10C1616
10C1616
    APEM(埃斐)
    APEM - 10C1616 - CAP, TACTILE SWITCH, WHITE
10C1616 数据手册
10C -1 M Round caps • ergonomic feel DISTINCTIVE FEATURES Slightly concave round cap Ø19.2 mm h=13.7 mm Consists of two pieces Designed for excellent illumination SWITCH SPECIFICATIONS : see Multimec® 5 series. 13,7 (0,540) 11,2 (0,441) 5G+10C - SMD Ø 19,2 (0,754) Ø2 7,62 (0,300) 14 (0,551) 2,0 (0,8 66) 11,2 (0,441) 5G+10C - TH W/LED Min 10,16 (0,400) Max 12,5 (0,492) 13,7 (0,540) EC PANEL PCB SWITCHES 10 18 0C Ø 19,2 (0,754) Ø2 7,62 (0,300) 2,0 (0,8 66) The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2mm. 1 Round caps • ergonomic feel MOUNTING MATERIALS • Panel cut-out : 10C : Ø19.8 mm • Switch spacing AxB : 10C : illuminated 30.2 x 30.2 mm non-illuminated 24 x 24 mm • Top part of the cap: : - solid color : ABS UL94HB - illuminated : polycarbonate UL94HB • Bottom part of the cap : polycarbonate UL94HB ASSEMBLY 1. LED PLACEMENT 2. SMD 14,0 (0,551) 14,0 (0,551) 7,0 (0,276) 1,2 (0,047) 7,62 (0,300) 7,0 (0,276) 2,5 (0,098) 12,5 (0,492) TH 14,0 (0,551) 10,16 (0,400) 2 Ø 1 14,0 (0,551) 7,0 (0,276) 7,0 (0,276) 7,62 (0,300) PCB SWITCHES 10C (0 ,0 39 ) Round caps • ergonomic feel BUILD YOUR PART NUMBER ILLUMINATED 5G MOUNTING SERIES ACTUATION FORCE LED CAP COLOR TOP 10C 16 TH9 through-hole 20 2.0N 02 blue SH9 surface mount 35 3.5N 22 green 65 6.5N 29 high intensity green 42 yellow 61 white 82 red LEGEND frosted white 118 OK 123 COLOR BOTTOM 16 2242 green/yellow 8222 red/green 8242 red/yellow PAINT COLOR 09 frosted white black NON-ILLUMINATED 5G MOUNTING SERIES ACTUATION FORCE TH9 through-hole 20 2.0N SH9 surface mount 35 65 CAP 10C COLOR TOP LEGEND 00 blue 118 3.5N 03 grey 123 6.5N 08 red 09 black 36 signal white OK COLOR BOTTOM 16 frosted white LEGEND COLOR 06 white ABOUT THIS SERIES Notice : please note that not all combinations of above numbers are available. Contact factory for more information. For more information on legends see the next two pages. 3 PANEL PCB SWITCHES 10C PCB SWITCHES Legends Available for Multimec caps STANDARD LEGENDS STANDARD LEGENDS LEGEND 1DS09_ 1FS096R_ 0 000 000 1 001 001 2 002 002 3 003 003 4 004 004 5 005 005 6 006 006 7 007 007 8 008 008 9 009 009 # 107 107 019 019 1ZB09D_ 1ZB16DLMH_ 1ZCS_ 1Z_ 1ZW_ 10R_ & 10RF_ 10RM16_ 10Q_ 10QM16_ 10A_ 054 054 054 059 059 10C_ 033 133 034 134 135 135 + 136 123 123 136 123* 123 123 123 ON/OFF 017 017 STOP 018 018 START RESET 038 CANCEL ENTER ESC 059 136 031 031 038 038 048 048 105 105 123 051 ON 116 OFF 117 OK 118* SET 119 MENU 120 FUNC 121 HOME 122 118 118 118 STANDARD OPTIONS • 1DS: pad printed • 10RM & 10QM: metal symbol • 1FS: reverse printed • 10R(F) & 10Q: pad printed / reverse printed • 1ZB: pad printed / laser marked • 10A: pad printed / laser marked • 1ZCS: pad printed *reverse printed *laser marked • 10C: pad printed / laser marked • 1Z & 1ZW: pad printed / laser marked 4 118 Available for Multimec caps HOW TO ORDER POSITIONING OF LEGENDS ON ROCKER-ACTION CAPS LEGEND ILLUMINATION • Option 1 - laser marked: In case of laser marked legends an “LM” is added after the cap colour, before the legend code. We recommend using hard paint (additional “H” ) for increased lifetime of the paint. E.g. 1ZB16DLMH13609 When ordering legends for caps with hinge-type cap retention system, it is important to note the position of the cap. An extra letter (U, D, R or L) needs to be added to the part number to refer to the position of the hinges in relation to the legend. See samples: • Option 2 - reverse printed: In case of reverse printed caps an “R” is added after the cap colour, before the legend code. Especially relevant when standard legends have both negative and positive print options. E.g. 1FS096R00009 Rocker-action caps without a lens: 1A, 1B, 1M, 1ZA and 1ZB ON/OFF UP 1A09U01706 ON/OFF RIGHT 1ZB16RLMH11809 OK ON/OFF • Option 3 - metal symbol: Only available ON/OFF for 10RM andON/OFF 10QM ON/OFF(therefore the “M”). E.g. ON/OFF 10RM16059 ON/OFF ON/OFF ON/OFF ON/OFF 3 1 + ON/OFF - 4 DOWN 2 1B09D01706 2 4 1 + ORIENTATION OF THE SWITCH LEFT 1ZB09L00106 1 3 3 1 1 + ON/OFF ON/OFF + 3 4 + - 1 2 2 4 - 2 UP 4 -2 1 1 + 4 3 + 3 DOWN STANDARD AND CUSTOM LEGENDS 3 • Standard are only certain legends on certain caps. See the table on the previous page. • All standard pad-printed legends are white on black caps. • All standard reverse-printed and laser marked legends are black on frosted white cap. STANDARD LEGENDS CAP COLOR CAP DIRECTION* 1B 00 Blue D Down 1DS 02 Green U Up ... 03 Grey R Right 04 Yellow L Left 06 White 08 Red 09 TYPE* LEGEND LEGEND COLOR* 001 1 00 Blue 002 2 02 Green 003 3 03 Grey etc 04 Yellow 06 White 08 Red Black 09 Black 16 Frosted white ... Etc ... Etc *Only for hingetype caps LM Laser marked on soft paint LMH Laser marked on hard paint R Reverse printed *In case of illumination ... *In case of reverse printed and laser marked legends the colour of the paint Notice: The size of the legends listed may not correspond to the actual size. If you decide to use one of the standard legends without any adjustments (without a new cliché or programming) on another cap than designated in the table, then there is no cliché or programming cost, for this to apply the cap has to be black and the print white. For further information on legends please contact your local distributor or MEC. 5 PANEL PCB SWITCHES Legends • • • • • • • 1B • • • • • • • 1DS • • • • • • • • • • • • 1ES/1FS 1GAS/1GCS • • • • • • 1H • • • • • • • 1KS • • • • • • • • • 1M 1PS • 1QS • • • • • 40 42 50 53 57 58 • • • • • • • • • • • • • • • • 1RS 1SS • 1TS/1US/1VS • • • • • • • • • • 1WAS/ 1WDS/1WPS • 1XS • • • 1ZA • • • • • • • • • • 1ZB • • • • • • • • • • 1ZCS • • • • • • • • • • 1Z/1ZW • • 10A • • • • • • • • 10C • 10R/10RF + 10Q • • • • • • • • The RAL Codes mentioned are the codes nearest to the solid colors in the multimec® range. 6 38 • • 1NS 36 • 1JS 1LS Metal bordeaux / No ral code 1A Metal dark grey / No ral code 08 Metal light grey / No ral code 06 Metal dark blue / No ral code 04 Aqua blue / 5021 Melon / 1028 • 03 Dusty blue / 5014 Tele grey / 7046 • 02 CODE Noble red / 3002 Mint green / 6029 • 00 CAP Signal white / 9003 Ultra blue / 5002 • Red / 3000 34 White / 9010 33 Yellow / 1023 32 Grey / 7004 30 green / 6018 09 Blue / 5012 Black / 9004 Available for Multimec caps Colour / RAL Code PCB SWITCHES Solid colors U -M M EC PANEL PCB SWITCHES EC M I LT 0 81 -1 5G Multimec® 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination DISTINCTIVE FEATURES Large range of accessories Momentary switches with NO or NC/NO function Sealed to IP67 Single or bi-color illumination option Illumination with integrated chip-LEDs ENVIRONMENTAL SPECIFICATIONS • Sealing : IP67 according to IEC 60529 • Working and storage temperature : - non-illuminated : -40 °C/+160 °C - illuminated : -30 °C/+85 °C • Soldering : - through-hole : IEC 60068-2-20 8 - surface mount : JEDEC J-STD-020E ELECTRICAL SPECIFICATIONS • Recommended load : - Gold contacts : 0.5µ-50 mA 24 VDC - Silver contacts : 0.5-50 mA 24 VDC • Contact resistance : 10 MΩ • Contact bounce : 10,000,000 cycles • Terminals : SnCu + 2 µNI + 3 µSn100 The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2 mm. 1 High performance tactile switches • MIL-PRF-28855H • excellent illumination RAS 6,4 13,8 12 0,8 0,8 Min 10,16 5,5 Max 12,5 7,62 10 11 14 7,62 0,8 7,62 7,62 7,62 5,08 5G ILLUMINATED 7,62 7,62 4 0,8 • SMD, TH or right angle TH • NO or NC/NO Min 10,16 Max 12,5 5,08 0,3 6,4 10 14 12 11 4 0,3 10 13,8 5,5 6,4 6,4 TH 10 SMD 5G NON-ILLUMINATED 4,85 7,62 SMD TH 4:1 0,3 8,5 8,5 Max 10,3 0,3 14 Min 10,16 Max 12,5 4:1 5G RAS • SMD or TH • NO • single or bi-color LEDs 0,8 0,8 7,62 7,62 All tolerances unless otherwise noted : ±0.2 mm PCB LAYOUT & CIRCUIT DIAGRAM 2 4 3 -2 Ø 0,9 4 3 12,50 3 4 1,2 7,62 1,2 2,5 -2 1 +3 Ø 0,9 2,5 +3 1 12,50 1 4 +3 2,50 3 4 1 2 3 Ø1,0(3x) 7,62 -2 1 1 1,20 12,50 2 *not for sale in Japan 1 Ø 0,9 2 4 NC/NO function 7,62 5,08 1 7,62 4 RAS 10,16 7,62 10,16 Bicolor - 2 LEDs 10,16 7,62 2 Single LED 7,62 Non-illuminated 7,62 PCB SWITCHES Multimec® 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination BUILD YOUR PART NUMBER ILLUMINATED 5G ACTUATION FORCE MOUNTING SERIES LED OPTIONAL TH9 Through-hole 20 2.0 N 02 Blue SH9 Surface mount 35 3.5 N 22 Green 65 6.5 N 29 High intensity Green 42 Yellow 61 White 82 Red 2242 Green/yellow 8222 Red/green 8242 Red/yellow Q Quiet contact (with 2.0 N only) R Tape & reel G Gold contacts NON-ILLUMINATED 5G MOUNTING SERIES ACTUATION FORCE TH9 Through-hole 20 2.0 N SH9 Surface mount 35 3.5 N 65 6.5 N OPTIONAL Q RAS NCNO Quiet contact (with 2.0 N only) Right angle (with TH only) Normally closed/ normally open function (with 3.5 N only) R Tape & reel G Gold contacts ABOUT THIS SERIES Caps and accessories : for the full range of accessories for Multimec 5G please see the website. 3 PANEL PCB SWITCHES Multimec® 5G PCB SWITCHES Multimec® 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination TAPE & REEL PART NO. ORDERING CODE PITCH QUANTITY PER REEL 5GSH9XX 5GSH9XXR 16 500 5GSH9XX1SSXX-08.0 5GSH9XXR1SSXX-08.0 20 250 5GSH9XX1SSXX-09.5 5GSH9XXR1SSXX-09.5 20 250 • Pitch: see list 5GSH9XX1SSXX-10.4 5GSH9XXR1SSXX-10.4 20 250 • Tape and reel material: antistatic or better 5GSH9XX1SSXX-11.0 5GSH9XXR1SSXX-11.0 20 250 • Quantity per reel: see list 5GSH9XX1SSXX-12.0 5GSH9XXR1SSXX-12.0 20 250 5GSH9XX01 5GSH9XX01R 20 250 5GSH9XX22 5GSH9XX22R 20 250 5GSH9XX42 5GSH9XX42R 20 250 5GSH9XX61 5GSH9XX61R 20 250 5GSH9XX82 5GSH9XX82R 20 250 5GSH9XX2242 5GSH9XX2242R 20 250 5GSH9XX8222 5GSH9XX8222R 20 250 5GSH9XX8242 5GSH9XX8242R 20 250 Tape and reel is available for the parts listed and has the following specifications • Reel diameter: Ø330 mm • Tape width: 24 mm OPERATING FORCE 2.0 N 10 FORCE 6.5 N 10 FORCE 9 9 8 8 8 7 7 7 6 6 6 5 2N 5 F(N) 9 F(N) F(N) 10 3.5 N 3,5N 5 4 4 4 3 3 3 2 2 2 1 1 1 TRAVEL TRAVEL 0 0 0 4 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 0 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 FORCE 6,5N TRAVEL 0 0 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 High performance tactile switches • MIL-PRF-28855H • excellent illumination MOUNTING (CONTINUED) MOUNTING TOOLS FOR MULTIMEC® THROUGH-HOLE SWITCHES Part No. 9861000 1 2 3 4 5 Min. 12,7 Min. 12,7 Min. 10,3 Min. 10,3 Through-hole (TH) Min. 10,3 Min. 10,3 SPACE REQUIREMENT - MATRIX MOUNTING Surface mount (SMD) Min. 15,24 Min. 15,24 MULTIMEC® SPACING EXAMPLES 5GT+1B/C+2C/D 1NS+1NS+1NS 5GT+1A/H 5GS+1B/C+2C/D 5GT+1M 1VS+1TS+1VS 5 PANEL PCB SWITCHES Multimec® 5G PCB SWITCHES Multimec® 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination MOUNTING (CONTINUED) SPACE REQUIREMENT - SWITCH/CAP Cap dimensions Switch spacing Panel cut-out RECOMMENDED MIN.SWITCH SPACING AxB NOMINAL CAP DIMENSION WxH RECOMMENDED MIN. PANEL CUT-CUT 1A/1H 12.7x10.16 12.6x10.1 13.0x10.5 1B/1C+2C/2D 15.24x15.24 15.1x15.1 15.5x15.5 1DS/1ES/1FS 12.7x12.7 Ø9.6 Ø10 1GAS 12.7x11.14 Ø11 Ø11.4 1GCS 15.14x15.14 Ø15 Ø15.4 1JS 12.7x12.7 Ø9.6 Ø10.4 1KS/1KBS/1KCS 15.24x15.24 14.3x14.3 14.7x14.7 1M 25.4x10.16 25x10 27.7x10.5 CAP SERIES 6 1NS 12.7x12.7 Ø9.8/ 14.9 Ø10.2/15.1 1PS/ 1QS/1RS 15.24x10.16 6.5x12.5 7x13, R max. 1.0 1SS/1IS/1LS 12.7x12.7 Ø6.5 Ø7 1TS 12.7x12.7 10.6x10.6 11x11 1US 12.7x12.7 Ø10.6 Ø11.0 1VS 12.7x12.7 10.6x13.25 11.0x13.65 1WAS/1WPS 12.7x10.3 12.5x6.5 12.9x6.9 1WDS 15.34x10.3 15.2x8.0 15.6x8.4 1XS 12.7x12.7 9.4x7.4 9.8x7.9 1YS 17x17 15x15 16x16 1ZA 18.84x10.3 18.7x10.1 19.4x10.5 1ZB 24.34x12.1 R1=7.4; R2=17.5 90° R1=7.1; R2=17.5-17.75 90° 1ZCS 14.44x14.44 Ø14.3 Ø14.7 1Z/1ZW 35.5x35.5; 41.6x41.6 Ø29.5 Ø30.3 10A 17x35 R=5.3; 10.6x28 R=5.5; 11x28.4 10C non-ill: 24 x 24; ill.: 30.2 x 30.2 Ø19.2 Ø19.8 10R/10RF/10RM 40.5x40.5 Ø30.0 Ø30.6 10Q/10QM 32.5x32.5 22x22 22.5x22.5 High performance tactile switches • MIL-PRF-28855H • excellent illumination LED COMPONENT SPECIFICATIONS LED COMPONENT SPECIFICATIONS Color Blue Green Yellow White Red High Intensity Green Color Codes 02 22 42 61 82 29 ABSOLUTE MAXIMUM RATINGS (Ta= 25°C) Power mW 110 75 60 48 65 102.5 Current forward mA 25 30 25 15 25 25 Forward peak current mA 100 80 60 100 100 150 Voltage reverse V 5 5 5 NA 12 5 Operating temperature °C -40/+85 -55/+85 -40/+85 -40/+85 -30/+85 -40/+85 Storage temperature °C -40/+90 -55/+85 -40/+90 -40/+85 -40/+85 -40/+85 Soldering temperature °C 2 3.3 245 for max 10 sec ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25 °C) Voltage forward Typ. V 3.3 Max. V Current reverse (VR=5V) Max. µA Wave length nm Spread nm 1.75** 2.85 3.7 2.4 2.35 3.1 2.5 4.1 50 100 10 NA 100 50 470 571 591 NA 633 525 25 NA 15 NA 16 30 120 130 120 150 160 60 Min. mcd 45 18 28.5 71 28 500 Typ. mcd 122* 35 72* 224* 180* 1000 Lm/w NA NA NA 36 7 NA Spread angle degree Luminous Intensity Optical intensity 2 */F=20 mA, **Pulse width 1ms Duty cycle 1:5, ***/F=50 mA, ****Luminous Flux mlm 7 PANEL PCB SWITCHES Multimec® 5G PCB SWITCHES Multimec® 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination USAGE GUIDELINES HOW TO GET THE BEST RESULTS WITH MEC SWITCHES ? case situation with water jets, complete immersion into a liquid with a temperature below the board or surface tension reducing additives. These guidelines are offered to users of MEC Switches as an aid to ensure successful and reliable switch operation. Please see the technical specifications for details on operating and storage temperatures and soldering guidelines to make sure you select the best switch for your application. When wave soldering is taking place, MEC strongly recommend that the temperature profile is analyzed and compared with the temperature rating of the switch. It is also important to monitor the accumulated heat buildup from both the pre-heat zones and the solder zone. Recommended cleaning methods are demineralized water. Any surface tension reducing agents, such as soap, must not be used as they risk causing a potential leakage of the switch. Most standard accessories for multimec 5 series switches are made from ABS plastic with a maximum operating temperature of 65 °C. It is strongly recommended that accessories are mounted after soldering of the switch. If this is not possible care must be taken not to overheat the accessories during the soldering process. The 1SS and 1GAS/1GCS caps are, however, made of high temperature materials and will meet the same temperature specifications as the switches. For accessories made from other plastic materials please see multimec® 5 series technical specifications. Wave soldering: heat built up in the switch during pre-heating and soldering must not exceed the maximum operating temperature of the switch. Peak temperature must not exceed 260 °C, and soldering time is max 10 sec. (IEC 60068-2-20 8) ® SOLDERING - THROUGH HOLE VERSIONS Hand soldering: max. 350 °C for max. 3 sec SOLDERING - SURFACE MOUNT VERSIONS LEDs have their own temperature specifications. When fitted in a switch the LED will determine the max. operating temperature, i.e. 5GTH93522 has an upper temperature limit of 85 °C! For all methods - infrared, convection and vapor phase. The upper limit 260 °C/30 sec must be observed. The soldering temperature profile must have moderate temperature gradients. (JEDEC J-STD020E) MOUNTING AND DISMOUNTING ROHS COMPLIANCE If switches are to be mounted in rows it is essential that the recommendations regarding spacing are followed. PC board thickness should be 1.4 ±0.2 mm and terminal hole diameter should be 0.9 mm. As of 1 July 2006 MEC has completed the conversion to RoHS compliance. For more info please see our homepage www.apem.com All multimec® 5 series caps and bezels are easily snapped onto the switch modules and can be changed at a later time. TEMPERATURE LIMITS: A mounting tool is available for through hole multimec® 5 series switches. SOLDERING AND CLEANING MULTIMEC® SERIES Multimec® 5 series switches are fully sealed to IP67 specifications to minimize solder flux and aqueous based cleaning solutions from entering the switch and contaminating the contacts. The switches can be placed on the PC board with other components and wave soldered. Multimec® 5 series offers a high level of sealing, however, with aqueous solvent solutions care must be taken to avoid the worst 8 Switch LEDs Accessories 160 °C 85/90 °C 65/85/160 °C PACKAGING Multimec® 5 series switches are packed in rigid tubes of 50 pieces each. A box contains 1.000 pcs. The surface mount versions of multimec® 5 series switches with a height up to 12.5 mm can also be delivered on tape/reel. Each reel contains 250/500 pcs.
10C1616 价格&库存
很抱歉,暂时无法提供与“10C1616”相匹配的价格&库存,您可以联系我们找货
