AV021003C900
AV021003C900
    APEM(埃斐)
    SWITCH PUSH SPST-NO 2A 48V
AV021003C900 数据手册
09 S 22 9 V1 AV series -A SW PANEL SWITCHES 17 EC Security pushbutton switches • Ø 19 or 22 mm • momentary NO DISTINCTIVE FEATURES Momentary (NO) Momentary (NC) and alternate action also available Long life UL-CSA approved (long case only) Marking available ENVIRONMENTAL SPECIFICATIONS • Optional front panel sealing : IP65 according to IEC 60529 • Operating temperature : -30 °C to +70 °C (-22 °F to +158 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - A contacts : 4 A 12 VDC, 500,000 cycles - C contacts : 2 A 48 VDC, 10,000 cycles • Approved ratings of models with long case and A contacts (AV..000) : UL-CSA : 4 A 250 VAC - 8 A 125 VAC - 6,000 cycles • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 2,000 Vrms 50 Hz min. between terminals and frame 2,000 Vrms 50 Hz min. between terminals GENERAL SPECIFICATIONS • Torque : 5 Nm min.- 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 11 mm (.433) max. • Low level or mechanical life : 1,000,000 cycles • Hand soldering : 300 °C (572 °F), 3 sec. max. MATERIALS • Case : PBT • Contacts : silver (A) or brass, silver plated (C) • Bushing and actuator : see following pages The company reserves the right to change specifications without notice. 1 PANEL SWITCHES AV series Security pushbutton switches • Ø 19 or 22 mm • momentary NO AGENCY APPROVAL 4 A 250 VAC /8 A 125 VAC (long case only) To order switches marked UL-CSA, add “UU“ at the end of model number. ELECTRICAL FUNCTIONS Function 3 (NO) PANEL MOUNTING • Panel cut-out :Ø 19,2 mm (.755) or Ø 22.2 mm (.874) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) 2 Security pushbutton switches • Ø 19 or 22 mm • momentary NO BUILD YOUR PART NUMBER BASIC PART NUMBER AV SERIES BUSHING/ACTUATOR CONFIGURATIONS Models Ø 19 (.748) 09 Flat actuator 19 Curved actuator FUNCTION CASE 000 Long 100 Short 3 TERMINALS CONTACTS NO A Silver C Brass, silver plated 9 Screw 2 Solder lug/ quick-connect Models Ø 22 (.866) 03 Flat actuator 02 Curved actuator OPTIONS BUSHING/ACTUATOR MATERIALS Flat or curved metal actuator 00 (std) Nickel plated brass / Nickel plated brass 10 Nickel plated brass / Stainless steel 20 Chrome plated brass / Chrome plated brass 30 Chrome plated brass / Stainless steel 40 Stainless steel / Stainless steel 50 Stainless steel / Nickel plated brass 70 Black chrome plated brass / Black chrome plated brass Flat thermoplastic actuator bushing 0• (std) Nickel plated brass 2• Chrome plated brass 8• Varnished polished brass SEALING Blank K No sealing Sealed to IP65 AGENCY APPROVAL UU UL Availability : models with long case only. Replace • with actuator color (see following pages). ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories: standard hardware supplied : 1 hex nut. Standard and special hardware is presented in the "Hardware" section of website. 3 PANEL SWITCHES AV series Security pushbutton switches • Ø 19 or 22 mm • momentary NO Hex nut 22 (.866) across flats BUSHING Ø 19 (.748) - FLAT ACTUATOR SHORT CASE - 48 VDC ø19.00x1.00 SI ø19.00x1.00 SI (.748DIAx1.00 (.748DIAx1.00 IS) IS) 2.00 2.00 (.078) (.078) 7.30 7.30 (.287) (.287) 4.00 4.00 (.157) (.157) 2.80 2.80 (.110) (.110) 13.50 13.505.50 5.50 (.216) (.216) (.531) (.531) 5.00 5.00 (.196) (.196) EPOXYEPOXY • Contacts. Replace with A or C. Hex nut 22 (.866) across flats BUSHING Ø 19 (.748) - CURVED ACTUATOR SHORT CASE - 48 VDC Ø15.00 (.590DIA) 2.00 (.078) AV191003•9 Ø22.00 (.866DIA) 3.60 (.141) Screw terminals Solder lug / quick-connect term. AV191003•2 • Contacts. Replace with A or C. Hex nut 22 (.866) across flats BUSHING Ø 19 (.748) - FLAT ACTUATOR LONG CASE- 4 A 250 VAC/8 A 125 VAC - UL/CSA 4.00 (.157) Ø19.00x1.00 SI (.748DIAx1.00 IS) Ø15.00 (.590DIA) AV090003A9 Ø22.00 (.866DIA) 5.00 (.196) Screw terminals 2.00 (.078) 14.80 (.582) 10.50 (.413) To order switches marked UL-CSA, add “UU” at the end of model number. Hex nut 22 (.866) across flats BUSHING Ø 19 (.748) - CURVED ACTUATOR LONG CASE - 4 A 250 VAC/8 A 125 VAC - UL/CSA CAV09DTUL AV190003A9 To order switches marked UL-CSA, add “UU” at the end of model number. Screw terminals for wires 1.5 mm2 max. 4 Ø15.00 (.590DIA) 2.00 (.078) Screw terminals 3.60 (.141) Ø22.00 (.866DIA) 1.20 (.047) 1.20 (.047) AV091003•2 2.80x0.5 (.110x.019) 2.80x0.5 (.110x.019) Solder lug / quick-connect term. ø15.00 (.590DIA) AV091003•9 ø22.00 ø15.00 (.866DIA) (.590DIA) Screw terminals ø22.00 (.866DIA) PANEL SWITCHES AV series Security pushbutton switches • Ø 19 or 22 mm • momentary NO Hex nut 25 (.984) across flats BUSHING Ø 22 (.866) - FLAT ACTUATOR SHORT CASE - 48 VDC ø22.00x1.00 SI (.866DIAx1.00 IS) 2.00 (.078) 7.30 (.287) 4.00 (.157) 2.80 (.110) 1.20 (.047) 2.80x0.5 (.110x.019) Solder lug / quick-connect term. ø15.00 (.59DIA) AV031003•9 ø25.00 (.984DIA) Screw terminals AV031003•2 12.70 (.500) 6.30 (.248) EPOXY 5.00 (.196) • Contacts. Replace with A or C. Hex nut 25 (.984) across flats BUSHING Ø 22 (.866) - CURVED ACTUATOR SHORT CASE - 48 VDC Ø25.00 (.984DIA) 2.00 (.078) AV021003•9 Ø15.00 (.590DIA) 3.60 (.141) Screw terminals Solder lug / quick-connect term. AV021003•2 • Contacts. Replace with A or C. Hex nut 25 (.984) across flats BUSHING Ø 22 (.866) - FLAT ACTUATOR LONG CASE - 4 A 250 VAC/8 A 125 VAC - UL/CSA 4.00 (.157) Ø15.00 (.59DIA) AV030003A9 2.00 (.078) Ø25.00 (.984DIA) Screw terminals Ø22.00x1.00 SI (.866DIAx1.00 IS) 15.00 (.590) 10.00 (.248) 5.00 (.196) To order switches marked UL-CSA, add “UU” at the end of model number. Hex CAV03NUL BUSHING Ø 22 (.866) - CURVED ACTUATOR LONG CASE - 4 A 250 VAC/8 A 125 VAC - UL/CSA nut 25 (.984) across flats Ø15.00 (.590DIA) 2.00 (.078) Screw terminals 3.60 (.141) Ø25.00 (.984DIA) AV020003A9 To order switches marked UL-CSA, add “UU” at the end of model number. Screw terminals for wires 1.5 mm2 max. 5 PANEL SWITCHES AV series Security pushbutton switches • Ø 19 or 22 mm • momentary NO Hex nut 25 (.984) across flats BUSHING Ø 22 (.866) - MOMENTARY, NORMALLY CLOSED Ø22.00x1.00 SI (.866DIAx1.00 IS) • Single pole, screw terminals, without marking 2.00 (.078) • Silver plated copper contacts (C) 4.00 (.157) Ø3.00x0.50 (.118DIAx.0.50) • Electrical life : 100,000 cycles at 0.3 A 24 VAC or DC 10,000 cycles at full load Flat actuator 13.20 3.60 (.141) 14.00 (.551) Curved actuator AV021202C9 BUSHING Ø 22 (.866) - ALTERNATE ACTION • Double pole, solder lug/quick-connect terminal, curved actuator 4.00 (.157) 1.60 (.063) • Dielectric strength : 3,000 Vrms min. between terminals and frame • Electrical life : 10,000 cycles at full load 50,000 cycles at 1 A 24 VAC or DC 3.60 (.141) • Mechanical life : 100,000 cycles ON - ON For further scpecificarions, see previous pages BUSHING/ACTUATOR MATERIALS BASIC P/N FLAT OR CURVED METAL ACTUATOR 6 CODE BUSHING ACTUATOR 00 (std) Nickel plated brass Nickel plated brass 10 Nickel plated brass Stainless steel 20 Chrome plated brass Chrome plated brass 30 Chrome plated brass Stainless steel 40 Stainless steel Stainless steel 50 Stainless steel Nickel plated brass 70 Black chrome plated brass Black chrome plated brass 8.40 (.330) • Max. current/voltage rating with resistive load : 3 (1.5) A 250 VAC - 6 A 125 VAC - 3 A 24 VAC or DC Ø15.00 (.59DIA) • Silver contacts 5.80 (.228) Ø22.00x1.00 SI (.866DIAx1.00 IS) 0.50x2.80 (.019x.110) AV031202C9 AV044746A2 7.00 (.275) 15.40 (.606) 14.00 (.551) 20.60 (.811) 7.20 (.283) (.519) Ø15.00 (.59DIA) Ø15.00 (.59DIA) • Dielectric strength : 2,000 Vrms 50 Hz min. betw. terminal and frame 2,000 Vrms. 50 Hz min. between terminals Ø25.00 (.984DIA) • Max. current/voltage rating with resistive load : 2 A 250 VAC - 3 A 125 VAC - 2.5 A 24 VDC Ø25.00 (.984DIA) PANEL SWITCHES AV series Security pushbutton switches • Ø 19 or 22 mm • momentary NO BUSHING/ACTUATOR MATERIALS (CONTINUED) BASIC P/N FLAT THERMOPLASTIC ACTUATOR CODE BUSHING ACTUATOR 0• (std) Nickel plated brass 2• Chrome plated brass 8• Varnished polished brass Replace • with one of the following codes : 1 : blue - 1/4 : dark blue 2 : black - 3 : green - 4 : grey 5 : yellow - 6 : red - 7/1: white - 9 : orange MARKING BASIC P/N For flat or curved actuator: by laser etching on non-illuminated brass or stainless steel actuator. For flat actuator: by hot stamping on thermoplastic insert (illuminated actuators). Not available for AV031202C9 and AV044746A2. 8.00 (0.314) Ø15.00 (0.590DIA) 1.50 (0.059) Select an option from each of the two paragraphs opposite (Type /Color). TYPE OF MARKING 0 to 9 X Y A to N P to W 0 Numbers 0 to 9 Symbol * Symbol # Letters A to N Letters P to W Letter O Letter O : same code and same design as number 0. For special symbols, consult factory. Minimum order : 500 pieces COLOR OF MARKING Brass actuator 0 (std) Same as finish 2 Black Note : a finished product supplied in version “0” cannot be modified to version "2". Thermoplastic actuator 2 Black 7 White SEALING BASIC P/N Blank No sealing K Front panel sealing to IP65 OPTION K 2 - internal gasket 1 CAVETKK-A - external gasket 7 PANEL SWITCHES AV series
AV021003C900 价格&库存
很抱歉,暂时无法提供与“AV021003C900”相匹配的价格&库存,您可以联系我们找货
AV021003C900
    AV021003C900
    • 4+263.19694
    库存:8
