FMC12A2200000
FMC12A2200000
    APEM(埃斐)
    船型开关 SPST 10A 250V
FMC12A2200000 数据手册
FM series Snap-in rocker switches - panel cut-out 19 x 13 (.750 x .508) Distinctive features and specifications ❑ Illuminated and non-illuminated ❑ For class II appliances ❑ VDE and UL approved ❑ Protection against moisture by double-shell case When the switch is submitted to moisture (drops, condensation), the double-shell case conducts the liquid outside, thus protecting the contact area and terminals. The light dripping inside the equipment resulting from this should be evacuated by adequate arrangement on back of panel. D ❑ Protection by boot In case of sand or splashing water, the best protection consists of insulating the rocker from these aggressive elements. This can be achieved with transparent PVC boot U5720. Order separately, see section H. AGENCY APPROVALS EN 61058-1 Availability : functions 1 and 6 Marking : approved models are standard marked. Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. Packaging unit : 150 pieces. APEM www.apem.com D-41 FM series Snap-in rocker switches - panel cut-out 19 x 13 (.750 x .508) Single pole - non-illuminated • Approved ratings (functions 1 and 6 ) : VDE : 10(4)A 250VAC T85°C - UL : 6A 250VAC & 125VAC T65°C • Max. contact rating : - functions 1 and 6 : see above. - function 3 : 4A 250VAC - functions 8 and 9 : 6A 250VAC • Initial contact resistance : 20mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : - functions 1 and 6 : 2.500 Vrms between terminals - functions 3, 8 and 9 : 1.500 Vrms between terminals • Electrical life at full load : 10 000 cycles FM C 1 3 6 8 9 D • Panel cut-out : Panel thickness Dim. Y Dim. Z 0,75 to 1,25 mm 19,2 +0/-0,1 12,9 +0,15/-0 1,25 to 2 mm 19,4 +0/-0,1 12,9 +0,15/-0 2 to 3 mm 19,8 +0/-0,1 12,9 +0,15/-0 A Electrical functions SERIES • Operating temperature : -20°C to +85°C • Case, frame, rocker : PA6/6 • Contacts : silver • Terminals : silver plated ON OFF MOM OFF ON ON ON OFF MOM ON OFF ON A Silver Frame colour 2 Black Others : on request. Terminals C Non illum. Concave Rocker colours 1 2 3 4 5 6 7 7/1 9 Blue Black (std) Green Grey Yellow Red (std) Ivory White Orange Lamp 0 None Lens colour 0 Marking * No lens 000 None 001 0 002 I 2 Solder lug 8 Quick-conn. 9 Straight PC (funct. 1 & 6) 0 0 Rocker Contacts 0 003 0 I 004 I 0 II ON OFF 005 * Colour of marking : white for black rockers - black for other colours - Other : on request. 0.80 (.031) ON OFF MOM OFF ON ON ON OFF MOM ON OFF ON 3 2 7.00 (.275) 1 12.80 (.504) 7.00 (.275) 18.80 (.740) 21.00 (.827) Y Z 15.00 (.591) FMC1 FMC3 FMC6 FMC8 FMC9 2-3 8.00 (.315) 1-2 9.30 (.366) 12.50 (.492) 4.80 (.189) 1.50 (.059) Single throw and double throw switch Shown with quick-connect terminals 4.70x0.80 (.185x.031) 2.80x0.80 (.11x.031) 2 Solder lug D-42 8 Quick-connect www.apem.com 1.20 x 0.80 (.047 x .031) 13.00 (.512) 7.00 (.275) 1.30 (.051) 3.10 (.122) 5.20 (.204) TERMINALS 9 Straight PC (functions 1 and 6 only) APEM FM series Snap-in rocker switches - panel cut-out 19 x 13 (.750 x .508) Single pole - illuminated • Lens : PC • Contacts : silver • Terminals : silver plated • Lamp terminal : no plating • Fluorescent lamp for blue or green lens, neon lamp for other colours • Panel cut-out : • Approved ratings : VDE : 10(4)A 250VAC T85°C - UL : 6A 250VAC & 125VAC T65°C • LED types available : 3,3V (4V max.) 10mA LED (resistor to be series connected by the user) 5V or 12V LED with integrated resistor • Initial contact resistance : 20mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 2.500 Vrms between terminals • Electrical life at full load : 10 000 cycles • Operating temperature: - 20°C to + 85°C • Case, frame and rocker : PA6/6 FM L 1 Electr. function SERIES 1 L 8 ON - OFF Panel thickness Dim. Y Dim. Z 0,75 to 1,25 mm 19,2 +0/-0,1 12,9 +0,15/-0 1,25 to 2 mm 19,4 +0/-0,1 12,9 +0,15/-0 2 to 3 mm 19,8 +0/-0,1 12,9 +0,15/-0 A Rocker colour Contacts A Rocker Terminals Illumin. concave 8 Quick-connect Silver 1 2 3 4 5 6 7 7/1 9 Frame colour 2 Black Others : on request. Blue Black (std) Green Grey Yellow Red (std) Ivory White Orange Lens colour Lamp Blue * Green * Yellow Red Translucent Orange 1 3 5 6 8 9 * w. fluorescent lamp * Colour of marking : white for black rockers - black for other colours - Other : on request. ** Resistor value = supply voltage - LED forward voltage LED forward current 220V neon 220V fluor. 110V neon 110V fluor. 000 None LED 3,3V 10mA LED 5V A B C D E F G H J K L Blue Red/green Green Yellow White Red Orange No resistor** 001 0 D N Green P Yellow Q Red LED 12V T Green U Yellow V Red 9.30 (.366) 12.50 (.492) 4.80 (.189) 1.50 (.059) Illuminated switches - quick-connect terminals Marking * ON - OFF 3 2 1 7.00 (.275) 7.00 (.275) 1 8.00 (.315) FML1 0.80 (.031) 2 3 12.80 (.504) 18.80 (.740) 21.00 (.827) Y For LED models, terminal 2 = cathode (-), terminal 3 = anode (-) APEM www.apem.com Z 15.00 (.591) AUTRES OPTIONS : voir Guide de Codification sur page ci- D-43
FMC12A2200000 价格&库存
很抱歉,暂时无法提供与“FMC12A2200000”相匹配的价格&库存,您可以联系我们找货
