FNRCM4SXX2X
FNRCM4SXX2X
    APEM(埃斐)
    船型开关 DP3T 1A 24V
FNRCM4SXX2X 数据手册
FNR series N -F SW PANEL SWITCHES 0 82 0 R- Sealed rocker switches DISTINCTIVE FEATURES Ideal for front / neutral / reverse selection Easy to install Excellent front panel sealing Backlit logos ENVIRONMENTAL SPECIFICATIONS • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) • Panel sealing; IP69K according to DIN 40050-9 ELECTRICAL SPECIFICATIONS • Maximum voltage rating with resistive load: 24 VDC • Current rating with resistive load: 0.03 to 1 A • Initial contact resistance: 10 Gohms at 500 VDC • Dielectric strength: 1000 Vrms 50 Hz min. • Electrical life: 1.000.000 cycles at 100 mA 100.000 cycles at 1 A LED COMPONENT SPECIFICATIONS LED color Forward current Typ. forward voltage Max. forward voltage Blue 20 mA 3.3 V 4V Green 20 mA 2.1 V 2.5 V Red 20 mA 1.9 V 2.5 V Yellow 20 mA 2V 2.5 V White 20 mA 3.3 V 4V Red/green 20 mA Red: 1.9 V / green: 2.1 V 2.5 V A resistor must be series-connected by the user. Resistor value = supply voltage - LED forward voltage LED forward current The company reserves the right to change specifications without notice. 1 PANEL SWITCHES FNR series Sealed rocker switches GENERAL SPECIFICATIONS • Total travel: ± 15°. WIRING DIAGRAM WIRING DIAGRAM • Typical operating force at center: 5 N ± 1 • Mechanical life: 1.000.000 cycles MATERIALS Wire colors (F & C output) • Contacts : Gold alloy • Case : PBT 10 9 8 7 6 5 4 3 2 1 Without resistor • Actuator : PA6-6 • Overmoulding: Polyamide APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. With resistor PANEL CUT-OUT Brown Orange White Black Blue Yellow Red Green Purple Grey POSITION CONNECTOR FOR C OUTPUT • Illuminated : Molex 510651000 •Non-illuminated : Molex 510650600 ELECTRICAL FUNCTIONS AND CONNECTIONS In the tables below, terminal connections as viewed from bottom of switch. Only the contact area is represented. x = w/o terminal o = with terminal = momentary 2 POSITIONS 2 3 POSITIONS MOM-ON-MOM 3 POSITIONS ON-ON-ON Sealed rocker switches BUILD YOUR PART NUMBER BASIC PART NUMBER FNR SERIES ELECTRICAL FUNCTIONS ACTUATOR SHAPE C Curved 6 ON - ON M MOM ON MOM F ON ON ON TERMINALS CONTACT MATERIALS 4 Gold plated Silver C Flying leads + Connector F Flying leads S Solder lug OPTIONS Side A Side B Area A ACTUATOR COLOR 2 Black LEDS X None F LED 12 V yellow A LED 6 V red N LED 12 V blue B LED 6 V green S LED 12 V white C LED 6 V yellow J LED 24 V red M LED 6 V blue K LED 24 V green R LED 6 V white L LED 24 V yellow D LED 12 V red P LED 24 V blue E LED 12 V green T LED 24 V white MARKING ORIENTATION MARKING STYLE/COLOR X No marking X No marking N North 0 Black pad printing S South 2 Laser E East W West Area M Area B SYMBOLS See end of the series. etc. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied : 1 hex nut and 1 O-Ring 3 PANEL SWITCHES FNR series PANEL SWITCHES FNR series Sealed rocker switches SOLDER LUG TERMINALS CURVED ACTUATOR FNRC64S ON FNRCM4S MOM ON MOM FNRCF4S ON ON ON ON FLYING LEADS TERMINALS CURVED ACTUATOR FNRC64F ON FNRCM4F MOM ON MOM FNRCF4F ON ON ON ON FLYING LEADS + CONNECTOR TERMINALS CURVED ACTUATOR 4 FNRC64C ON FNRCM4C MOM ON MOM FNRCF4C ON ON ON ON Sealed rocker switches LEDS Side B Side A BASIC P/N Complete each enlarged box with one of the codes listed below. X Without LED Red Green Yellow Blue White Red/green No resistor U V W Y Z - 12 VDC D E F N S 2 24 VDC J K L P T 3 12 VDC is calibrated for 15 VDC max 24 VDC is calibrated for 30 VDC max ACTUATOR COLOR BASIC P/N 2 Black MARKING ORIENTATION BASIC P/N X N S E W No marking North South East West MARKING STYLE /COLOR BASIC P/N X 0 2 No marking Black pad printing Laser SYMBOLS BASIC P/N Area A Area M Area B XXX No marking Other markings : see logo list 5 PANEL SWITCHES FNR series
FNRCM4SXX2X 价格&库存
很抱歉,暂时无法提供与“FNRCM4SXX2X”相匹配的价格&库存,您可以联系我们找货
