FPDR3D1428F12D4
FPDR3D1428F12D4
    APEM(埃斐)
    APEM - FPDR3D1428F12D4 - Industrial Pushbutton Switch, Panel, FP, 30.5 mm, DPST-NO, Momentary, Round...
FPDR3D1428F12D4 数据手册
FP series Distinctive features and specifications 00 ) 4. IA Ø3 39D .3 (1 Ø26.50 (1.043DIA) 4.50 (.177) Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching UG1410-A-R3 ❑ Snap-in and threaded bushing models 0.50 (.020) 2.80 (.110) 6.30 (.248) ❑ Large but lightweight 26.50 (1.043) ❑ Full actuator or symbol illumination Ø29.80 (1.173) ❑ Pad printed or laser etched symbols Pad printing CFP30DT Laser B2 Non-illuminated • Max. current/voltage rating with resistive load : - silver contacts (code 2) : 4A 12VDC - gold plated contacts (code 4) : 200mA 12VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. • Electrical life at full load : - Momentary models : 1 million cycles (gold plated contacts) 400.000 cycles (silver contacts) - Latching models : 200.000 cycles 4.50 (.177) 26.50 (1.043) Illuminated 0.50 (.020) 2.80 (.110) MATERIALS 6.30 (.248) ELECTRICAL SPECIFICATIONS 00 ) 4. IA Ø3 39D .3 (1 Ø26.50 (1.043DIA) Ø30.00x1.50 SI (1.181DIAx1.50 IS) • Case : PA46 • Actuator : PA12, gloss finish • Bushing/ bezel : ABS, gloss finish • Contacts : Silver (code 2) or silver, gold plated (code 4) CFP30DT WIRING DIAGRAM ➞ Flat POLE 2 + LED GENERAL SPECIFICATIONS • Panel thickness : - Snap-in version : 1,5 (.059) to 2 mm (.078) with panel gasket 2 (.078) to 2,5 mm (.885) without panel gasket - Threaded bushing version : 1(.039) to 9 mm (.354) max. • Total travel : 2,8 mm ± 0,5 mm • Typical operating force : 8N ± 2N • Low level or mechanical life : - Momentary models : 1 million cycles - Latching models : 200.000 cycles • Torque : 2 Nm max. applied to nut • Operating temperature : -40°C to +75°C LED POLE 1 CFP30DT The company reserves the right to change specifications without notice. B2-150 www.apem.com APEM FP series Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching Overview FP SERIES R Model C D Silver Silver, gold plated Electrical function Round, curved 1 3 Snap-in, dia. 30 mm Threaded bushing, dia. 30 mm Contact mat. 2 4 Actuator Blue Black Green Grey Yellow Red White/natural Bright chrome Orange OFF - ON Normally open (NO) 1 Solder lugs LED control & No of poles A B C D E Actuator colour 1 2 3 4 5 6 7 8 9 Terminals Bezel colour 1 2 3 4 5 6 7 8 Blue Black Green Grey Yellow Red White/natural Bright chrome LED colour X A B C D E F G Non-illum. Blue Green Red Yellow White Red/green Red/blue Non-illuminated, 1 pole Non-illuminated, 2 poles Independent, 1 pole Independent, 2 poles Independent, 1 pole, dimming LED Symbols LED resistor 0 1 2 5 6 No resistor supplied 12V resistor 24VDC resistor 15VDC resistor 30VDC resistor See end of series Marking X 1 2 No marking Pad printing Laser ABOUT THIS SERIES On the following pages, you will find successively : model structure of switches and options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied :1 panel gasket (snap-in versions) 1 plastic hex nut and 1 panel gasket (threaded bushing versions) Packaging unit : 20 pieces APEM www.apem.com B2-151 B2 FP series Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching Ø .20 30. 0D 5 0 IA /+0 0/+ .5 .01 9) 14.00 (.551) (1 CFP30DEC1-A Ø26.50 (1.043DIA) Ø26.50 (1.043DIA) LATCHING OFF - 2.80 (.110) 26.50 6.30 (1.043) (.248) 0.50 (.020) 00 ) 4. IA Ø3 39D .3 (1 FICHIER: CFP30DEC-P3 ECHELLE: 0.625 indice A le 17/02/2014 4.50 26.50 (.177)(1.043) ➞ Flat Snap-in mounting - solder lug terminals FPCR1•1 00 ) 4. IA Ø3 39D .3 (1 ON Ø29.80 (1.173) CFP30DT1-A MOMENTARY (NO) FPCR3•1 2.80 (.110) 6.30 (.248) 0.50 (.020) Ø29.80 (1.173) CFP30DT1-A ➞ Flat Mounting by threaded bushing - solder lug terminals 4.50 (.177) 00 ) 4. IA Ø3 39D .3 (1 Ø26.50 (1.043DIA) LATCHING - ON Ø26.50 (1.043DIA) MOMENTARY (NO) FPDR3•1 0.50 (.020) 0.50 (.020) 00 ) 4. IA Ø3 39D .3 (1 4.50 26.50 (.177) (1.043) OFF 26.50 6.30 (1.043) (.248) FPDR1•1 6.30 (.248) B2 MODEL STRUCTURE 4.50 (.177) To order a product, replace • with one of the codes selected under “LED control and number of poles” on next page, then add he desired options. 2.80 (.110) Ø30.00x1.50 SI (1.181DIAx1.50 IS) CFP30DT2-A 2.80 (.110) Ø30.00x1.50 SI (1.181DIAx1.50 IS) CFP30DT2-A LED B2-152 www.apem.com POLE 2 + LED POLE 2 + LED POLE 1 APEM CFP30DT3-A FP series Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching Options LED CONTROL AND NUMBER OF POLES Complete the model numbers on previous pages with one of the following codes. Function 1 (latching) Function 3 (momentary) Non-illuminated one pole Function 1 (latching) Function 3 (momentary) Independent one pole A C CFPSH1-A CFPSH1-A CFPSH1-A CFPSH1-A CFPSH2-A CFPSH2-A Non-illuminated two poles CFPSH2-A CFPSH2-A ++ -- ++ CFPSH5-A CFPSH5-A - - ++ CFPSH5-A CFPSH5-A -- ++ CFPSH6-A CFPSH6-A -- -- ++ CFPSH7-A CFPSH7-A - - ++ CFPSH7-A CFPSH7-A -- ++ CFPSH8-A CFPSH8-A -- CFPSH6-A CFPSH6-A Independent two poles B D CFPSH3-A CFPSH3-A CFPSH3-A CFPSH3-A CFPSH4-A CFPSH4-A CFPSH4-A CFPSH4-A ++ Independent one pole Dimming LED E + - B2 CFPSH8-A CFPSH8-A dotted line = jumper to be wired by the user. LED- has to be wired to one pin of pole 2. CFP30SHE-A FICHIER: CFPSH-P5 FICHIER: CFPSH-P5 FICHIER: CFPSH-P5 FICHIER:CFPSH-P5 ECHELLE: ECHELLE: 0.625 0.625 ECHELLE: ECHELLE:0.625 0.625 indice A indice A indice A indice A le 19/01/11 le 19/01/11 19/01/11 le le 19/01/11 CONTACT MATERIALS 2 4 FICHIER: CFP30SH-P4 ECHELLE: 0.625 indice A le 03/03/2014 Silver Silver, gold plated ACTUATOR COLOUR 1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7 : white/natural - 8 : bright chrome - 9 : orange BEZEL COLOUR 1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7 : white/natural - 8 : bright chrome LED COLOUR X : non-illuminated A : blue - B : green - C : red - D : yellow - E : white - F : red/green - G : red/blue APEM www.apem.com B2-153 FP series Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching Options LED RESISTOR 0 1 2 5 6 B2 No resistor supplied 12VDC resistor 24VDC resistor 15VDC resistor 30VDC resistor MARKING X 1 2 No marking Pad printing Laser SYMBOLS Blank ➞ Flat No symbol ➞ Available symbols See end of K-range, section D. Ø (.6 16 3 0 .0 0 DI A) Marking colour White marking for illuminated actuators (laser etching) and non-illuminated black actuators (pad printing). Black marking for non-illuminated colour actuators (pad printing). Other : on request. Marking area The symbol will be included in the hatched area. (this is the optimal area, larger symbols can be made on request) CFP30ZL-A FICHIER: CFP30ZL-P5 ECHELLE: 0.625 indice A le 17/02/2014 B2-154 www.apem.com APEM FP series Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching Symbols Most symbols meet the ISO 7000 standard “graphical symbols for use on equipments” (code given in bracket in the description). Contact us for symbols not featured in the following tables. Legend scale : Depending on space available on the product (see “Symbols” section). CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION 32 Emergency first aid vehicle (2565) Rear ventilator 33 Load tipping (1557) 18 Heating (0637) 34 Loading light (2457) - 19 Door opening 35 Tractor, rear-ward (1667) 04 - 20 Windshield demister/defroster (0635) 36 Combine, direction of movement (1678) 05 - 21 Windshield wiper (0086) 37 Use no forks (2406) 06 - 22 Windshield washer (0088) 38 Transmission (1166) 07 Stop 23 Ventilator fan (0089) 39 Working spot light (1145) 08 Motion 24 Side mirror defroster 40 Engine (0640) 09 Up motion 25 Restarting pump 41 Horn (0244) 10 Down motion 26 Front fog lights (0633) 42 Lock (1656) 11 Hot 27 Rear fog lights (0634) 43 Taxi sign light (2551) 12 Cold 28 Propulsion system trim 44 Working light (1204) 13 Hazard warning (0085) 29 Beacon (1141) 45 Working light symmetric (1204) 14 Traveller lighting 30 Anchor 46 - 15 Driver lighting (1421 31 Electric motor (0011) 47 - - 16 01 - 17 02 - 03 XX APEM None Revolving light www.apem.com B2-155 B2 FP series Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching Symbols Most symbols meet the ISO 7000 standard “graphical symbols for use on equipments” (code given in bracket in the description). Contact us for symbols not featured in the following tables. Legend scale : Depending on space available on the product (see “Symbols” section). CODE B2 DESCRIPTION CODE DESCRIPTION CODE 48 All wheel drive 64 Indicator 80 Front windshield heating 49 Differential lock (1662) 65 Brake release 81 Aus 50 - 66 Baggage room left door 82 Radiator fan 51 - 67 Baggage room right door 83 Remove retarder 52 - 68 Power blinds 84 Restricted speed 53 - 69 Engine idle control 85 Preheater 54 Rear window wiper (0097) 70 Cruise res/set 86 ABS detection 55 Rear window washer (0099) 71 Driver windows up/down 87 ECAS detection 56 Lower load (2223) 72 Middle door opening 88 Engine stop 57 Cab lock (1560) 73 Front door opening 89 Cruise res/cancel 58 Extraction 74 Lighting in baggage room 90 ECAS reset 59 Pumping in 75 Cruise on/off 91 Driver windows heating 60 Rear PTO (1572) 76 TV 92 Cruise set 61 Front PTO 77 Pump 93 Air bag up/down 62 Rockshaft down 78 Toilet 94 Read lighting 63 Rockshaft up 79 Toilet decontamination 95 Lighting main switch B2-156 SYMBOL SYMBOL www.apem.com SYMBOL DESCRIPTION APEM FP series Fully illuminated pushbutton switches - bushing Ø 30 mm - momentary or latching Symbols Most symbols meet the ISO 7000 standard “graphical symbols for use on equipments” (code given in bracket in the description). Contact us for symbols not featured in the following tables. Legend scale : Depending on space available on the product (see “Symbols” section). CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION CODE SYMBOL DESCRIPTION 96 Heating using water AD - AV - 97 Low beam AE - AW - 98 Position lights AF - AY - 99 Diesel acceleration AG Battery charging condition (0247) AZ - A1 Manual mode AH Turn signals (0084) B1 - A2 Clockwise cabin rotation AJ High beam (0082) B2 - A3 Anticlockwise cabin rotation AK Differential lock, bogie (2600) B3 - A4 - AL Brushing with a rotating brush (0070) A5 - AM Differential lock, transfer case 4x4 (2475) A6 Parking brake AN Loader bucket, float (1441) A7 - AP Loader bucket (1437) A8 - AQ Rear window washer & wiper (0098) A9 - AR Header Header drive (1579) AA - AS Excavator/backhoe boom side shift (2091) AB - AT Chemical water treatment (1851) AC - AU Grapple skidder, single funct° boom (1762) APEM www.apem.com B2-157 B2
FPDR3D1428F12D4
该PDF文档提供的信息包括: - 物料型号:MSP430F149 - 器件简介:MSP430F149是德州仪器(TI)推出的一款16位超低功耗微控制器,适用于需要电池供电或能量收集的场合。
- 引脚分配:该微控制器有多个引脚,其中包含电源引脚、地引脚、I/O引脚等,具体分配需要查看数据手册。
- 参数特性:包括工作电压范围、工作频率、内存容量等。
- 功能详解:详细介绍了其内部功能模块如ADC、定时器、通信接口等。
- 应用信息:适合用于便携式设备、医疗设备、工业控制等领域。
- 封装信息:提供多种封装形式,如QFP、BGA等。
FPDR3D1428F12D4 价格&库存
很抱歉,暂时无法提供与“FPDR3D1428F12D4”相匹配的价格&库存,您可以联系我们找货
