FP series
Distinctive features and specifications
00 )
4. IA
Ø3 39D
.3
(1
Ø26.50
(1.043DIA)
4.50
(.177)
Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching
UG1410-A-R3
❑ Snap-in and threaded bushing models
0.50
(.020)
2.80
(.110)
6.30
(.248)
❑ Large but lightweight
26.50
(1.043)
❑ Full actuator or symbol illumination
Ø29.80
(1.173)
❑ Pad printed or laser etched symbols
Pad printing
CFP30DT
Laser
B2
Non-illuminated
• Max. current/voltage rating with resistive load :
- silver contacts (code 2) : 4A 12VDC
- gold plated contacts (code 4) : 200mA 12VDC
• Initial contact resistance : 50 mΩ max.
• Insulation resistance : 1 GΩ min. at 500VDC
• Dielectric strength : 1.000 Vrms 50 Hz min.
• Electrical life at full load :
- Momentary models : 1 million cycles (gold plated contacts)
400.000 cycles (silver contacts)
- Latching models : 200.000 cycles
4.50
(.177)
26.50
(1.043)
Illuminated
0.50
(.020)
2.80
(.110)
MATERIALS
6.30
(.248)
ELECTRICAL SPECIFICATIONS
00 )
4. IA
Ø3 39D
.3
(1
Ø26.50
(1.043DIA)
Ø30.00x1.50 SI
(1.181DIAx1.50 IS)
• Case : PA46
• Actuator : PA12, gloss finish
• Bushing/ bezel : ABS, gloss finish
• Contacts :
Silver (code 2)
or silver, gold plated (code 4)
CFP30DT
WIRING DIAGRAM
➞ Flat
POLE 2
LED
GENERAL SPECIFICATIONS
• Panel thickness :
- Snap-in version : 1,5 (.059) to 2 mm (.078) with panel gasket
2 (.078) to 2,5 mm (.885) without panel gasket
- Threaded bushing version : 1(.039) to 9 mm (.354) max.
• Total travel : 2,8 mm ± 0,5 mm
• Typical operating force : 8N ± 2N
• Low level or mechanical life :
• Torque : 2 Nm max. applied to nut
• Operating temperature : -40°C to +75°C
LED
POLE 1
CFP30DT
The company reserves the right to change specifications without notice.
B2-150
www.apem.com
APEM
FP series
Overview
FP
SERIES
R
Model
C
D
Silver
Silver, gold
plated
Electrical function
Round, curved
1
3
Snap-in, dia. 30 mm
Threaded bushing,
dia. 30 mm
Contact mat.
2
4
Actuator
Blue
Black
Green
Grey
Yellow
Red
White/natural
Bright chrome
Orange
OFF - ON
Normally open
(NO)
1
Solder lugs
LED control & No of poles
A
B
C
D
E
Actuator colour
1
2
3
4
5
6
7
8
9
Terminals
Bezel colour
1
2
3
4
5
6
7
8
Blue
Black
Green
Grey
Yellow
Red
White/natural
Bright chrome
LED colour
X
A
B
C
D
E
F
G
Non-illum.
Blue
Green
Red
Yellow
White
Red/green
Red/blue
Non-illuminated, 1 pole
Non-illuminated, 2 poles
Independent, 1 pole
Independent, 2 poles
Independent, 1 pole, dimming LED
Symbols
LED resistor
2
5
6
No resistor
supplied
12V resistor
24VDC resistor
15VDC resistor
30VDC resistor
See end of series
Marking
X
1
2
No marking
Pad printing
Laser
ABOUT THIS SERIES
On the following pages, you will find successively :
model structure of switches and options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Mounting accessories : Standard hardware supplied :1 panel gasket (snap-in versions)
1 plastic hex nut and 1 panel gasket (threaded bushing versions)
Packaging unit : 20 pieces
APEM
www.apem.com
B2-151
B2
FP series
Ø
.20 30.
0D 5 0
IA /+0
0/+ .5
.01
9)
14.00
(.551)
(1
CFP30DEC1-A
Ø26.50
(1.043DIA)
Ø26.50
(1.043DIA)
LATCHING
OFF
2.80
(.110)
26.50 6.30
(1.043) (.248)
0.50
(.020)
00 )
4. IA
Ø3 39D
.3
(1
FICHIER: CFP30DEC-P3
ECHELLE: 0.625
indice A
le 17/02/2014
4.50 26.50
(.177)(1.043)
➞ Flat
Snap-in mounting - solder lug terminals
FPCR1•1
00 )
4. IA
Ø3 39D
.3
(1
ON
Ø29.80
(1.173)
CFP30DT1-A
MOMENTARY (NO)
FPCR3•1
2.80
(.110)
6.30
(.248)
0.50
(.020)
Ø29.80
(1.173)
CFP30DT1-A
➞ Flat
Mounting by threaded bushing - solder lug terminals
4.50
(.177)
00 )
4. IA
Ø3 39D
.3
(1
Ø26.50
(1.043DIA)
LATCHING
ON
Ø26.50
(1.043DIA)
MOMENTARY (NO)
FPDR3•1
0.50
(.020)
0.50
(.020)
00 )
4. IA
Ø3 39D
.3
(1
4.50 26.50
(.177) (1.043)
OFF
26.50 6.30
(1.043) (.248)
FPDR1•1
6.30
(.248)
B2
MODEL
STRUCTURE
4.50
(.177)
To order a product, replace • with one of the codes selected under “LED control
and number of poles” on next page, then add he desired options.
2.80
(.110)
Ø30.00x1.50 SI
(1.181DIAx1.50 IS)
CFP30DT2-A
2.80
(.110)
Ø30.00x1.50 SI
(1.181DIAx1.50 IS)
CFP30DT2-A
LED
B2-152
www.apem.com
POLE 2
LED
POLE 2
LED
POLE 1
APEM
CFP30DT3-A
FP series
Options
LED CONTROL AND NUMBER OF POLES
Complete the model numbers on previous pages with one of the following codes.
Function 1 (latching)
Function 3 (momentary)
Non-illuminated
one pole
Independent
one pole
A
C
CFPSH1-A
CFPSH1-A
CFPSH1-A
CFPSH1-A
CFPSH2-A
CFPSH2-A
Non-illuminated
two poles
CFPSH2-A
CFPSH2-A
CFPSH5-A
CFPSH5-A
CFPSH5-A
CFPSH5-A
CFPSH6-A
CFPSH6-A
CFPSH7-A
CFPSH7-A
CFPSH7-A
CFPSH7-A
CFPSH8-A
CFPSH8-A
CFPSH6-A
CFPSH6-A
Independent
two poles
B
D
CFPSH3-A
CFPSH3-A
CFPSH3-A
CFPSH3-A
CFPSH4-A
CFPSH4-A
CFPSH4-A
CFPSH4-A
Independent
one pole
Dimming LED
E
B2
CFPSH8-A
CFPSH8-A
dotted line = jumper to
be wired by the user.
LED- has to be wired to
one pin of pole 2.
CFP30SHE-A
FICHIER:
CFPSH-P5
FICHIER: CFPSH-P5
FICHIER:
CFPSH-P5
FICHIER:CFPSH-P5
ECHELLE:
ECHELLE: 0.625
0.625
ECHELLE:
ECHELLE:0.625
0.625
indice
A
indice
A
indice A
indice A
le
19/01/11
le 19/01/11
19/01/11
le
le 19/01/11
CONTACT MATERIALS
2
4
FICHIER: CFP30SH-P4
ECHELLE: 0.625
indice A
le 03/03/2014
Silver
Silver, gold plated
ACTUATOR COLOUR
1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7 : white/natural - 8 : bright chrome - 9 : orange
BEZEL COLOUR
LED COLOUR
X : non-illuminated
A : blue - B : green - C : red - D : yellow - E : white - F : red/green - G : red/blue
APEM
www.apem.com
B2-153
FP series
Options
LED RESISTOR
2
5
6
B2
No resistor supplied
12VDC resistor
24VDC resistor
15VDC resistor
30VDC resistor
MARKING
X
1
2
No marking
Pad printing
Laser
SYMBOLS
Blank
➞ Flat
No symbol
Available symbols
See end of K-range, section D.
Ø
(.6 16
3 0 .0 0
DI
A)
Marking colour
White marking for illuminated actuators (laser etching) and non-illuminated
black actuators (pad printing). Black marking for non-illuminated colour
actuators (pad printing). Other : on request.
Marking area
The symbol will be included in the hatched area.
(this is the optimal area, larger symbols can be made on request)
CFP30ZL-A
FICHIER: CFP30ZL-P5
ECHELLE: 0.625
indice A
le 17/02/2014
B2-154
www.apem.com
APEM
FP series
Symbols
Most symbols meet the ISO 7000 standard “graphical symbols for use on equipments” (code given in bracket in the
description). Contact us for symbols not featured in the following tables.
Legend scale :
Depending on space available on the product (see “Symbols” section).
CODE
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
32
Emergency first
aid vehicle
(2565)
Rear
ventilator
33
Load tipping
(1557)
18
Heating
(0637)
34
Loading light
(2457)
19
Door
opening
35
Tractor, rear-ward
(1667)
04
Windshield
demister/defroster
(0635)
36
Combine,
direction of
movement (1678)
05
21
Windshield
wiper
(0086)
37
Use no forks
(2406)
06
22
Windshield
washer
(0088)
38
Transmission
(1166)
07
Stop
23
Ventilator fan
(0089)
39
Working spot
light
(1145)
08
Motion
24
Side mirror
defroster
40
Engine
(0640)
09
Up motion
25
Restarting
pump
41
Horn
(0244)
10
Down motion
26
Front
fog lights
(0633)
42
Lock
(1656)
11
Hot
27
Rear
fog lights
(0634)
43
Taxi sign light
(2551)
12
Cold
28
Propulsion
system trim
44
Working light
(1204)
13
Hazard warning
(0085)
29
Beacon
(1141)
45
Working light
symmetric
(1204)
14
Traveller
lighting
30
Anchor
46
15
Driver
lighting
(1421
31
Electric motor
(0011)
47
16
01
17
02
03
XX
APEM
None
Revolving light
www.apem.com
B2-155
B2
FP series
Symbols
Legend scale :
CODE
B2
DESCRIPTION
CODE
DESCRIPTION
CODE
48
All wheel
drive
64
Indicator
80
Front windshield
heating
49
Differential lock
(1662)
65
Brake release
81
Aus
50
66
Baggage room
left door
82
Radiator
fan
51
67
Baggage room
right door
83
Remove
retarder
52
68
Power blinds
84
Restricted
speed
53
69
Engine
idle control
85
Preheater
54
Rear window
wiper
(0097)
70
Cruise
res/set
86
ABS detection
55
Rear window
washer
(0099)
71
Driver windows
up/down
87
ECAS detection
56
Lower load
(2223)
72
Middle door
opening
88
Engine stop
57
Cab lock
(1560)
73
Front door
opening
89
Cruise
res/cancel
58
Extraction
74
Lighting in
baggage room
90
ECAS reset
59
Pumping in
75
Cruise on/off
91
Driver windows
heating
60
Rear PTO
(1572)
76
TV
92
Cruise set
61
Front PTO
77
Pump
93
Air bag
up/down
62
Rockshaft down
78
Toilet
94
Read lighting
63
Rockshaft up
79
Toilet
decontamination
95
Lighting
main switch
B2-156
SYMBOL
SYMBOL
www.apem.com
SYMBOL
DESCRIPTION
APEM
FP series
Symbols
Legend scale :
CODE
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
CODE
SYMBOL
DESCRIPTION
96
Heating
using water
AD
AV
97
Low beam
AE
AW
98
Position
lights
AF
AY
99
Diesel
acceleration
AG
Battery charging
condition
(0247)
AZ
A1
Manual
mode
AH
Turn signals
(0084)
B1
A2
Clockwise
cabin rotation
AJ
High beam
(0082)
B2
A3
Anticlockwise
cabin rotation
AK
Differential lock,
bogie
(2600)
B3
A4
AL
Brushing with a
rotating brush
(0070)
A5
AM
Differential lock,
transfer case 4x4
(2475)
A6
Parking
brake
AN
Loader bucket,
float
(1441)
A7
AP
Loader bucket
(1437)
A8
AQ
Rear window
washer & wiper
(0098)
A9
AR
Header
Header drive
(1579)
AA
AS
Excavator/backhoe
boom side shift
(2091)
AB
AT
Chemical water
treatment
(1851)
AC
AU
Grapple skidder,
single funct° boom
(1762)
APEM
www.apem.com
B2-157
B2
很抱歉,暂时无法提供与“FPDR3D1428F12TV”相匹配的价格&库存,您可以联系我们找货
