxy sealed terminals. Gold plated contacts available - consult factory. Electrical life: 10,000 cycles min. ● ● Operating temperature range: -20°C to +85°C MATERIALS Solder heat resistance: 250°C max. for 5 seconds Contacts & terminals: Silver plated brass Housing: Zinc plated steel Actuator: Polyacetal, color black Base: Phenolic laminated sheet Actuation force: 200-600 grams Solvent washing permissible MODEL NO. MSTS1332K E VERTICAL ACTUATOR 1P3T SCHEMATIC MODEL NO. MSTS2332K VERTICAL ACTUATOR E22 2P3T SCHEMATIC Terminal seal: Epoxy .098 (2.50) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .098 (2.50) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Slide Switches MHS Series Miniature Slide Switches with aluminum actuator SPECIFICATIONS FEATURES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Contact rating: 300 mA at 30 VDC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 VAC for 1 minute Electrical life: 10,000 cycles min. ● Miniature compact size. ● Wash-through open frame construction. ● Positive spring loaded ball detent mechanism. ● Epoxy sealed terminals. Operating temperature range: -20°C to +85°C MATERIALS Solder heat resistance: 260°C max. for 3 seconds Contacts & terminals: Silver plated brass Housing: Tin plated steel Actuator: Aluminum alloy Base: Phenolic laminated sheet Actuation force: 250 ±150 grams Solvent washing permissible MODEL NO. MHS122K VERTICAL ACTUATOR .157 (4.0) TRAVEL/THROW 1P2T E SCHEMATIC MODEL NO. MHS123K Terminal seal: Epoxy 1P2T w/center MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW OFF VERTICAL ACTUATOR MODEL NO. MHS133K VERTICAL ACTUATOR SCHEMATIC 1P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E23 MHS Series Miniature Slide Switches with aluminum actuator MHS222K VERTICAL ACTUATOR MODEL NO. .157 (4.00) TRAVEL/THROW 2P2T SCHEMATIC 2P2T w/center MECHANICAL OUTLINE OFF P.C. BOARD LAYOUT .079 (2.0) TRAVEL/THROW MHS223K E VERTICAL ACTUATOR SCHEMATIC MODEL NO. 2P3T MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.0) TRAVEL/THROW MHS233K VERTICAL ACTUATOR E24 SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. MHS Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE ! New Miniature Slide Switches SPECIFICATIONS FEATURES Contact rating: 300 mA at 30 VDC ● Miniature compact size. ● Wash-through open frame construction. ● Positive spring loaded ball detent mechanism. Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 VAC for 1 minute Electrical life: 10,000 cycles min. ● Operating temperature range: -20°C to +85°C MATERIALS Solder heat resistance: 260°C max. for 3 seconds Contacts & terminals: Silver plated brass Housing: Tin plated steel Actuator: Polyacetal Base: Phenolic laminated sheet Actuation force: 250 ±150 grams Solvent washing permissible MODEL NO. MHS122 VERTICAL ACTUATOR MODEL NO. MHS123 Epoxy sealed terminals. Terminal seal: Epoxy .157 (4.0) TRAVEL/THROW 1P2T E SCHEMATIC 1P2T w/center MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW OFF VERTICAL ACTUATOR MODEL NO. MHS133 VERTICAL ACTUATOR SCHEMATIC 1P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E25 MHS Series New Miniature Slide Switches MHS222 VERTICAL ACTUATOR MODEL NO. .157 (4.00) TRAVEL/THROW 2P2T SCHEMATIC 2P2T w/center MECHANICAL OUTLINE OFF P.C. BOARD LAYOUT .079 (2.0) TRAVEL/THROW MHS223 E VERTICAL ACTUATOR SCHEMATIC MODEL NO. 2P3T MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.0) TRAVEL/THROW MHS233 VERTICAL ACTUATOR E26 SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. ! SLB Series (with p.c. board stand-off bracket) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Slide Switches SPECIFICATIONS FEATURES Contact ratings: 300 mA at 125 VAC or 30 VDC ● Miniature compact size. Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS for 1 minute Electrical life: 10,000 cycles min. ● Wash-through open frame construction. Operating temperature range: -20°C to +85°C Actuation force: 220g ± 100g Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MATERIALS ● Positive spring loaded ball detent mechanism. ● Epoxy sealed terminals. Contacts & terminals: Silver plated Frame: Zinc plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet MODEL NO. SLB12814 VERTICAL ACTUATOR MODEL NO. SLB1281R5 RIGHT ANGLE ACTUATOR .126 (3.20) TRAVEL/THROW 1P2T SCHEMATIC VERTICAL ACTUATOR E MECHANICAL OUTLINE SCHEMATIC 1P3T SCHEMATIC P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW 1P2T MODEL NO. SLB1370 Terminal seal: Epoxy MECHANICAL OUTLINE P.C. BOARD LAYOUT .090 (2.30) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E27 SLB Series (with p.c. board stand-off bracket) Miniature Slide Switches SLB13814 VERTICAL ACTUATOR 1P3T SCHEMATIC MODEL NO. SLB1381R5 E RIGHT ANGLE ACTUATOR VERTICAL ACTUATOR VERTICAL ACTUATOR E28 P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .090 (2.30) TRAVEL/THROW 1P4T SCHEMATIC MODEL NO. SLB1570 MECHANICAL OUTLINE 1P3T MODEL NO. SLB1470 .126 (3.20) TRAVEL/THROW 1P5T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .090 (2.30) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. SLB Series (with p.c. board stand-off bracket) Miniature Slide Switches MODEL NO. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SLB22814 VERTICAL ACTUATOR 2P2T SCHEMATIC MODEL NO. SLB2281R5 RIGHT ANGLE ACTUATOR MODEL NO. SLB23814 VERTICAL ACTUATOR RIGHT ANGLE ACTUATOR MECHANICAL OUTLINE P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW 2P2T SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW 2P3T SCHEMATIC MODEL NO. SLB2381R5 .126 (3.20) TRAVEL/THROW 2P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E29 SLB Series (with thru- p.c. board hole mounting bracket) SPECIFICATIONS FEATURES Contact ratings: 300 mA at 125 VAC or 30 VDC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS for 1 minute ● Miniature compact size. ● Wash-through open frame construction. ● Positive spring loaded ball detent mechanism. ● Epoxy sealed terminals. Electrical life: 10,000 cycles min. Operating temperature range: -20°C to +85°C Actuation force: 220g ± 100g Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MODEL NO. SLB12804 E VERTICAL ACTUATOR VERTICAL ACTUATOR RIGHT ANGLE ACTUATOR E30 Terminal seal: Epoxy .126 (3.20) TRAVEL/THROW SCHEMATIC 1P2T SCHEMATIC MODEL NO. SLB1240R45 Contacts & terminals: Silver plated Frame: Zinc plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet 1P2T MODEL NO. SLB124145 MATERIALS 1P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Slide Switches SLB Series (with thru- p.c. board hole mounting bracket) Miniature Slide Switches MODEL NO. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SLB1280R5 RIGHT ANGLE ACTUATOR 1P2T SCHEMATIC MODEL NO. SLB1250R8 RIGHT ANGLE ACTUATOR MODEL NO. SLB1370R RIGHT ANGLE ACTUATOR VERTICAL ACTUATOR MECHANICAL OUTLINE P.C. BOARD LAYOUT .098 (2.50) TRAVEL/THROW 1P2T SCHEMATIC 1P3T SCHEMATIC MODEL NO. SLB13804 .126 (3.20) TRAVEL/THROW 1P3T SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT .090 (2.30) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E31 SLB Series (with thru-p.c. board hole mounting bracket) Miniature Slide Switches SLB134145 VERTICAL ACTUATOR 1P3T SCHEMATIC MODEL NO. SLB1340R45 E RIGHT ANGLE ACTUATOR 1P3T SCHEMATIC MODEL NO. SLB1380R5 RIGHT ANGLE ACTUATOR RIGHT ANGLE ACTUATOR E32 MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW 1P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .090 (2.30) TRAVEL/THROW MODEL NO. SLB1470R .079 (2.00) TRAVEL/THROW 1P4T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. SLB Series (with thru-p.c. board hole mounting bracket) Miniature Slide Switches MODEL NO. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SLB1570R RIGHT ANGLE ACTUATOR .090 (2.30) TRAVEL/THROW 1P5T SCHEMATIC VERTICAL ACTUATOR 2P2T SCHEMATIC MODEL NO. SLB224145 VERTICAL ACTUATOR RIGHT ANGLE ACTUATOR E MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 2P2T SCHEMATIC MODEL NO. SLB2240R45 P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW MODEL NO. SLB22804 MECHANICAL OUTLINE MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 2P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E33 SLB Series (with thru-p.c. board hole mounting bracket) Miniature Slide Switches SLB2280R5 RIGHT ANGLE ACTUATOR .126 (3.20) TRAVEL/THROW 2P2T SCHEMATIC MODEL NO. SLB23804 E VERTICAL ACTUATOR VERTICAL ACTUATOR .126 (3.20) TRAVEL/THROW SCHEMATIC RIGHT ANGLE ACTUATOR E34 MECHANICAL OUTLINE P.C. BOARD LAYOUT .126 (3.20) TRAVEL/THROW 2P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MODEL NO. SLB2340R45 P.C. BOARD LAYOUT 2P3T MODEL NO. SLB234145 MECHANICAL OUTLINE 2P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. SLC Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Slide Switches SPECIFICATIONS FEATURES Contact ratings: 300 mA at 125 VAC or 30 VDC ● Panel mounting with solder lug terminals. ● Wash-through open frame construction. ● Positive spring loaded ball detent mechanism. Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS for 1 minute Electrical life: 10,000 cycles min. Operating temperature range: -20°C to +85°C Actuation force: 220g ± 100g Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MATERIALS Contacts & terminals: Silver plated Frame: Zinc plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet .134 (3.40) TRAVEL/THROW MODEL NO. 1P2T SLC12007 SCHEMATIC E MECHANICAL OUTLINE PANEL CUTOUT .134 (3.40) TRAVEL/THROW MODEL NO. 1P2T SLC120025 New! SCHEMATIC PANEL CUTOUT .134 (3.40) TRAVEL/THROW MODEL NO. SLC22007 MECHANICAL OUTLINE 2P2T SCHEMATIC MECHANICAL OUTLINE PANEL CUTOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E35 SLG Series SPECIFICATIONS FEATURES Contact ratings: 300 mA at 125 VAC or 30 VDC ● Wash-through open frame construction. ● Panel and p.c. mounting models. ● Positive spring loaded ball detent mechanism. Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS for 1 minute Electrical life: 10,000 cycles min. Operating temperature range: -20°C to +85°C Actuation force: 200g ± 75g Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MODEL NO. SLG12004 E SLG12014 VERTICAL MOUNTING E36 Contacts & terminals: Silver plated Frame: Zinc plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet .118 (3.00) TRAVEL/THROW 1P2T SCHEMATIC MODEL NO. MATERIALS 1P2T SCHEMATIC MECHANICAL OUTLINE PANEL CUTOUT .118 (3.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Slide Switches SLA Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Slide Switches SPECIFICATIONS FEATURES Contact ratings: 500 mA at 125 VAC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS for 1 minute ● Miniature compact size. ● Wash-through open frame construction. ● Panel and p.c. mounting models. Electrical life: 10,000 cycles min. Operating temperature range: -20°C to +85°C Actuation force: 350g ± 200g Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MODEL NO. SLA1200 .106 (2.70) TRAVEL/THROW MODEL NO. 1P2T SCHEMATIC MODEL NO. SLA2200 Contacts & terminals: Silver plated brass Frame: Zinc plated steel Actuator: PBT Thermoplastic Base: Phenolic laminated sheet 1P2T SCHEMATIC SLA1201 MATERIALS 2P2T SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT .106 (2.70) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .106 (2.70) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E37 .106 (2.70) TRAVEL/THROW 2P2T SLA2201 SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT SLE Series Miniature Slide Switches E SPECIFICATIONS FEATURES Contact ratings: 500 mA at 125 VAC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC ● Miniature compact size. ● Wash-through open frame construction. Dielectric strength: 500 volts RMS for 1 minute Electrical life: 10,000 cycles min. Operating temperature range: -20°C to +85°C Actuation force: 350g ± 200g ● Panel and p.c. mounting models. Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MATERIALS Contacts & terminals: Silver plated brass Frame: Zinc plated steel Actuator: PBT Thermoplastic Base: Phenolic laminated sheet MODEL NO. SLE1200 .153 (3.90) TRAVEL/THROW 1P2T SCHEMATIC MECHANICAL OUTLINE MODEL NO. SLE1201 E38 .153 (3.90) TRAVEL/THROW 1P2T SCHEMATIC P.C. BOARD LAYOUT MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. SLE Series Miniature Slide Switches MODEL NO. 2P2T .153 (3.90) TRAVEL/THROW SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SLE2200 SCHEMATIC MECHANICAL OUTLINE MODEL NO. SLE2201 P.C. BOARD LAYOUT .153 (3.90) TRAVEL/THROW 2P2T E SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E39 G Series SPECIFICATIONS FEATURES Contact ratings: Gold; 0.4 Volt-Amps (VA) max. at 20 V max. (AC or DC) Silver; 4 A at 125 VAC,2 A at 250 VAC or 3 A at 30 VDC Initial contact resistance: 10 milliohms max. Insulation resistance: 1000 megohms min. Dielectric strength: 1000 V rms min. Electrical life w/resistive load: Gold; 60,000 cycles min. Silver; 2 pos. - 40,000 cycles, 3 pos. - 20,000 cycles Operating temperature range: -30°C to +85°C Solder heat resistance: 300°C max. for 5 seconds Washing not recommended ● Epoxy sealed terminals. ● Break-before-make contact action. SPDT and DPDT models with long electrical life. Many additional models & options available (see page E44). MODEL NO. E GH36S000001 GH39S000001 GH36S010001 GH39S010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on SPDT GH36P000001 GH39P000001 GH36P010001 GH39P010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on GH36W000001 GH39W000001 GH36W010001 GH39W010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on SPDT MECHANICAL OUTLINE PANEL CUTOUT .086 (2.20) TRAVEL/THROW Function (see pg. E46) SPDT MECHANICAL OUTLINE P.C. BOARD LAYOUT .086 (2.20) TRAVEL/THROW Function (see pg. E46) SCHEMATIC E40 Contacts & terminals: Gold or silver available (see contact ratings) Cover: Stainless steel Actuator: Glass filled polyamide Case: PES high temp. thermoplastic Terminal seal: Epoxy Function (see pg. E46) SCHEMATIC MODEL NO. MATERIALS .086 (2.20) TRAVEL/THROW SCHEMATIC MODEL NO. ● ● MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Instrument Grade Miniature Slide Switches G Series Instrument Grade Miniature Slide Switches SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. PLATING GH36WW00001 GH39WW00001 GH36WW10001 GH39WW10001 Gold Gold Silver Silver ACTION on - on on off on on - on on off on SPDT .086 (2.20) TRAVEL/THROW Function (see pg. E46) SCHEMATIC MODEL NO. GH36Y000001 GH39Y000001 GH36Y010001 GH39Y010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on MECHANICAL OUTLINE SPDT .086 (2.20) TRAVEL/THROW E Function (see pg. E46) SCHEMATIC MODEL NO. GH36Y400001 GH39Y400001 GH36Y410001 GH39Y410001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on P.C. BOARD LAYOUT MECHANICAL OUTLINE SPDT P.C. BOARD LAYOUT .086 (2.20) TRAVEL/THROW Function (see pg. E46) SCHEMATIC MECHANICAL OUTLINE ACTUATOR POSITION AND CONNECTIONS (FOR BOTH SP & DP MODELS) SOLDER LUG TERMINAL Function 6 ON NONE ON Function 9 ON OFF ON P.C. BOARD LAYOUT P.C. TERMINAL APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E41 G Series Instrument Grade Miniature Slide Switches GH46S000001 GH49S000001 GH46S010001 GH49S010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on DPDT .086 (2.20) TRAVEL/THROW Function (see pg. E46) E SCHEMATIC MODEL NO. GH46P000001 GH49P000001 GH46P010001 GH49P010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on DPDT GH46W000001 GH49W000001 GH46W010001 GH49W010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on Function (see pg. E46) DPDT MECHANICAL OUTLINE P.C. BOARD LAYOUT .086 (2.20) TRAVEL/THROW Function (see pg. E46) SCHEMATIC E42 P.C. BOARD LAYOUT .086 (2.20) TRAVEL/THROW SCHEMATIC MODEL NO. MECHANICAL OUTLINE MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. G Series Instrument Grade Miniature Slide Switches SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. GH46WW00001 GH49WW00001 GH46WW10001 GH49WW10001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on DPDT .086 (2.20) TRAVEL/THROW Function (see pg. E46) E SCHEMATIC MODEL NO. GH46Y000001 GH49Y000001 GH46Y010001 GH49Y010001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on DPDT GH46Y400001 GH49Y400001 GH46Y410001 GH49Y410001 PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on P.C. BOARD LAYOUT .086 (2.20) TRAVEL/THROW Function (see pg. E46) SCHEMATIC MODEL NO. MECHANICAL OUTLINE DPDT MECHANICAL OUTLINE P.C. BOARD LAYOUT .086 (2.20) TRAVEL/THROW Function (see pg. E46) SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E43 G Series Additional ordering information: Commonly ordered models are shown on pgs. E40 thru E43 with complete specifications. Below is an ordering format that enables you to 'build your own switch' by simply selecting from all available options shown and filling in the boxes. Instrument Grade Miniature Slide Switches Fill in all boxes shown with options selected from below. Allowable options for each box are shown under each respective box. Series Actuator Height Poles Function Terminals Contact & Term. Mat'l. Special Option 1 Special Option 2 G B* C E* H L* N E 3 4 6 9 S 0 P 0 W 0 WW Y 0 Y 4 0 1 2 5 8 0 1 1 1 0 0 1 2 0 0 1 1 0 1 0 1 * indicates Actuator options B, E & L are available for single pole models only . Actuators heights: Dimensions in inches and millimeters. H is standard. B = .301" (7.65mm) C = .137" (3.50mm) E = .358" (9.10mm) H = .200" (5.10mm) for S0 & P0 and .185" (4.70mm) for Y,Y4,W0 & WW L = .251" (6.40mm) N = .374" (9.50mm) Poles: Functions: 3 = Single Pole 6 = ON - ON 4 = Double Pole 9 = ON OFF ON Terminals: See completely specified models in prior section for configurations and dimensions. S0 = Solder lugs P0 = .250" (6.35mm) long Printed circuit terminals W0 = Right angle horizontal p.c. terminals with mounting bracket WW = Right angle vertical p.c. terminals with mounting bracket Y0 = P.C. terminals with short bracket Y4 = P.C. terminals with tall bracket Contact & terminal materials: See contact ratings under "specifications". 0 = Gold plated brass 1 = Silver 2 = Gold plated silver 5 = Special contact with lower rating 8 = Gold plated brass contacts with tin plated terminals (not available w/SO) Special options 1: 00 = Standard model 10 = Switch without ground plate 11 = .407" (10.35mm) long printed circuit terminals 12 = Same as 11 except without ground plate Special options 2: 00 = No epoxy seal (for printed circuit terminals only as S0 (solder lug) terminals are always sealed) 01 = Epoxy sealed terminals (standard on solder lug models) 10 = Extended terminals for WW models (see figure 1) 11 = Same as 10 above except with epoxy sealed terminals E44 figure 1 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE 'BUILD YOUR OWN SWITCH' ORDER FORMAT 25000N Series Miniature Slide Switches FEATURES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE SPECIFICATIONS Contact ratings: Gold; 0.4 Volt-Amps (VA) max. at 20 V max. (AC or DC) Silver; 4 A at 125 VAC,2 A at 250 VAC or 3 A at 30 VDC Initial contact resistance: Gold; 50 milliohms max. Silver; 10 milliohms max. Insulation resistance: 1000 megohms min. at 500 VDC Dielectric strength: 1000 V rms min. between terms. Electrical life: Gold; 20,000 cycles, Silver; 10,000 cycles Operating temperature range: -40°C to +85°C Solder heat resistance: 300°C max. for 5 seconds Washing not recommended. MODEL NO. PLATING ACTION SINGLE POLE 25136NLDB 25139NLDB 25136NAB 25139NAB Gold Gold Silver Silver on - on on off on on - on on off on FLUSH ACTUATOR VERTICAL ACTUATOR MODEL NO. 25336NLD 25339NLD 25336NA 25339NA PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on RIGHT ANGLE ACTUATOR Molded-in terminals. .100" (2,54mm) and .200" (5,08mm) terminal spacing. ● Many additional models & options available (see page E49). ● Optional UL recognized & marked models available . MATERIALS Contacts & terminals: Gold or silver available (see contact ratings) Actuator and Cover: Glass filled polyamide Case: PBT high temp. thermoplastic Terminal seal: Epoxy TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) E Function (see pg. E51) SCHEMATIC SINGLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC MODEL NO. PLATING ACTION DOUBLE POLE 25146NLDB 25149NLDB 25146NAB 25149NAB Gold Gold Silver Silver on - on on off on on - on on off on FLUSH ACTUATOR VERTICAL ACTUATOR ● ● MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) . G36) SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E45 25000N Series Miniature Slide Switches 25346NLD 25349NLD 25346NA 25349NA PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on RIGHT ANGLE ACTUATOR E DOUBLE POLE Function (see pg. E51) SCHEMATIC MODEL NO. PLATING ACTION SINGLE POLE 25436NLDB 25439NLDB 25436NAB 25439NAB Gold Gold Silver Silver on - on on off on on - on on off on FLUSH ACTUATOR VERTICAL ACTUATOR MODEL NO. 25536NLD 25539NLD 25536NA 25539NA PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on RIGHT ANGLE ACTUATOR MODEL NO. 25446NLDB 25449NLDB 25446NAB 25449NAB PLATING Gold Gold Silver Silver E46 MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC SINGLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC ACTION DOUBLE POLE on - on on off on on - on on off on FLUSH ACTUATOR VERTICAL ACTUATOR TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. 25000N Series Miniature Slide Switches SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. 25546NLD 25549NLD 25546NA 25549NA PLATING ACTION Gold Gold Silver Silver on - on on off on on - on on off on RIGHT ANGLE ACTUATOR MODEL NO. PLATING ACTION 25136NLDH 25139NLDH 25136NAH 25139NAH Gold Gold Silver Silver on - on on off on on - on on off on VERTICAL ACTUATOR MODEL NO. PLATING ACTION 25336NLD6 25339NLD6 25336NA6 25339NA6 Gold Gold Silver Silver on - on on off on on - on on off on RIGHT ANGLE ACTUATOR MODEL NO. PLATING ACTION 25146NLDH 25149NLDH 25146NAH 25149NAH Gold Gold Silver Silver on - on on off on on - on on off on VERTICAL ACTUATOR DOUBLE POLE TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 Function (see pg. E51) SCHEMATIC SINGLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 E Function (see pg. E51) SCHEMATIC SINGLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC DOUBLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E47 25000N Series Miniature Slide Switches 25346NLD6 25349NLD6 25346NA6 25349NA6 PLATING Gold Gold Silver Silver ACTION on - on on off on on - on on off on RIGHT ANGLE ACTUATOR E MODEL NO. PLATING ACTION 25436NLDH 25439NLDH 25436NAH 25439NAH Gold Gold Silver Silver on - on on off on on - on on off on VERTICAL ACTUATOR MODEL NO. PLATING ACTION 25536NLD6 25539NLD6 25536NA6 25539NA6 Gold Gold Silver Silver on - on on off on on - on on off on RIGHT ANGLE ACTUATOR MODEL NO. PLATING ACTION 25446NLDH 25449NLDH 25446NAH 25449NAH Gold Gold Silver Silver on - on on off on on - on on off on VERTICAL ACTUATOR E48 DOUBLE POLE TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 Function (see pg. E51) SCHEMATIC SINGLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 Function (see pg. E51) SCHEMATIC SINGLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC DOUBLE POLE MECHANICAL OUTLINE P.C. BOARD LAYOUT TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. E51) SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. 25000N Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Slide Switches MODEL NO. PLATING 25546NLD6 25549NLD6 25546NA6 25549NA6 Gold Gold Silver Silver ACTION DOUBLE POLE on - on on off on on - on on off on TRAVEL/THROW; 3 POSITION - .078 (2.00) 2 POSITION - .150 (3.80) Function (see pg. below) SCHEMATIC RIGHT ANGLE ACTUATOR MECHANICAL OUTLINE P.C. BOARD LAYOUT Additional ordering information: Commonly ordered models are shown above and on preceeding pages with complete model numbers and specifications. Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply selecting from all available options shown and filling in the boxes. 'BUILD YOUR OWN SWITCH' ORDER FORMAT Fill in boxes shown with options selected from below. Allowable options for each box are shown under each respective box. Series Actuator/ Term. Spacing Poles Functions Version 3 4 6 9 N *Contact & Term. Mat'l. *Actuators Approvals B H H 6 6 (NONE) X 6 9 3 U L 2 5 1 4 3 5 A L D * If a single suffix selection is chosen from the Contact & Term. Mat'l.or Actuator categories above, eliminate the extra box. Actuator/Terminal spacing: Dimensions in inches and millimeters. 1 = Vertical actuator and .100" (2.54mm) terminal spacing 4 = Vertical actuator and .200" (5.08mm) terminal spacing 3 = Side actuator and .100" (2.54mm) terminal spacing 5 = Side actuator and .200" (5.08mm) terminal spacing Poles: 3 = Single Pole 4 = Double Pole Functions: 6 = ON - ON 9 = ON OFF ON Version: N = Version specification (Specify for all models) Contact & terminal materials: See contact ratings under "specifications". A = Silver LD = Gold plated brass Actuators: Dimensions in inches and millimeters. B = Flush vertical actuator H = Vertical actuator .110" (2.80mm) high H6 = Vertical actuator .236" (6.00mm) high 6 = Side actuator .236" (6.00mm) long Note: If Actuator boxes are not used, a side actuator .090" (2.30mm) long will be supplied. Approvals: X693UL = Switches recognized and marked UL - silver (A) contacts only. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E49 E MSS Series SPECIFICATIONS FEATURES Contact ratings: Gold; 0.4 Volt-Amps (VA) max. at 20 V max. (AC or DC) Silver; 300 mA at 125 VAC or 30 VDC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS at sea level Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible ● Bifurcated wiping contact design. ● Epoxy sealed terminals. ● Wash-through open frame construction. ● Reinforcing mounting legs. E MODEL NO. PLATING MSS12A SILVER MSS12AG GOLD VERTICAL ACTUATOR MODEL NO. SILVER MSS12ARG GOLD RIGHT ANGLE ACTUATOR MODEL NO. MSS13AR RIGHT ANGLE ACTUATOR E50 .079 (2.00) TRAVEL/THROW SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 1P2T SCHEMATIC PLATING SILVER Contacts & terminals: Gold or silver available (see contact ratings) Housing: Tin/lead plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet Terminal seal: Epoxy 1P2T PLATING MSS12AR MATERIALS MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 1P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Standard Size Slide Switches MSS Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Standard Size Slide Switches MODEL NO. PLATING MSS14 SILVER MSS14G GOLD VERTICAL ACTUATOR MODEL NO. PLATING MSS22 SILVER MSS22G GOLD VERTICAL ACTUATOR MODEL NO. PLATING MSS225R SILVER MSS225RG GOLD RIGHT ANGLE ACTUATOR MODEL NO. PLATING MSS23 SILVER MSS23G GOLD VERTICAL ACTUATOR 1P4T SCHEMATIC .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P2T SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 2P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E51 MSS Series Standard Size Slide Switches PLATING MSS24A SILVER MSS24AG GOLD VERTICAL ACTUATOR E MODEL NO. PLATING MSS42 SILVER MSS42G GOLD VERTICAL ACTUATOR MODEL NO. SILVER MSS42RG GOLD RIGHT ANGLE ACTUATOR MSS43 SILVER MSS43G GOLD MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 4P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 4P2T SCHEMATIC PLATING VERTICAL ACTUATOR E52 SCHEMATIC PLATING MSS42R MODEL NO. .079 (2.00) TRAVEL/THROW 2P4T MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 4P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. M Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Standard Size Slide Switches SPECIFICATIONS FEATURES Contact rating: 300 mA at 125 VAC or 30 VDC ● Bifurcated wiping contact design. Initial contact resistance: 20 milliohms max. ● Epoxy sealed terminals. Wash-through open frame construction. Reinforcing mounting legs. Many actuator styles and lengths available on request. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 500 volts RMS at sea level Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MODEL NO. M12R RIGHT ANGLE ACTUATOR MODEL NO. M13R RIGHT ANGLE ACTUATOR RIGHT ANGLE ACTUATOR ● ● MATERIALS Contacts & terminals: Silver plated Housing: Tin plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet Terminal seal: Epoxy .079 (2.00) TRAVEL/THROW 1P2T SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW 1P3T SCHEMATIC MODEL NO. M13AR ● 1P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E53 M Series Standard Size Slide Switches M22 VERTICAL ACTUATOR 2P2T SCHEMATIC MODEL NO. M22R E RIGHT ANGLE ACTUATOR 2P2T SCHEMATIC MODEL NO. M23 VERTICAL VERTICALACTUATOR MOUNTING RIGHT ANGLE ACTUATOR E54 MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 2P3T SCHEMATIC MODEL NO. M23R .157 (4.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 2P3T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. M Series Standard Size Slide Switches MODEL NO. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE M42 VERTICAL ACTUATOR 4P2T SCHEMATIC MODEL NO. M42R RIGHT ANGLE ACTUATOR VERTICAL MOUNTING VERTICAL ACTUATOR MODEL NO. MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 4P2T SCHEMATIC MODEL NO. M42A .157 (4.00) TRAVEL/THROW 4P2T SCHEMATIC 4P3T E MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW M43 VERTICAL ACTUATOR SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E55 M Series Standard Size Slide Switches M43R RIGHT ANGLE ACTUATOR 4P3T SCHEMATIC MODEL NO. M62 E VERTICAL ACTUATOR MODEL NO. M62R VERTICAL MOUNTING RIGHT ANGLE ACTUATOR VERTICAL ACTUATOR E56 MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 6P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 6P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW MODEL NO. M62A .079 (2.00) TRAVEL/THROW 6P2T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. M Series Standard Size Slide Switches MODEL NO. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE M63 VERTICAL ACTUATOR 6P3T SCHEMATIC .079 (2.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT MODEL NO. M63R RIGHT ANGLE ACTUATOR MODEL NO. 6P3T SCHEMATIC 8P3T .079 (2.00) TRAVEL/THROW E MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW M83 VERTICAL MOUNTING VERTICAL ACTUATOR MODEL NO. SCHEMATIC 8P3T MECHANICAL OUTLINE P.C. BOARD LAYOUT .079 (2.00) TRAVEL/THROW M83R RIGHT ANGLE ACTUATOR SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E57 PM Series SPECIFICATIONS FEATURES Contact rating: 6 Amps at 125 VAC, 3 Amps at 250 VAC ● Wash-through open frame construction. ● UL & CSA recognized. ● Threaded mounting holes standard - M3X0.5. Electrical life: 10,000 cycles min. ● Panel mounting. Operating temperature range: -20°C to +60°C MATERIALS Actuation force: 500g ± 200g Contacts: Silver plated phosphor bronze Solder heat resistance: 260°C max. for 3 seconds Terminals: Tin plated brass Actuator: Nylon, type 6/6 Solvent washing permissible Base: Phenolic laminated sheet Frame: Zinc plated steel Initial contact resistance: 30 milliohms max. Insulation resistance: 100 megohms min. at 500 VDC Dielectric strength: 1000 VAC for 1 minute (min.) MODEL NO. PM13B012 E 1P2T SCHEMATIC MODEL NO. PM13B022 1P2T SCHEMATIC MODEL NO. PM13B022P 2P2T SCHEMATIC E58 .193 (4.90) TRAVEL/THROW MECHANICAL OUTLINE PANEL CUTOUT .193 (4.90) TRAVEL/THROW MECHANICAL OUTLINE P. C. BOARD LAYOUT .193 (4.90) TRAVEL/THROW MECHANICAL OUTLINE PANEL CUTOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Standard Size Slide Switches MPS Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Miniature Pushbutton Style Slide Switches SPECIFICATIONS FEATURES Contact ratings: Pushbutton contacts; 0.4 Volt-Amps max. at 20 V max. (AC or DC) Slide contacts; 300 mA at 125 VAC or 30 VDC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms max. at 250 VDC Dielectric strength: 250 volts RMS at sea level Electrical life: 100,000 cycles min. Operating temperature range: -10°C to +60°C Actuation force: Pushbutton; 200g ± 100g Slide; 100g to 450g Solder heat resistance: 260°C max. for 3 seconds Washing not recommended ● MODEL NO. MPS101 RIGHT ANGLE ACTUATOR MODEL NO. MPS101A RIGHT ANGLE ACTUATOR MODEL NO. MPS101B RIGHT ANGLE ACTUATOR ● ● ● Combination momentary pushbutton switch and slide switch mechanism. Bifurcated wiping contact design. Epoxy sealed terminals. Reinforcing mounting legs. MATERIALS Contacts & terminals: Gold plating for pushbutton. Silver plating for slide (see contact ratings). Housing: Nickel plated brass Actuator: Thermoplastic Base: Phenolic laminated sheet Terminal seal: Epoxy 1P1T, (PB) 1P3T, (Slide) SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT MECHANICAL OUTLINE P.C. BOARD LAYOUT MECHANICAL OUTLINE P.C. BOARD LAYOUT 1P1T, (PB) 1P3T, (Slide) SCHEMATIC 1P1T, (PB) 1P3T, (Slide) SCHEMATIC APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E59 MSL Series Note: up to 10 positions available - contact factory. Minimum quantities may apply. Optional color cap available for these models - see Hardware section. Single Pole Multi-Position Slide Switches Contact rating: 200 mA at 125 VAC or 30 VDC Initial contact resistance: 30 milliohms max. Contact timing: Non-shorting Insulation resistance: 100 megohms max. at 500 VDC Dielectric strength: 500 volts RMS at sea level Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Actuation force: 250g ± 100g Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MODEL NO. MSL33 E VERTICAL ACTUATOR MODEL NO. MSL55 VERTICAL ACTUATOR 1P3T SCHEMATIC VERTICAL ACTUATOR E60 ● ● ● Bifurcated wiping contact design. Epoxy sealed terminals. Wash-through open frame construction. Reinforcing mounting legs. Threaded mounting holes standard - 4-40NC-2B. MATERIALS Contacts & terminals: Silver plated Housing: Tin/lead plated steel Base: Phenolic laminated sheet Slider: High temperature thermoplastic Actuator: Steel Terminal seal: Epoxy .157 (4.00) TRAVEL/THROW MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 1P5T SCHEMATIC MODEL NO. MSL66 ● ● MECHANICAL OUTLINE P.C. BOARD LAYOUT .157 (4.00) TRAVEL/THROW 1P6T SCHEMATIC MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE FEATURES SPECIFICATIONS MBT Series Baton Toggle Style Slide Switches SPECIFICATIONS FEATURES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Contact rating: 300 mA at 125 VAC or 30 VDC Initial contact resistance: 20 milliohms max. Insulation resistance: 100 megohms max. at 500 VDC Dielectric strength: 500 volts RMS at sea level Electrical life: 10,000 cycles min. Operating temperature range: -10°C to +60°C Actuation force: 400g ± 200g Solder heat resistance: 260°C max. for 3 seconds Solvent washing permissible MODEL NO. CONTACTS MBT22N NON-SHORTING CONTACTS MBT22S SHORTING CONTACTS MBT23N NON-SHORTING ● ● MATERIALS Contacts & terminals: Silver plated Housing: Tin plated steel Actuator: Thermoplastic Base: Phenolic laminated sheet Terminal seal: Epoxy E MECHANICAL OUTLINE P.C. BOARD LAYOUT MECHANICAL OUTLINE P.C. BOARD LAYOUT MECHANICAL OUTLINE P.C. BOARD LAYOUT 2P2T SCHEMATIC MODEL NO. ● ● Bifurcated wiping contact design. Epoxy sealed terminals. Wash-through open frame construction. Reinforcing mounting legs. Threaded mounting holes standard. 2P2T SCHEMATIC MODEL NO. ● 2P3T SCHEMATIC APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E61 MBT Series Baton Toggle Style Slide Switches CONTACTS MBT24 UNSPECIFIED 2P4T SCHEMATIC E MODEL NO. CONTACTS MBT42N NON-SHORTING CONTACTS MBT42S SHORTING CONTACTS MBT43N NON-SHORTING P.C. BOARD LAYOUT MECHANICAL OUTLINE P.C. BOARD LAYOUT MECHANICAL OUTLINE P.C. BOARD LAYOUT 4P3T SCHEMATIC E62 MECHANICAL OUTLINE 4P2T SCHEMATIC MODEL NO. P.C. BOARD LAYOUT 4P2T SCHEMATIC MODEL NO. MECHANICAL OUTLINE APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE MODEL NO. MBT Series SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Baton Toggle Style Slide Switches MODEL NO. CONTACTS MBT62N NON-SHORTING MBT62S SHORTING 6P2T SCHEMATIC MODEL NO. CONTACTS MBT63 UNSPECIFIED MECHANICAL OUTLINE P.C. BOARD LAYOUT 6P3T SCHEMATIC E MECHANICAL OUTLINE P.C. BOARD LAYOUT APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com E63
25546NA 价格&库存
很抱歉,暂时无法提供与“25546NA”相匹配的价格&库存,您可以联系我们找货
25546NA
    • 1+46.77050
    25546NA
    • 5+179.077185+23.16364
    • 25+90.6311825+11.72315
    • 50+81.5493150+10.54841
    库存:270
    25546NA
    • 8+101.306548+13.10401
    • 10+94.8241310+12.26551
    • 20+91.6583020+11.85601
    • 50+64.8913750+8.39370
    • 100+59.66369100+7.71750
    • 250+49.89021250+6.45330
    • 500+42.16234500+5.45370
    • 750+40.45767750+5.23320
    库存:500
