4631A22UU
4631A22UU
    APEM(埃斐)
    钮子开关 单刀单掷 1万次 面板安装 6A 125V -20℃~+55℃
4631A22UU 数据手册
4600 and 4400 series Toggle switches Distinctive features and specifications ❑ High current/voltage rating in a small case ❑ Butt action contacts ❑ Insulated or metal lever A ❑ UL, CSA and VDE (EN 61058-1) approved ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (A) : 4A 250VAC - 6A 125VAC - silver plated copper contacts (C) : 2A 250VAC - 3A 125VAC • Approved electrical ratings : see table below • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.000 Vrms 50 Hz min. between terminals 2.500 Vrms 50 Hz min. between poles and between terminals and frame • Electrical life : 10.000 cycles at full load APPROVALS MODELS POLES FUNCTIONS APPROVED RATINGS UL/CSA 4600A 1-2 1-6-9 3A 250VAC - 6A 125VAC 4400A 1-2 1-6 4(2)A 250VAC 4600A 1-2-3 1-6 4(2)A 250VAC VDE (EN 61058-1) MATERIALS • Case : melamine phenolic • Actuator : - insulated : polyamide ,6-6 - non-insulated : brass, nickel plated • Bushing : - insulated : polyamide 6-6 - non-insulated : brass, nickel plated • Contacts : A : silver C : copper, silver plated A-94 GENERAL SPECIFICATIONS • Torque : 0,95 Nm (.70 Ft.lb) max. applied to nut • Panel thickness : 5 mm (.196) between 2 nuts • Operating temperature : -20°C to +55°C • Hand soldering : 270°C max. for 10 seconds max. - iron Ø3 (.118) AGENCY APPROVALS EN 61058-1 Availability : see above chart. Marking : VDE approved models are standard marked. To order switches marked UL-CSA, complete appropriate box of ordering format. www.apem.com APEM 4600 and 4400 series Toggle switches Overview 4 Terminals SERIES Number of poles Straight PC Solder lug and quickconnect 6../8 Quick-connect 4,7 x 0,8 mm 4 6 Contact materials A C Silver Copper, silver plated 3 4 5 Single pole Double pole Three pole Actuators 1 and 2 pole models -2 Insulated flat lever Standard 3 pole models Blank Round metal lever -32 Insulated round lever, black Actuator colours 1 2 3 4 5 6 7/1 9 Blue Black (std) Green Grey Yellow Red White Orange Electrical functions 1 6 9 ON ON ON OFF OFF ON ON Approvals UL CSA VDE (EN 61058-1) For SP and DP models only. ABOUT THIS SERIES Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Sealing boots are available on 3 pole models to protect the switches against dust and water. They are presented in section H. Mounting accessories : standard hardware supplied with all models : 1hex nut U166 and 1 knurled nut U520 in the same colour as the lever (insulated models) or U411 nickel plated (metal lever models). Standard and special hardware available are presented in section I. Packaging unit : 20 pieces. APEM www.apem.com A-95 A 4600 and 4400 series Toggle switches Insulated flat lever 2.40 (.094) A 3 2 6.20 (.244) 7.20 (.283) (.047) 5.00 (.196) • Solder lug/quick-connect terminals 2,8 x 0,5 (.110 x .019) • Straight PC terminals or quick-connect terminals 4,7 x 0,8 (.185 x .031) • 2 and 3 maintained positions • 1 and 2 pole configurations 1.20 ➞ Keyway 2.80x0.50 (.11x.019) 1 1.20x0.5 (.047x.019) MODEL STRUCTURE ➞ Keyway 11.50 (.452) 14.00 (.551) 7.20 (.283) 2.80 (.11) Solder lug/quick-connect terminals - single pole 4631 -2 4636 -2 4639 -2 ON ON ON II OFF I OFF ON ON 12.00 (.472) 13.50 (.531) 5.80 (.228) III III 0.50 (.019) 30˚ 2 8.40 (.33) 19.00 (.748) 3 II 1 I Ø12.00x0.75 SI (.472DIAx0.75 IS) ➞ Keyway III II 15.00 (.590) 11.50 (.452) 7.20 (.283) 2.80 (.11) Solder lug/quick-connect terminals - double pole I 16.50 (.649) 8.00 (.315) 13.50 (.531) 21.00 (.826) B6 III A3 A2 B5 B4 A1 0.50 (.019) OFF ON ON 30˚ OFF 5.80 (.228) ON ON ON 8.40 (.33) 4641 -2 4646 -2 4649 -2 II I Ø12.00x0.75 SI (.472DIAx0.75 IS) ➞ Keyway 12.50 (.492) 14.50 (.57) 5.00 (.196) 1.20 (.047) Straight PC terminals - single pole 4431 -2 4436 -2 4439 -2 ON ON ON II OFF I OFF ON ON 23.00 (.905) 12.00 (.472) 13.50 (.531) 5.80 (.228) III III 1 II 0.50 (.019) 30˚ 2 8.40 (.33) 19.00 (.748) 3 I Ø12.00x0.75 SI (.472DIAx0.75 IS) A-96 www.apem.com APEM 4600 and 4400 series Toggle switches Insulated flat lever ➞ Keyway 15.50 (.610) I 5.00 (.196) 16.50 (.649) 23.00 (.905) 8.00 (.315) 13.50 (.531) 21.00 (.826) B6 A2 A3 B5 B4 A III A1 0.50 (.019) OFF ON ON 30˚ OFF 5.80 (.228) ON ON ON 4441 -2 4446 -2 4449 -2 II 8.40 (.33) III 12.50 (.492) 1.20 (.047) Straight PC terminals - double pole II I Ø12.00x0.75 SI (.472DIAx0.75 IS) Quick-connect terminals 4,7 x 0,8 (.185 x .031) - single pole 11.50 (.452) 14.00 (.551) 8.20 (.322) ➞ Keyway 4.70 (.185) - OFF ON 12.00 (.472) 13.50 (.531) II 30˚ 19.00 (.748) 3 0.80 (.0319) ON ON 4631/8 -2 4636/8 -2 II 7.70 (.303) I 2 7.70 (.303) 1 I Ø12.00x0.75 SI (.472DIAx0.75 IS) PANEL CUT-OUT Ø12.20 (.48DIA) Ø12.50 (.492DIA) 5.10 (.20) Ø3.50 (.137DIA) APEM 9.60 (.377) Ø12.20 (.48DIA) 1.70 (.066) www.apem.com A-97 4600 and 4400 series Toggle switches Round lever - three pole 2.40 (.094) A 3 2 6.20 (.244) 7.20 (.283) 1.20 (.047) 5.00 (.196) • Solder lug or straight PC terminals • 2 and 3 maintained positions ➞ Keyway 2.80x0.50 (.11x.019) 1 1.20x0.5 (.047x.019) MODEL STRUCTURE ➞ Keyway Solder lug terminals - metal lever 7.20 (.283) 2.80 (.11) 24.40 (.960) OFF ON ON 8.00 8.00 (.315) (.315) 15.00 (.590) 19.00 (.748) 1 2 4 5 8 6 3 I 7 9 0.50 (.019) OFF 30 ON ON ON 15.00 (.590) I 5.80 (.228) 4651 4656 4659 II 8.40 (.330) III 10.50 (.413) II III Ø12.00x0.75 SI (.472DIAx0.75 IS) ➞ Keyway Straight PC terminals - metal lever 1.20 (.047) 24.40 (.960) OFF ON ON 8.00 8.00 (.315) (.315) 19.00 (.748) 1 2 4 5 15.00 (.590) I 7 8 6 3 9 II III Ø12.00x0.75 SI (.472DIAx0.75 IS) Keyway Solder lug terminals - insulated lever - silver contacts ➞ 1 2 3 4 5 2.80 (.11) 7.20 (.283) 15.00 (.59) II 7 8 6 15.00 (.59) 9 0.50 (.019) OFF ON 30˚ - 8.00 8.00 (.315) (.315) 5.80 (.228) ON ON 24.40 (.96) II 19.00 (.748) 4651A-32 4656A-32 11.50 (.452) 8.40 (.33) I 5.00 (.196) 0.50 (.019) OFF 30 ON ON ON 15.50 (.610) I 5.80 (.228) 4451 4456 4459 II 8.40 (.330) III 10.50 (.413) I Ø12.00x0.75 SI (.472DIAx0.75 IS) A-98 www.apem.com APEM 4600 and 4400 series Toggle switches CONTACT MATERIALS A C Silver Copper, silver plated A ACTUATORS Blank Round, metal lever for 3 pole only -2 Insulated flat lever (for single and double pole only) -32 Black insulated round lever (for 3 pole only) ACTUATOR COLOURS 1 2 3 4 5 6 7/1 9 Blue Black (standard) Green Grey Yellow Red White Orange For insulated flat lever Black : standard colour - reduced delivery time Minimum order of 500 pieces for non-standard colours. APPROVALS UU (UL-CSA) Single and double pole only Availability : see specifications for details of approved models. Marking : to order switches marked UL-CSA, complete above box with 'UU". Other approvals available as standard, see specifications. APEM www.apem.com A-99
4631A22UU 价格&库存
很抱歉,暂时无法提供与“4631A22UU”相匹配的价格&库存,您可以联系我们找货
