25136NAH
25136NAH
    APEM(埃斐)
    插件,14.1x7.5mm
    滑动开关 插件,14.1x7.5mm 单刀双掷 1万次 直插
25136NAH 数据手册
05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page14 25000N series Professional slide switches Distinctive features and specifications UG1410A ❑ Professional grade slide switches for PC boards ❑ Approved according to UL 1054 ❑ Wave solderable Not washable in aqueous process ❑ Available with flush, high and side actuator ❑ Various actuator lengths ELECTRICAL SPECIFICATIONS E • Max. current/voltage rating with resistive load : - silver contacts (A) : 1A 30VDC - gold plated brass contacts (LD) : 100mA 30VDC • Minimum load : - silver contacts (A) : 100mA 10V - gold plated brass contacts (LD) : 10µA 5VDC - 10mA 50mV • Initial contact resistance : - silver contacts (A) : 10mΩ max. - gold plated brass contacts (LD) : 50mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between poles 2.000 Vrms 50 Hz min. between terminals and frame • Electrical life : 10.000 cycles at full load • Low level or mechanical life : 20.000 cycles APPROVALS 2A 250VAC 4A 125VAC Availability : consult factory for details of approved models. Marking : To order switches marked UL, complete the “Options and Approvals” box of ordering format. MATERIALS • Case : PBT • Actuator : polyamide, glass filled • Cover : polyamide, glass filled • Contacts A : silver LD : brass, gold plated • Terminal seal : epoxy GENERAL SPECIFICATIONS • Operating temperature : -40°C to +85°C • Overall length : 14 mm (.551) • Actuator height (outside case) : - high : 2,80 mm (.110) - extra high : 6 mm (.236) - side : 2,3 mm (.090) - long side : 6 mm (.236) • Travel : 4 mm (.157) The company reserves the right to change specifications without notice. E-14 www.apem.com APEM 05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page15 25000N series Professional slide switches Overview N 25 Actuator and terminals SERIES 1 4 3 5 Flush or high actuator, terminal spacing 2,54 (.100) Flush or high actuator, terminal spacing 5,08 (.200) Side actuator, terminal spacing 2,54 (.100) Side actuator, terminal spacing 5,08 (.200) Number of poles 3 4 Single pole Double pole Contact materials A Silver LD Gold plated brass Electrical functions 6 9 Actuator B H H6 Blank -6 Flush High Extra high Side Long side ON ON OFF Version N For all models ON ON Options and approvals X601 Special contact : lower rating Other : see following pages. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches (including actuator options) - contact options Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Packaging unit : single pole : 100 pieces - double pole : 50 pieces APEM www.apem.com E-15 E 05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page16 25000N series Professional slide switches • Epoxy sealed terminals standard • 1 and 2 pole configurations • UL approved models : see next page. MODEL STRUCTURE Double pole 25446N H 25449N H Extra high actuator : 25000NH6 E-16 Terminal spacing 2,54 (.100) Terminal spacing 5,08 (.200) Single pole 25136N H6 25139N H6 Single pole 25436N H6 25439N H6 Double pole 25146N H6 25149N H6 Double pole 25446N H6 25449N H6 www.apem.com 3.00 (.118) 3.00 (.118) 0.60 (.023) 7.50 (.295) 0.60 (.023) 2.54 (.100) Shown with 5,08 mm terminal spacing 14.10 (.555) 0.50 (.019) 5.08 (.200) 12.50 (.465) 5.08 (.200) Double pole 25146N H 25149N H 5.08 (.200) Ø1.10 (.043DIA) EPOXY 0.60 (.023) 5.08 (.200) Single pole 25436N H 25439N H 5.08 (.200) 5.08 (.200) 5.08 (.200) Shown with 5,08 mm terminal spacing 14.10 (.555) 3.00 (.118) 0.50 (.019) 5.08 (.200) 12.50 (.465) 3.00 (.118) 5.08 (.200) Single pole 25136N H 25139N H 0.60 (.023) Ø1.10 (.043DIA) EPOXY 0.60 (.023) 5.08 (.200) Terminal spacing 5,08 (.200) 2.54 (.100) EPOXY 2.80 (.110) Terminal spacing 2,54 (.100) 7.50 (.295) 0.50 (.019) 6.00 (.236) High actuator : 25000NH 0.60 (.023) 8.10 (.318) Double pole 25446N B 25449N B Ø1.10 (.043DIA) 8.10 (.318) Double pole 25146N B 25149N B 12.50 (.465) 8.10 (.318) Single pole 25436N B 25439N B 14.10 (.555) 3.80 (.149) Single pole 25136N B 25139N B 7.50 (.295) 3.80 (.149) Terminal spacing 5,08 (.200) 3.80 (.149) E Terminal spacing 2,54 (.100) 2.54 (.100) Shown with 2,54 mm terminal spacing Flush actuator : 25000NB 5.08 (.200) 5.08 (.200) APEM 05-Serie 25000N-A_05-Serie 25000N-A 06/11/14 13:55 Page17 25000N series Professional slide switches Shown with 2,54 mm terminal spacing Double pole 25546N 25549N 0.60 (.023) 0.50 (.019) 5.08 (.200) 5.08 (.200) Double pole 25346N -6 25349N -6 Double pole 25546N -6 25549N -6 PCB MOUNTING 6.00 (.236) Ø1.10 (.043DIA) 8.10 (.318) 3.00 (.118) 0.60 (.023) 12.50 (.465) 0.50 (.019) 2.54 (.100) EPOXY 2.54 (.100) Single pole 25536N -6 25539N -6 3.00 (.118) 14.10 (.555) 0.60 (.023) 2.54 (.100) Single pole 25336N -6 25339N -6 7.50 (.295) 4.30 (.169) Terminal spacing 5,08 (.200) 5.08 (.200) 5.08 (.200) E POSITIONS AND CONNECTIONS 7.50 (.295) 2.30 (.090) 7.50 (.295) 2 6.00 (.236) 1 1 2 2 1 1 2 2 1 1 10.80 (.425) 14.10 (.555) 8.10 (.318) 0.60 (.023) EPOXY 2.54 (.100) 3.80 (.149) Terminal spacing 2,54 (.100) H Ø1.10 (.043DIA) Shown with 2,54 mm terminal spacing Long side actuator : 25000N-6 B 2.30 (.090) 2.54 (.100) Double pole 25346N 25349N 12.50 (.465) 2.54 (.100) Single pole 25536N 25539N 3.00 (.118) 14.10 (.555) 6.00 (.236) Single pole 25336N 25339N 7.50 (.295) 3.80 (.149) Terminal spacing 5,08 (.200) 1.30 (.051) Terminal spacing 2,54 (.100) 8.10 (.318) Side actuator : 25000N H6 6 Function 6 Function 9 ON ON OFF ON ON CONTACT MATERIALS A LD Silver Brass, gold plated OPTIONS AND APPROVALS X601 X693 X693UL APEM Silver plated brass contacts - Lower rating 3VA 30VDC. Min quantity : 5.000 pieces per model and shipment. Flame retardant plastic materials Switches approved and marked UL (silver contacts only) www.apem.com E-17
25136NAH 价格&库存
很抱歉,暂时无法提供与“25136NAH”相匹配的价格&库存,您可以联系我们找货
25136NAH
    • 1+48.19947
    • 100+46.85794
    • 250+44.92948
    • 500+43.67179
    库存:84
    25136NAH
      • 1+23.83560
      • 200+9.22320
      • 500+8.89920
