A01MXB+A0152B
A01MXB+A0152B
    APEM(埃斐)
    APEM - A01MXB+A0152B - Industrial Pushbutton Switch, A01 Series, 16 mm, DPDT, Maintained, Mushroom, ...
A01MXB+A0152B 数据手册
A01 series Mushroom head pushbutton switches Distinctive features and specifications A01M_AX1607US Panel Sealed to IP65 Single pole to four pole changeover Custom engraving Push on tab terminals 6A 250VAC PANEL CUT OUT ELECTRICAL SPECIFICATIONS • Current/Voltage Rating : 10mA 5VAC min, 6A 250VAC, 6Amp 12VDC • Initial Contact Resistance : 10mΩ max at 1A 4VDC • Insulation Resistance : 50MΩ min • Dielectric Strength : 750V between open contacts, 5KV live to accessible • Electrical Life : 50,000 cycles min • Contact Gap : >1mm (0.039) • Insulation : Class 2 7.25 (.285) Ø16.00 0.00/+0.30 (.629 DIA .000/+.011 ) 1.50 (.059) MECHANICAL SPECIFICATIONS • Mechanical Life (operator) : Momentary, 1 million cycles, maintained 100,000 cycles • Terminals : Solder/quick connect 2.8mm (0.110) GENERAL SPECIFICATIONS AGENCY APPROVALS • Operating Temperature : -20°C to +55°C • Solder Heat Resistance : 350°C for 5 seconds • Sealing : Panel sealed to IP65, rear of panel IP40 MATERIALS • Screens : PC • Reflector assembly : PC • Operator : PBT • Nut : ABS • Camtrack Momentary : PPE • Camtrack maintained : PPSU • Switch block 1 & 2 pole : PBT • Switch block 3 & 4 pole : PEI • Contacts : Gold plated silver Dimensions : first dimensions are in mm while inches are shown in brackets. Refer to the following pages for further information. Mounting accessories : standard hardware 1 nut and 1 sealing washer. The company reserves the right to change specifications without notice. APEM www.apem.com 1 A01 series Mushroom head pushbutton switches Panel cut-out Ø16 (0.755) Pushbutton Overview APEM www.apem.com 2 A01 series Mushroom head pushbutton switches Accessories Flush mount bezels Ø25.00 (.984 DIA) Ø16.00 (.630DIA) Ø22.00 (.866 DIA) 18.15 (.715) Ø25.00 (.984 DIA) Ø16.00 (.630DIA) 18.15 (.715) Ø22.00 (.866 DIA) Anodised aluminium/matt black 11.00 (.433) 11.00 (.433) +0.20 22.20 0.00 +.008 .000 ) +0.20 22.20 0.00 +.008 .000 ) (.874 (.874 Round natural anodised : A01FMM Round matt black : A01FMMG PCB Sockets Single pole, non illuminated : Double pole, non illuminated : Single pole, illuminated : Double pole, illuminated : Indicator : A01PC1 A01PC2 A01PC3 A01PC4 A01PC5 7,65 0,301 7,65 0,301 18,40 0,724 7.65 (.301) 1,10 0,043 4,25 0,167 4,25 0,167 6,00 0,236 6,00 0,236 Part No. 18,25 0,719 Number of Poles 5,00 0,197 10,25 0,404 10,50 0,413 Terminal guards Eight way 10.00 10.50 10.00 10.50 14.85 14.85 10.00 10.50 10.00 10.50 3.023.02 7.357.35 Part number A01RTC2 APEM 7.45 7.45 7.45 7.45 20.75 20.75 20.75 20.75 6.00 6.00 20.75 6.00 6.00 20.75 Two way 8.50 8.50 20.75 20.75 Part number A01RTC8 www.apem.com 3 A01 series Mushroom head pushbutton switches Accessories & tools Anti rotation ring Blanking plugs 24.0 (.946) 18.0 (.709) Ø18.0 (.709 DIA) 2.00 (.078) A01LW 18.0 (.709) 18.00 (.708) 18.0 (.709) 14.75 (.580) 18.00 (.708) Ø16.00 (.629DIA) Rectangular : A0131 Square : A0132 Round : A0133 Tools Nut fixing key 30-0001 0 236 0.80 (.031) 7.65 (.301) (.167) The company reserves the right to change specifications without notice. APEM www.apem.com 4
A01MXB+A0152B 价格&库存
很抱歉,暂时无法提供与“A01MXB+A0152B”相匹配的价格&库存,您可以联系我们找货
