A02ESI3B102IX0+PEA01+QH22L28RGC
    APEM(埃斐)
    APEM - A02ESI3B102IX0+PEA01+QH22L28RGC - Emergency Stop Switch, DPST-NC, On-Off, 10 A, 24 V, 24 V
A02ESI3B102IX0+PEA01+QH22L28RGC 数据手册
A02ES-I series Emergency stop switches Distinctive features and specifications ❑ Approved to EN 60947-5-5, UL 508 and CSA C22.2 No 14-10 ❑ Industrial range A02ESI1701A-R2 ❑ Pull or twist to release ❑ AC-12, 6A 240VAC / DC-12, 8A 24VAC ❑ Panel sealed to IP65 ❑ Illuminated model ELECTRICAL SPECIFICATIONS GENERAL SPECIFICATIONS • Electrical function : push to shutt off, pull or twist to release • Current/voltage rating : AC-12, 10A 24VAC / 6A 240VAC DC-12, 8A 24VDC AC-15, 10A 24VAC / 3A 240VAC DC-13, 4A 24VDC • Electrical life : 100.000 cycles with one contact block • Insulation resistance : 50 MΩ min. • Dielectric stength : contact block 2.500 Vrms • Contacts : silver • Panel thickness : 6 mm (.236) max. • Low level or mechanical life : 250.000 cycles w. one contact block • Operating temperature -20°C to +55°C • Switch terminals : M3.5 screws AGENCY APPROVALS ENVIRONMENTAL SPECIFICATIONS • Front panel sealing : IP65 UL 508 CSA C22.2 No 14-10 EN 60947-5-5 PANEL CUT-OUT MOUNTING LOCKING SYSTEM ( .70 22 A) 0 -Ø D I 2.3 -.893 2 Ø DIA 7 .87 .80 R0 RAD) 31 (.0 24.10-24.5 (.948-.964) 3.2-3.4 (.125-133) fichier Fichier: CA02ESIPE eche Single pole Normally closed ECHELLE: 0.5 le 03/11/2015 Double pole Normally closed Mounting accessories : Standard hardware supplied : 1 nut and 1 flat panel seal Packaging unit : box of 5 pieces Fichier: CA02ESSH revision 3 1 ECHELLE: 1 The company reserves the right to change specifications without notice - Not for sale in JAPAN. APEM www.apem.com A02ES-I series Emergency stop switches Panel cut-out Ø 22 (.866) 10.00 (.393) Ø40.00 (1.574 DIA) Panel thickness 0.8(.031) to 6(.236) Single pole - Normally closed A02ESI3B101IX0 0.50 (0.019) Contact Block-M3.5 Terminal Screw Locking ring Gasket 41.40 (1.629) 28.60 (1.125) Lock 30.00 (1.181) 45.80 (1.803) 32.50 (1.279) Panel thickness 0.8(.031) to 6(.236) A02ESI3B102IX0 Ø40.00 (1.574 DIA) 10.00 (.393) Double pole - Normally closed Contact Block-M3.5 Terminal Screw Fichier: CA02ESI3B101IX0VDT Locking ring indice : B Lock 0.50 (0.019) Gasket ECHELLE: 0.5 41.40 (1.629) 28.60 (1.125) le 08/12/2015 30.00 (1.181) 45.80 (1.803) 32.50 (1.279) 10.00 (.393) Ø40.00 (1.574 DIA) Panel thickness 0.8(.031) to 6(.236) Single pole - Normally closed - illuminated With LED 24V A02ESI4B101IR2 0.50 (0.019) Contact Block-M3.5 Terminal Screw Locking ring Gasket 41.40 (1.629) 28.60 (1.125) Lock 30.00 (1.181) 2 45.80 (1.803) 32.50 (1.279) www.apem.com APEM Fichier: CA02ESI3B102IX0VDT Fichier: CA02ESI4B101IR2VDT indice : B A02ES-I series Emergency stop switches Accessories Ø 60 mm name plate Ø60.00 (2.362DIA) Anti-rotation ring 1.00 (.039) Ø29.00 (1.141DIA) Ø22.00 (.866DIA) 1.50 (.059) Ø22.00 (.866DIA) 1.50 (.059) A02-U9ZRL Legend “EMERGENCY STOP“ is indicated outside A02-U27Y a Ø 44 mm circle. Locking ring wrench A02-U27Y 110.00 (4.330) Ø28.00 (1.102DIA) fichier CA02-U9ZRL echelle : 1 date : 18/11/2015 A02-9ZT1 par MD fichier CA02-U27Y echelle : 1 date : 18/11/2015 par MD fichier CA02-9ZT1 echelle : 1 date : 18/11/2015 par MD APEM www.apem.com 3
A02ESI3B102IX0+PEA01+QH22L28RGC 价格&库存
很抱歉,暂时无法提供与“A02ESI3B102IX0+PEA01+QH22L28RGC”相匹配的价格&库存,您可以联系我们找货
  • 1+602.80133
  • 5+572.99645
  • 10+550.95128
库存:2
