HFX36R12
HFX36R12
    APEM(埃斐)
    APEM - HFX36R12 - HALL EFFECT SWITCH, 5V, 0.03A, CONNECTOR
HFX36R12 数据手册
HFX series First generation Hall effect joysticks HFX series First generation Hall effect joysticks OPTION SELECTION HFX LIMITER PLATE SERIES OUTPUT OPTIONS S Square 0 0V to 5V (Rail to Rail) R Round 1 0.5V to 4.5V X Slotted 2 0.25V to 4.75V Y Slotted 3 1V to 4V P Plus 4 2V to 3V C Cross 5 0.25V to 4.75V - Sensor 1 0.25V to 4.75V - Sensor 2 6 0.5V to 4.5V - Sensor 1 0.5V to 4.5V - Sensor 2 7 1V to 4V - Sensor 1 1V to 4V - Sensor 2 8 0.25V to 4.75V - Sensor 1 4.75V to 0.25V - Sensor 2 HANDLE MOUNTING -10 Ball Tip (2 Axes) 0 Flush -11 Tapered (2 Axes) 1 Drop-in -22 1 Pushbutton (2 Axes) 2 Raised -27 1 Sealed Pushbutton (2 Axes) 3 Snap-on 10 1V to 4V - Sensor 1 4V to 1V - Sensor 2 -33 3 Axes 4 Rear Mount 0-U USB -44 1 Pushbutton (3 Axes) 0-V Voltage Regulator -45 2 Pushbuttons (3 Axes) 1-J Cursor Emulation -36 Low Profile (3 Axes) 9 0.5V to 4.5V - Sensor 1 4.5V to 0.5V - Sensor 2 ADDITIONAL OPTIONS -D Dual Decode¹ -E Environmental Sealing -F Friction Clutch² -AD Analog Deadband 4 -DC Center Detect³ 4 NOTES 1. Dual Decode cannot be used with USB or Voltage Regulator. Dual Decode requires Output Option 9. 2. Friction Clutch requires limiter plates R, X, or Y. 3. Center Detect requires output Option 1. 4. Depth below panel increases by 10mm (0.394in) for USB, Voltage Regulator, Dual Decode, Analog Deadband, and Center Detect Output Options. Up to IP68 available. Mounting accessories. Standard hardware includes: gasket, clamping ring, and four 40-3/4Phil Ph MS SS screws. Note: The company reserves the right to change specifications without notice. www.chproducts.com ,4 ,4 4 HFX series First generation Hall effect joysticks SPECIFICATIONS MECHANICAL (FOR X, Y AXES) Break Out Force Operating Force Maximum Applied Force Mechanical Angle of Movement Expected Life Material Lever Action – – – – – – – 1.3N (0.3lbf ) 2.8N (0.63lbf ) 200N (45.00lbf ) 36° (±18°) 3 million cycles Glass filled nylon Single spring omnidirectional MECHANICAL (FOR Z AXIS) Break Out Torque Operating Torque Maximum Allowable Torque Hand Mechanical Angle Handle Action Expected Life – – – – – – 0.09N·m (0.80lbf·in) 0.121N·m (1.07lbf·in) 0.150N·m (1.33lbf·in) 80° (±40°) Spring centering, rotational 3 million cycles ENVIRONMENTAL Operating Temperature Storage Temperature Sealing (IP) EMC Immunity Level (V/M) EMC Emissions Level ESD – – – – – – -25ºC to 70ºC (-13ºF to 158ºF) -40ºC to 70ºC (-40ºF to 158ºF) IP65 to IP68* IEC 61000-4-3: 2006 IEC 61000-4-8: 1993/A1: 2000 IEC 61000-4-2: 2008 ELECTRICAL Sensor Resolution Supply Voltage Operating Reverse Polarity Max Overvoltage Max Output Voltage Output Impedance Current Consumption Max Return to Center Voltage (No Load) Output Ramp – – – – – – – – – – Hall effect Infinite 5.00VDC –14.5VDC 18VDC See options 6Ω 10mA per axis ±200mV See options NOTES: * All values are nominal Exact specifications may be subject to configuration. Contact Technical Support for the performance of your specific configuration. Excludes some handle options Note: The company reserves the right to change specifications without notice. www.chproducts.com HFX series First generation Hall effect joysticks DIMENSIONAL DRAWINGS 10 48.51 (1.91) 48.51 (1.91) Ø31.75 (1.25) 98.55 (3.88) 35.56 (1.40) 33.53 (1.32) 41.15 (1.62) 11 35.56 (1.40) 48.51 (1.91) Ø21.08 (0.83) 48.51 (1.91) 100.58 (3.96) 35.56 (1.40) 33.53 (1.32) 41.15 (1.62) 22, 27 35.56 (1.40) Ø20.32 (0.80) 48.51 (1.91) 48.51 (1.91) 119.38 (4.70) 35.56 (1.40) 33.53 (1.32) 35.56 (1.40) 41.15 (1.62) 33 48.51 (1.91) Ø35.31 (1.39) 48.51 (1.91) 108.46 (4.27) 35.56 (1.40) 33.53 (1.32) 41.15 (1.62) Note: The company reserves the right to change specifications without notice. www.chproducts.com 35.56 (1.40) HFX series First generation Hall effect joysticks DIMENSIONAL DRAWINGS 44 Ø35.31 (1.39) 48.51 (1.91) 48.51 (1.91) 119.89 (4.72) 35.56 (1.40) 33.53 (1.32) 35.56 (1.40) 41.15 (1.62) 45 Ø35.31 (1.39) 48.51 (1.91) 48.51 (1.91) 119.89 (4.72) 35.56 (1.40) 33.53 (1.32) 35.56 (1.40) 41.15 (1.62) 36 48.51 (1.91) Ø35.31 (1.39) 48.51 (1.91) 98.81 (3.89) 35.56 (1.40) 33.53 (1.32) 41.15 (1.62) 35.56 (1.40) NOTES: 1. DEFAULT WIRE COLOR CODE* Dimensions are in mm/(inch). 2. Depth below panel increases by 10mm (0.394in) for USB, Voltage Regulator, Dual Decode, Analog Deadband, and Center Detect Output Options. 3. Axes orientation: + Z Y+ X- Y- X+ COLOR FUNCTION RED Vcc or Vdd BLACK Ground BLUE X Axis YELLOW Y Axis GREEN Z Axis WHITE Switch Common (optional) ORANGE Switch 1 (optional) VIOLET Switch 2 (optional) * - Starting from the strain relief, the leads are 178mm (7in) long, 3.18mm (0.125in) stripped. Note: The company reserves the right to change specifications without notice. www.chproducts.com AWG 28 22 HFX series First generation Hall effect joysticks DIMENSIONAL DRAWINGS - continued PANEL CUTOUT DIMENSIONS Ø41.66 (1.64in) Ø35.56 (1.40) Ø35.56 (1.40) Ø7.54 (19/64) 4 places Ø3.18(1/8in) 4 places Ø3.18(1/8in) 4 places 17.78 (0.70) 17.78 (0.70) 17.78 (0.70) 17.78 (0.70) 17.78 (0.70) 17.78 (0.70) 35.56 (1.40) 35.56 (1.40) FLUSH MOUNT * 35.56 (1.40) DROP-IN, RAISED, SNAP-ON REAR MOUNT OPTION B * Not available for Option 11 Handle REAR MOUNT OPTION A ** ** Available only for Option 10, 22, and 27 Handles MOUNTING OPTIONS 4-40 x 3/8 Phil Panhead FLUSH DROP-IN Brass insert 4 places 39.37 (1.55) 4-40 x 7/8 Phil Panhead 4-40 x 9/16 Phil Panhead RAISED 32.77 (1.29) Brass insert 4 places Brass insert 4 places 27.18 (1.07in) 4-40 x 9/16 Phil Panhead SNAP-ON REAR MOUNT REAR MOUNT OPTION A 32.77 (1.29) Brass insert 4 places OPTION B 32.77 (1.29) 39.37 (1.55) 4-40 x 3/8 Phil Panhead 4-40 x 3/8 Phil Panhead NOTES: - Panel • Dimensions are in mm/(inch). - 6mm spacer (0.24in) • The panel thickness can be 1.17mm to 3.17mm (0.046in to 0.125in), except for the Rear Mount Option A, where the maximum panel thickness is 1.6mm (0.063in). - Standard gasket • A panel thickness of 1/16" (1.6mm, 0.063in) was considered for all the below-panel depth values. - Rear mount gasket • The below-panel depth is extended by 10.15mm (0.40in) with the USB option. Note: The company reserves the right to change specifications without notice. www.chproducts.com HFX series First generation Hall effect joysticks CONFIGURATION OPTIONS LINEAR OUTPUT OPTIONS OPTION 0 OPTION 1 OPTION 2 OPTION 3 5.0 5.0 4.5 4.0 4.0 4.0 4.0 3.5 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.5 0.5 0 0 0 MIN AXES TRAVEL (º) MAX OPTION 4 5.0 MIN AXES TRAVEL (º) MAX OPTION 5 OUTPUT VOLTAGE (V) 4.5 OUTPUT VOLTAGE (V) 4.5 5.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 MIN AXES TRAVEL (º) OPTION 6 0 MAX OPTION 7 5.0 4.5 4.0 4.0 4.0 4.0 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.5 0.5 0 0 0 AXES TRAVEL (º) MAX AXES TRAVEL (º) OPTION 8 5.0 5.0 MAX MIN AXES TRAVEL (º) OPTION 9 4.5 4.0 4.0 4.0 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.5 0 0 MIN AXES TRAVEL (º) MAX MIN AXES TRAVEL (º) MAX 3.5 3.0 2.5 2.0 1.5 1.0 MAX 0 5.0 4.5 3.5 MAX OPTION 10 4.5 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) MIN AXES TRAVEL (º) 0.5 OUTPUT VOLTAGE (V) MIN OUTPUT VOLTAGE (V) 4.5 OUTPUT VOLTAGE (V) 4.5 3.5 MIN 5.0 4.5 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 5.0 4.5 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 5.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 MIN AXES TRAVEL (º) Output 1 Output 2 Note: The company reserves the right to change specifications without notice. www.chproducts.com MAX 0 MIN AXES TRAVEL (º) MAX HFX series First generation Hall effect joysticks CONFIGURATION OPTIONS - continued ADDITIONAL OUTPUT OPTIONS PLUG-AND-PLAY SOLUTIONS: USB Featuring USB 1.1 HID compliant interface, CH Products’ USB joysticks are recognized as standard HID “game controller” devices. Adhering to the HID specification, CH Products’ USB joysticks are plug-and-play with most versions of Windows and Linux. Joystick button and axes assignments are dependent upon the controlled application. FEATURES • USB 1.1 HID compliant “game controller” device • Easy to install and operate • Functions determined by controlled application • Standard Male Type A Connector SUPPLIED WIRING USB Male Type A Connector • USB Male Type A Connector with overmolded cable (Optional ruggedized military connectors are available.) • The HFX Series I USB joysticks are shipped with a standard USB cable of 7 feet. Cables of 14 feet are also available. Please mention the desired length at order entry. Note: The company reserves the right to change specifications without notice. www.chproducts.com HFX series First generation Hall effect joysticks CONFIGURATION OPTIONS - continued ADDITIONAL OUTPUT OPTIONS PLUG-AND-PLAY SOLUTIONS: JOYBALL (CURSOR EMULATION) The Joyball option converts multi-axis joystick output into a mouse, trackball, or cursor control device. The joystick’s internal microprocessor converts absolute axis position into a cursor velocity, which is translated as a relative trackball or mouse position. Supported protocols include Sun Microsystems (mouse systems 5vdc serial) and USB. APPLICATIONS The Joyball option is ideal for vehicle applications subjected to dirt and high vibration which makes operating a traditional cursor control device difficult. The Joyball option is widely used in shipboard and military applications. FEATURES • HID compliant “pointing device” • Plug-and-play with USB option • Ideal for marine GPS and navigation • Environmental sealing up to IP68 SUPPLIED WIRING USB: USB Male Type A Connector with overmolded cable SUN: SUN mini-DIN plug with overmolded cable and strain relief I/O COMPLEMENT/ USER SPECIFIED PARAMETERS: • USB 4 pushbuttons 2 or 3 axes (X, Y, and Z “scroll”) • SUN 2 pushbuttons and 2 axes (X, Y) Note: The company reserves the right to change specifications without notice. www.chproducts.com HFX series First generation Hall effect joysticks CONFIGURATION OPTIONS - continued ADDITIONAL OUTPUT OPTIONS DUAL DECODE Dual Decode utilizes a microprocessor to monitor two linear opposite-ramp signals for each joystick axis and provides one proportional (0.5VDC – 4.5VDC) and one logical output accordingly. The dual inversed signals are continuously monitored and a logical signal of 0VDC is provided for over-range (>4.5VDC), under-range (4.5VDC) or under-range (
HFX36R12 价格&库存
很抱歉,暂时无法提供与“HFX36R12”相匹配的价格&库存,您可以联系我们找货
