BD140A01BK0549
BD140A01BK0549
    APEM(埃斐)
    APEM - BD140A01BK0549 - Hall Effect Switch, 1, 5 V, 20 mA
BD140A01BK0549 数据手册
BF series Paddle controllers A The BF Series Paddle is the very latest generation in high precision contactless controls. It combines the features of a contactless single axis joystick and a switch in one control. Long trouble-free life is assured with the latest Hall effect technology, providing a range of analog, switched or custom PWM output options. The all-new design with its innovative mechanism and ergonomic styling is specifically designed for robustness, strength and performance. KEY FEATURES Hall effect joystick and switch function Sculpted ergonomic design Next generation Hall effect technology 5V operation - dual redundant outputs as standard Two lever height variants Industry standard connector IP67 sealed Sprung and detent lever options Available with color-coded inserts EMC & Magnetically shielded - analog or PWM outputs Effectively zero below panel depth End stackable mounting www.apem.com BF series Paddle controllers OPTION SELECTION GAIN PADDLE BF 74mm (2.91in) above the panel BD 50mm (1.97in) above the panel INSERT COLOR 10 +/-10% x V BK Black 25 +/-25% x V RE Red 30 +/-30% x V BL Blue 40 +/-40% x V YE Yellow 50 +/-50% x V GR Green CONFIGURATION MODIFIER 00 None SWITCHING POINTS LEVER OPERATION 1 Standard Dual Outputs A01 Sprung to Center 00 No Switches 2 Inverse Dual Outputs D01 Center Detent 05 +/- 5 Degrees 3 PWM D02 12.5 Degree Detents 12 +/- 12.5 Degrees D03 12.5 & 25 Degree Detents 25 +/- 25 Degrees D04 25 Degree Detents SD1 Sprung to Center with D1 SD2 Sprung to Center with D2 SD3 Sprung to Center with D3 SD4 Sprung to Center with D4 LEVER OPERATION DETENT OPTIONS D01 = CENTER DETENT D02 = +/-12.5 DEGREES D03 = +/- 12.5 & 25 DEGREES D04 = +/-25 DEGREES SPRUNG TO CENTER WITH DETENT OPTIONS SD1 = CENTER DETENT SD2 = +/-12.5 DEGREES SD3 = +/- 12.5 & 25 DEGREES Note: The company reserves the right to change specifications without notice. www.apem.com SD4 = +/- 25 DEGREES BF series Paddle controllers SPECIFICATIONS MECHANICAL Materials Employed Weight Mechanical Operating Angle Max Load to Mechanism – – – – Polyetherimide, Polycarbonate, Stainless Steel 50g +/- 25 Degrees Vertical: IK08 (BSEN62262:2002) Horizontal: 75N (16.86lbf) ELECTRICAL Gain (Output Voltage Span) Output at Center Power Supply Switch Outputs – – – – Sensor Type Current Consumption Loads – – – +/-10% x V to +/-50% x V V/2 +/- (5% x Gain) 5V +/-0.5V Transient free Open Drain, pulled high within control via 1K5 to 5V, and smoothed to 0V with 100nF Hall effect
BD140A01BK0549 价格&库存
很抱歉,暂时无法提供与“BD140A01BK0549”相匹配的价格&库存,您可以联系我们找货
BD140A01BK0549
    库存:7
    BD140A01BK0549
    • 1+954.93080
    • 5+935.84001
    • 10+916.73736
    库存:7
